Fuel Gauge Calibration Instructions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Feb 2, 2006.
  1. darwin100
    darwin100 New Member
    131
    how do you turn the Odo/Trip off then on? when I hit it it goes to B then odo reading
    where does the 6 digit code appear
    I got to keep your foot off the brake then whe I pushed the power button twice the gauges were black (ie not showing) sometimes they are showing at least 3 of the yellow pictures were up...I tried it several times
    thanks
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(darwin100 @ May 6 2006, 11:35 AM) [snapback]250776[/snapback]</div>
    Make sure that the odometer is on Trip A when you power off the car. With the car still OFF, push and hold down the Odo/Trip button. Then, with the foot off the brake, while still holding down the Odo/Trip button, push the Power button twice. At this point, release the Odo/Trip button and push it three times within five seconds. On the third push keep holding it down until a six digit code appears in the Odometer readout. When the code appears, release the Odo/Trip button and immediately push it again and hold it down for another five seconds. At this point, the six digit code will change to a five digit number. The last digit will keep changing. When it turns to 1, release the Odo/Trip button and the normal odometer reading should be visible.
    ydpplqbd likes this.
  3. prius2go
    prius2go Member
    311
    Ive tried this about a 100 times and I cant get the sequence to work :(
    anyone else?
    Does the odometer step through each time you press it quickly?
  4. Bobby T
    Bobby T Junior Member
    Chicago
    Ok. I have am issue. Regardless of how cold it has been here in Chicago the gas gauge had been working properly. I pumped about 4 gallons yesterday and the gas gauge did not reset to full from 1/2 reading. Thinking that pumping gas would reset the gauge, I went to the gas station again after driving 100 miles today. Between yesterday, drove 100 miles, put more gas to fill level, the gas gauge never budged. Never had this issue before. I have read all the posts here but am at my wits end here. Before I go to the dealer, anyone have any ideas?
  5. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I would try disconnecting the 12V battery. no tools required, you can remove the red cover then disconnect the white clips on the positive side and that will disconnect it. Hope this helps!
  6. Anthony Williams
    Anthony Williams Antonation205
    Birmingham
    I had problems with the sequence as well, but I figured it out. After you turn the car off and then back on, you must press the odometer button 3 times quickly. My problem was that I was waiting five seconds after turning the car back on, but as soon as you turn the car back on press the button three times quickly and hold it down on the 3rd push. Then the code will appear.
  7. waltvl
    waltvl New Member
    sc
    Don't count on the Toyota dealer doing this for you. Today I asked them and was told that the Prius for 2005 did not have inclination sensors. I don't know what to believe. This was Sparks Toyota in Myrtle Beach. Maybe I'll try these instructions listed here by myself.
    SFO likes this.
  8. bisco
    48,945
    or another dealer. welcome to priuschat!(y)
  9. pburkh
    pburkh Junior Member
    I have a 2007 Prius with 140,000 miles. When I go to fill up on the flashing final pip, I can only get 7.0 gallons in. Used to put in 9+ gallons when that low. I've tried the fuel gauge reset process and we'll see how it goes.
    ydpplqbd and fairclge like this.
  10. AquaJan
    AquaJan Junior Member
    47
    17
    US
    Any luck?
    My 2007 with 180k just started doing the same thing. Also, after a fill up (until the nozzle clicks) it only shows 9 pips.
  11. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Always enjoy learning something new after viewing an old thread for the first time :whistle:
  12. Fred Norris
    Fred Norris New Member
    CLT, NC
    Hi Everybody,
    About a month ago the maintenance required light came on, really wasn't worried about that one since I change the oil and filter every 3K miles and check for codes. But the fuel gauge started acting crazy it showed 1/2 tank. I filled it up but it never changed! So A REALLY BIG THANKS to everyone in this site and sharing information. MY first problem on the 09' Prius I couldn't get to trip/Odo A. After about 15 tries it started working where I could change it. I did the calibration from the great help here and it worked as they said. But the fuel gauge was still stuck, I reset the maintenance light and decided to pull off the positive side of the battery and it looks like a motorcycle battery right along side of it. Let it sit for 10 minutes and put everything back together. Now the fuel gauge seems to be working I filled it up and the gas station is only 3 miles from my house. So we'll see what happens. But, Thanks to everyone and your help, much appreciated.
    Fred
  13. Yiye
    Yiye New Member
    Three Touring
    This is what worked for me. Disconnect both terminals of the aux battery and touch the end of the cable together for 5 seconds. Re-connect the cables. This will recalibrate everything in your car.
  14. kswahl1
    kswahl1 Junior Member
    46
    Is this for real?
  15. ChapmanF
    15,067
    No. But it will leave you needing to reinitialize various things mentioned in the manual as needing it after the battery has been disconnected. Power windows, etc. Radio presets. Mostly easy stuff.
  16. ydpplqbd
    ydpplqbd Active Member
    542
    250
    Same thing that I am dealing with now.
  17. Organfreak
    Organfreak Junior Member
    42
    17
    Gig Harbor, WA
    My Gen2 2008 guage is stuck now at 2 pips, no matter what's in it. Temps are cool. Might this 'reset' procedure fix it?
  18. ydpplqbd
    542
    250
    My suggestion is give the fuel gauge recalibration procedure a try. And, then let us know how you make out.
    SFO likes this.
  19. gary40
    gary40 Junior Member
    Maryland
    I have the problem with the fuel gauge giving an incorrect reading and decreasing rapidly full to half-full after only 185 miles. This happens after I changed the 12-volt battery. So I tried the above instruction for resetting the fuel gauge. BUT.. how do you turn the Odo/Trip off and then on 3 times? All that has done was circling through trip B, odo, trip A. Holding down the odo/trip button afterward did not produce any 6-digit code.
  20. dolj
    dolj Senior Member
    7,483
    3,763
    Wellington, New Zealand
    Are you in the correct mode, IG-ON when doing the procedure? IG-ON is when you press the power button twice with your foot OFF the brake pedal.
    From my reading of the instruction in step #7:
    Release the ODO button then press the ODO button
    release the ODO button then press the ODO button
    release the ODO button then press the ODO button and hold down the button – all within 5 seconds.
    I hope that helps.
