Fully Charged HV Battery==No Regenerative Braking?
Discussion in 'Gen 2 Prius Technical Discussion' started by Oldwolf, Apr 27, 2011.
  1. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
    I’ve searched for an answer to my question but have not found it yet.
    When the HV battery becomes fully charged, which might happen when driving down long mountain grades (that can continue for many miles), what happens? Does the computer just cut off regeneration so you “feel” a loss in regenerative braking?
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    You should switch into B mode (on the stick with D, R, N) for engine braking. This will help prevent overheating/overcharging of the battery pack (EDIT: last bit is wrong, see post #6) when it reaches the computer-imposed 80% state of charge limit. It will still feel like regen braking, but instead of taking that energy and putting into the battery, the engine throws it off as heat.
    You can still drive normally in B mode, too, accelerate, etc., just the braking is different.
  3. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    When the battery is fully charged (80%), it then cuts to friction brakes. The transition is pretty seamless. When in B mode, it spins the engine as an air pump just to waste energy it captures from regen. That way it doesn't go into the battery.
    The car is extremely careful to protect itself. You cannot kill it. If the terminator was in a Cars movie, it would be a Prius. (With a slight personality change from "death to all" to "look at the fuzzy wabbit").
    I live on a mountain and every morning I start with low SOC and end up fully charged by the time I get to the town's elevation. I don't really notice the switch from regen to friction only when it fully fills up.
    Data Daedalus likes this.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The ICE will also spin up to draw off energy when in D. You don't have to be in B, but it helps when going down a long hill.
    thetuningspoon likes this.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Agreed w/firepa63. I frequently hit soc above 75% (as indicated by ScanGauge, looks like all bars filled on the MFD) while going downhill to get home and the ICE automatically turns on while in D, even at speeds <41 mph. Sometimes, the revving gets pretty high too, say over 3000 rpm.
  6. richard schumacher
    7,663
    1,038
    United States
    The reason to shift to "B" on a long downgrade is to save the friction brakes, not the battery. (The battery takes care of itself perfectly under all driving conditions.) And that's not just a matter of conserving the brake pads: it is possible to boil brake fluid, in which case you will have no brakes.
    Don't use "B" when not on a long downgrade because it will only reduce fuel economy.
    usnavystgc and mikewithaprius like this.
  7. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    We drive up and over Blood Mountain here in GA a few times a year and the first time you use B it can kind of freak you out when you are slowing down but the engine starts revving higher and higher.
    It works like a charm though, I love it.
  8. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Is there any other way to use this energy productively rather than let the energy get thrown away spinning the engine?
    I was thinking that maybe if it was hot and you were using the ac minimally to improve mileage and you saw a full battery before a long downhill you could go to max ac and then you could reduce the ac later. Not sure if the ac uses enough to have an impact, but I'm just throwing this out there... wonder if there are any other possibilities?
  9. fuzzy1
    10,039
    Yes on the AC, because at this point, it is free. Just like going into 'B' mode, I switch it on before the battery fills.
  10. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Good idea... I think. Problem is, it's so cold in the Seattle area that AC is of no benefit other than to dehumidify.
  11. fuzzy1
    10,039
    Fortunately most of my long mountain descent experience has been in warmer seasons outside of Seattle.
  12. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Even in cold climate, the HV Battery gets heated up with frequent charging and discharging. So there is still benefit to use A/C for the longevity of battery life.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    True... I do have HV battery temp XGauges set in my Scangauge so I'll check them more closely but err.. it's pretty cold for the driver already. I'm using the heater!
    Here's is our forecast:
    KING5.com | Seattle Weather Forecast Maps
    50 F = 10 C and 39 F = 3.9 C
  14. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
    To summarize:
    When the HV battery is full or nearly full and the car is descending a grade-
    1) The battery on the MFD turns a Salmon color.
    2) The computer starts to use the engine for a higher percentage of braking.
    3) When the engine cannot provide enough braking (RPM limited perhaps?) the friction brakes are utilized to some degree.
    Do I have the sequence correct? The automatic use of the friction brakes would requires some sort of temperature measurement to avoid overheating the rotors/drums. What am I missing?
  15. richard schumacher
    7,663
    1,038
    United States
    The car never automatically applies the friction brakes, that's up to the driver. The car will use more engine braking sooner when in "B" than in "D". Shifting is also the driver's responsibility, the car will not shift itself.
  16. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Salmon Color? Mine just goes to full green. (8 bars.)
    What's with the Salmon thing, has anyone else seen that?
  17. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
  18. uart
    uart Senior Member
    4,215
    1,200
    Australia
  19. theforceprius
    theforceprius Junior Member
    25
    Everett, WA
    So it sounds like my engine racing after decending a hill with a full battery is normal. how do you shift into B while driving? Or should I shift into nuetral to save the power?
  20. dolj
    dolj Senior Member
    7,487
    3,763
    Wellington, New Zealand
    Yes.
    Move the gear selector to B
    Definitely NOT.
