1. Offline
    alfon Active Member
    Start a Conversation
    May 17, 2009
    1,165
    167
    seaside, oregon
    Your Vehicle Year:
    Has anyone filled their Prius C to the top of the filler neck,
    and if so how many gallons did it take after the
    auto shut off on the pump clicked off.
    On our Prius our tank can still hold about 2.1 gallons
    or so after auto click-off and filled to the top
    of the filler neck so you can see standing fuel.
    Factory tank capacity is listed at 11.9 gallons but
    true tank capacity is more closer to 14 gallons or
    so.
    I know, I know, that this practice is considered unsafe
    and can cause severe engine damage. But true reports
    on this are far and few between or nonexistent.
    But that aside I am just looking for the true tank capacity
    of the Prius C which I believe is factory listed at 9.5 gallons or
    so.
  2. Offline
    crebble Member
    Mar 16, 2012
    176
    42
    Shohola PA
    Your Vehicle Year:
    I've always read that it can backfill into your Evap system and in some cars throw a CEL. Plus, you leave no room for gas expansion. Not worth the extra range.
    EPA says not to top off
  3. Online
    Oct 26, 2009
    770
    224
    Maryland
    Your Vehicle Year:
    Going beyond the first click from the gas pump (filling up over the official stated fuel capacity of the tank) is only safe if you know you are going to burn that extra 2.1 gallons immediately after you do the fillup, i.e. if you are doing the fillup right before going on a greater than 120 mile road trip. The extra fuel is stored in the gasoline vapor pressure release valve and the overflow release. If the gas gets too hot and starts to expand there is a risk that the vapor pressure release valve or the fuel pump inside the gas tank could get damaged or its lifespan might be lessened.
    IF that extra gasoline is not burnt right away AND it gets really hot and expands over the design limits of the tank THEN IF everything works the way it is suppose to THEN that extra gasoline that is now to hot to hold will escape through a tanks overflow/pressure release valve and your MPG will drop proportionally and your range for that tank of gasoline will not be extended.
    A better and proven way to maximize the range of a Prius c is to drive under 50 mph and avoiding jack rabbit accelerations. Several people on Priuschat have reported being able to extend the range of a regular Prius hatchback over 700 miles per tank (usually getting +65mpg in the process) without overfilling their gasoline tanks -- just by driving the Prius more fuel efficiently. I am confident that once Prius c drivers learn more about their car - many of them will be able to beat the Prius hatchback with respect to range and fuel efficiency, too.
  4. Offline
    XRinger Member
    May 8, 2012
    116
    17
    Woburn, MA
    Your Vehicle Year:
    Way back before self-service, a gas pump jerk over-filled the tank on my little 4wd subaru wagon.
    A few miles down the road we stopped at a store. (It was a hot day).
    After a few minutes a guy ran into the store yelling for people to get their cars out of the parking lot.
    I ran out and found gas dripping out of my car was running down-hill in the lot.
    The little river of gas ran under about a dozen other cars.
    Not only did he over-fill, he left the gas cap loose..
    The car was parked at a slightly nose-up angle, which made the expansion worse.
    Oh yeah, now I remember. He also chipped the paint (twice) near the gas cap cover.
    Makes me really like self service..
  5. Offline
    Oldwolf Prius Enthusiast
    Feb 15, 2011
    569
    49
    NC
    Your Vehicle Year:
    In my Gen II, the model with the fuel tank bladder, the instructions were to fill the tank with the dispenser nozzle at the lowest flow rate, iow's, at the first click. I might do this on my C for the heck of it. Since it has no bladder to expand though, I'll probably be wasting my time now that I think about it.
  6. Offline
    alfon Active Member
    May 17, 2009
    1,165
    167
    seaside, oregon
    Your Vehicle Year:
    Here in the lovely state of Oregon you are forbidden to
    pump gas in you own gas powered car.
    Now, its OK if you have a motorcycle or a diesel
    powered vehicle, but, god forbid if you
    pump gasoline into your car.
    Of course drive across the Columbia River into Washington, or
    over the eastern border into Idaho, or the souther border of
    Nevada,or California, your choice, and you can pump your
    own gas with fear of penalty.
  7. Offline
    ftl Researcher
    Jun 2, 2009
    566
    183
    Long Island NY
    Your Vehicle Year:
    Same in New Jersey, where you get full service and cheap gas.
  8. Offline
    Ashley7 Active Member
    Mar 19, 2012
    499
    156
    Oregon
    Your Vehicle Year:
    ^Having been raised in Oregon, I've never properly learned how to pump gas. Even though I'm certain it's the easiest thing ever, it makes me nervous on the rare occasion I leave the state :rolleyes:
  9. Offline
    XRinger Member
    May 8, 2012
    116
    17
    Woburn, MA
    Your Vehicle Year:
    My sister-in-law never learned. She doesn't like the smell of gas..
    Funny thing is, she had to learn to deal with the results of bad service.
    Her 2001 Toyota Echo is very sensitive to over-filling and loose gas caps.
    Every year I would reset her errors codes (& tighten the cap) so she could get her car inspected.
    All she had to do was drive it for a few days and avoid gas station stops.
    After a few years, I got her trained to tighten the cap and ordered her a code reader,
    so she can clear out emissions errors as they occur.. (She has the list).
    She leaves it plugged in, like it was a Scangauge2.. :rolleyes:
  10. Offline
    Codyroo Senior Member
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    Alfon,
    That would mirror, roughly, what others have seen here that overfill their tanks to the neck (at least in the liftback).
    Realize, not everyone overfills to get the big range boost. Some do it to keep their fill ups "consistent" in a single tank.
    My previous method was to fill on the slow setting and when I was within 2 gallons of the estimated shut-off value, I'd hand pump as slow as I could (so the vapor pressure wouldn't vary so much). After the first click, I'd wait 15 seconds and fill to the second click (usually 0.2 to 0.3 gallons) and end the fill up there.
    I gave up doing that and just fill to the first click. My tank to tank variation hasn't changed significantly and I do calculate over the lifetime of my ownership (nearly 50,000 miles and counting).
  11. Offline
    rwn Junior Member
    Mar 25, 2012
    Bend
    Your Vehicle Year:
    I grew up in MN and have lived in Oregon since 2004. Once i was visiting MN and driving my brothers pickup, and had to fill it up. For what ever reason, I was just an idiot. Managed to spill gas everywhere...
    Also I was traveling in Toronto once, and it took me for ever to get the pump started. Just couldn't get the damn thing to pump. And I had to get help from the attendant. Felt like a real #winner!!! DOH! Oregon really needs to drop this law.
  12. Offline
    rlalford New Member
    Mar 14, 2012
    31
    Durham, NC
    Your Vehicle Year:
    Filled my tank on 6.11.12 after 545 miles -- 9.69 gallons, with a second click.
  13. Offline
    chrispdx New Member
    May 21, 2012
    Portland, OR
    Your Vehicle Year:
    It creates good low-wage jobs for people who really need them, and doesn't markedly raise the price of gas for the consumer vs. the prices at neighboring states (due to slightly lower gas taxes). Oregon will never do away with this, just like they'll never approve a sales tax.
Share This Page
