1. Offline
    tony New Member
    Start a Conversation
    Mar 15, 2004
    I only get about 300 miles on a full tank of gas and the gage reads empty and the warning light comes on …indicating that I need to get to a gas station soon. . However when fill up it only takes 7+ gallons.. in other words, I still had about 4 gallons in the tank, and at an average of 45 mpg I should be able to go another 200 miles (approximately) but the gage was reading empty and the warning light was flashing.
    I went to the dealer to ask them about this problem and they say it was normal for the Prius because it had a bladder gas tank and it depended on the atmospheric pressure, temperature etc.
    Have any of you had a similar problem?
  2. Offline
    jchu New Member
    Mar 2, 2004
    1,063
    Nampa, ID
    Lots of posts in other threads in this forum. Has alot to do with the tank system which is not a simple metal container. Inside the metal tank is a bladder that expands as gas is introduced and contracts as gas is removed. This is to eliminate most of the gas vapor over the emptying tank and thereby decreasing car emissions when refueling.
    Thus a simple bouy system doesn't work to measure remaining gas. The system that Toyota came up with results in a great deal of "reserve" However, it has been observed that it is NOT a good idea to run out of gas in this car. Limping to the gas station on battery alone runs the risk of excessively deep discharging of the Main Battery Bank.
  3. Offline
    tag New Member
    Nov 26, 2003
    2,526
    Chicago
    Figure this one out:
    I filled up earlier last week allowing the pump to click off. The fuel gauge read "full" showing, I believe, 10 bars. I drove the thing about 100 miles before the first bar disappeared (leaving 9 bars lit up). The MFD showed about 54 mpg.
    I am now going to record how many miles I get for each bar on the fuel gauge.
  4. Offline
    rflagg Member
    Jan 5, 2004
    946
    Springfield, VA
    Finding a rhyme or reason to how the bars decrease on the gauge - prefix, anyway - is like figuring out Hawking's Theory of Everything before he does.
    On the up side, with spending between 5 and 10 minutes at the pump, I consistently get 10+ gallons into the tank, and I don't even pay attention to the gauge if I'm below 500 miles (unless, of course, my MPG is below 48 or so, which is rare). My only suggestion is to go as far as comfortable for yourself, and attempt to consistently achieve that.
    -m.
  5. Offline
    jamarimutt New Member
    May 4, 2004
    985
    When I fill the tank completely, I go 150-175 miles before the first square in the gauge goes off. From then on the squares disappear faster, and slow again when I reach two bars.
    The othe day I parked on an incline with two bars on the gauge and when I came back six hours later I had one blinking bar! The gauge never returned to two bars and I filled up 30 miles later.
  6. Offline
    mikepaul New Member
    Dec 2, 2003
    1,764
    Columbia, SC
    Your Vehicle Year:
    When I FILL the tank, I've gone as far as 205 miles before the first bar went out. That was averaging 54-odd MPG on a trip.
    The only way to be sure the tank is full is to wait until a small amount of gasoline is visible when you stop and pull the filler out. Too much, and it will leap out at you. I've settled on 25 cents worth of gas as my add-then-check amount when I'm close to being full, but that's getting to be a little more gas each time due to price decreases, so I may have to go to 20 cents soon.
    The Wal-Mart gas I got Friday for $1.769 is doing OK, much better than the previous Hess tank. Too bad I didn't wait until Saturday for another penny decrease, but I'll gladly put up with disappointments like that for a return to $1.199 or less sometime down the road...
  7. Offline
    tag New Member
    Nov 26, 2003
    2,526
    Chicago
    Yes, I've noticed that; I haven't seen a bar that disappeared light up again.
    As soon as I get down to one bar, I start looking for a gas station. I've just been letting the pump click off so far. Maybe one day I'll see how much I can cram into the tank after the pump clicks off.
  8. Offline
    rflagg Member
    Jan 5, 2004
    946
    Springfield, VA
    You know, I was back in Michigan when the prices went down. Out there, it was down to $1.75, and in Ohio, $1.69. Needless to say, I was quite upset to come home to the same prices as when I left! Right now I still can't find it for less than $2/gal.
    -m.
  9. Offline
    randalla Member
    Jan 22, 2004
    361
    Lexington, SC
    Your Vehicle Year:
    Yeah, its seems that gas prices in the DC area are first to spike upwards higher than a most other areas of the country and last to fall when other areas have already dropped their prices. Gasbuddy.com consistently showed the Germantown-Gaithersburg MD area commanding the highest gas prices in Maryland, though they have fallen back .05-.10 cents since their peak prices.
  10. Offline
    frenchofva New Member
    Jun 21, 2004
    Northern VA
    Your Vehicle Year:
    [font=Lucida Console:76dd18dfbb]For people in Northern VA, Costco is usually about $0.15 less than local average. Just filled up @ Sterling (VA) Costco for $1.839 Saturday 06/19[/font:76dd18dfbb]
  11. Offline
    rflagg Member
    Jan 5, 2004
    946
    Springfield, VA
  12. Offline
    priusist New Member
    Dec 9, 2004
    27
    Fremont, CA
    Having read this discussion, I experienced this problem yesterday.
    I had one level left after 430 miles on my 05 Prius. I stopped by a cheap gas station ($1.89/g) to fill it up and tried to figure out the result of my third tank. To my surprise, it stopped at 5.5 gal. This reminded me of the problem because my MPG for that tank had been about 50. I believed I should be able to keep pumping more, but it stopped almost immediately every time and I gave up at 6 gal after a few tries. Back into my car, I saw one level left to the tank full.
    Hence I'm pending the MPG math for these two tanks.
  13. Offline
    nathanvoght New Member
    Nov 3, 2004
    Howell, Michigan
    I have had the exact same problem as Priusist recently. The tank only took about 6 or 7 gallons, and the gauge never went all the way up when I got back in the car. On the ensuing tank, the computer calculated about 33 mpg, but my calculations were off, because the tank was never really full, according to the guage.
    This fuel tank thing has really bothered me. My first tank from the dealership I went 440 miles and was able to put about 8.5 gallons back in after. From that point forward, I have never been able to go more than about 325 miles before I get the low fuel warning!! And when I fill up, it may only put 6, 7 or 8 gallons in, but can be very inconsistent! Does the tightness of pump in the side of the fuel tank hole make pressure build up and stop the pump prematurely?? Every time I try to top off, it doesn't really let me... I remain very frustrated at the fuel tank/guage design.
  14. Offline
    bruceha_2000 Senior Member
    Jan 2, 2004
    2,686
    43
    South Burlington, VT
    Your Vehicle Year:
    I had a problem only once having fills consistant with the computer MPG until the last couple of times. The last 2 it clicked off about a 1.5 gallons early. So I kept going, 5 drops at a time it seemed. Gentle on the handle (like trying to hold computer selected EV mode ;-) ). I'm wondering if the cold is keeping the bladder from expanding as much as usual. I did pull the nozzle out a few time in case there was air back pressure or something but it didn't seem to help. Never a hint of spit back or a 'near full' sound in the pipe.
  15. Offline
    Canuck Member
    Aug 16, 2004
    608
    Vancouver Island,BC,Canada
    Your Vehicle Year:
    I've decided to ignore the little squares entirely. We reset our "B" odometer to 0 when we fuel up and refill around 400 miles (640 km). Am not going to be a slave to a computer...... hey, wait ...the whole vehicle is a computer. Sorry Prius Master!
  16. Offline
    priusist New Member
    Dec 9, 2004
    27
    Fremont, CA
    <div class='quotetop'>QUOTE(priusist\";p=\"61185)</div>
    I was doing my fourth tank two days ago and it went back to normal. With the last one level blinking and "add fuel" showing up on the monitor, I was able to pump in about 10 gal after 330 miles for the previous tanl of 6 gal.
Share This Page
