1. Offline
    theshark New Member
    Start a Conversation
    Nov 3, 2010
    52
    Martinsburg, WV
    Your Vehicle Year:
    The front windshield washer is not working. I can hear the pump running but no fluid comes out. The rear washer works fine.
    Any Ideas?
    Thanks in advance
  2. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,276
    649
    Wilmington, NC
    Your Vehicle Year:
    If the rear ones work and the front does not, and the fact that you can hear the front pump running, the first thing I would check is to take a pin and insert in the holes in the front spray nozzles to make sure they are not plugged.
    If this does not work I would check the plastic hoses between the washer fluid container and the front wiper spray nozzles to make sure they have not come loose.
  3. Offline
    theshark New Member
    Nov 3, 2010
    52
    Martinsburg, WV
    Your Vehicle Year:
    Thank you. The fix was simple, a lose filler cap..
    Thanks again
Share This Page
