1. Offline
    Blind Guy New Member
    May 17, 2009
    Message Count:
    354
    190
    Springfield Missouri
    Your Vehicle Year:
    To Those Who've Owned Both a G2 and G3;
    Toyota's Press Release of Jan. 12, 2009 says "a newly developed electronically controlled Regenerative Braking System has been adopted, with Control Logic optomized to enhance regeneration".
    Is there a difference between the quality and affectiveness of their respective brakes (since the G3's are 4-Wheel Disks), and their regenerative braking systems, is the G3's stronger, touchier or more responsive etc....or is the G2's better?
    Curious
    David (aka Blind Guy)
  2. Offline
    Feb 26, 2007
    Message Count:
    7,431
    983
    Carmichael, CA
    Your Vehicle Year:
    I don't have a G3, but its important to remember that the regenerative braking only works on the front wheels - it is the retarding force created by MG2 that slows the car during regenerative braking. So the type of rear brakes (drum or disc) have no influence.
    1 people like this.
  3. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    dogfriend, that's true up until the driver demands more force than regeneration can provide (quick or emergency stops). I've found braking in the G3 much improved in those situations.
  4. Offline
    Feb 26, 2007
    Message Count:
    7,431
    983
    Carmichael, CA
    Your Vehicle Year:
    Yes, but that's friction braking, not regenerative.
    I can believe that the G3 friction braking is better or that the regen braking has been improved in some respects, but the rear brake type (disc or drum) can't have any effect on regen braking.
  5. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    It looks the 3G Prius regen braking is more efficient than 2G one.
    I saw seven regen marks on the G3 and we saw max three and a half on the G2 in 5 minutes.
    Had anyone seen more than that on the G2?
    Ken@Japan
    [IMG]
    [IMG]
    4 people like this.
  6. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    Wow, 7 regen cars. That's 350Wh. I have never seen it in my 06 Prius.
  7. Offline
    CtrlAltDelete New Member
    May 6, 2009
    Message Count:
    Daphne, AL
    Your Vehicle Year:
    My wife has an gen II and I have a gen III. In the few weeks that I've had my gen III, its much easier to regen. Taking the same trip in both cars, I can easily double or triple the amount of energy captured with the gen III compared to the gen II. This is just from normal driving; and its just something I noticed one day when I saw all the little cars staked up.
  8. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    I think the higher RPM of MG2 (despite it's smaller size) thanks to reduction gearing allows for more effective (read MAX) regen up to a lower speed. I've seen more regen on my bars as well.
  9. Offline
    mosttoysrk New Member
    May 30, 2009
    Message Count:
    Bellevue, WA
    Your Vehicle Year:
    It is interesting how different the G2 and G3 cars feel (at least for me) when you coast. The G2 Prius creates an immediate drag sensation when you coast almost as if you downshifted in a normal car. The G3 just glides like crazy without slowing down, when you gently touch the brake on the G3 you see the regenerating scale increase.
    This is probably why the pulse and glide technique works on a G3 vs not so much on a G2.
    I tend to gently touch the brake pedal if I want to obtain the largest regenerative effect in a G3 where you didn't have to do this in a G2.
  10. Offline
    Judgeless New Member
    Jun 30, 2009
    Message Count:
    1,489
    149
    Cleveland, OH
    Your Vehicle Year:
    It would be great if the display gave feed back when you are using friction braking compared to regenerative. It would make me lighten up on breaking. It would also generate more energy and save on brake pads.
    I do not own a Prius yet and the car might already do this.
  11. Offline
    wfolta New Member
    Jun 13, 2009
    Message Count:
    290
    51
    Washington DC
    Your Vehicle Year:
    I've asked about this but got no answer. My hope would be that friction braking begins at the far left side of the "CHG" section of the main display, but no one's confirmed this for me yet.
    So I generally try to brake -- when I have the option -- so that I see a tiny bit of gap in the CHG section. I'd love to know the answer, but unless it comes from a factory manual I don't see how anyone could test it.
  12. Offline
    Jun 30, 2009
    Message Count:
    1,489
    149
    Cleveland, OH
    Your Vehicle Year:
    It would be even better if you could feel it in the brake pedal. As you press the pedal down it would be smooth until you pressed hard enough to start using friction brakes. The pedal can give a slight knock as feed back to tell you friction braking has started.
    Most highway braking is because traffic is slowing down. If you keep clear distance you could use regenerative braking most of the time.
  13. Offline
    DetPrius New Member
    Apr 24, 2009
    Message Count:
    534
    82
    Southeast Michigan
    Your Vehicle Year:
    Came looking for the same answer Judgeless and wfolta are looking for but it looks like nobody knows yet. I can't feel when the friction brakes are kicking in, if I am pressing hard enough at times to cause them to engage. I also wondered if it was at the point the CHG area is filled while braking. Would really like to know this one...
  14. Offline
    wfolta New Member
    Jun 13, 2009
    Message Count:
    290
    51
    Washington DC
    Your Vehicle Year:
    Still no answer. :( Personally, I think the HSI display needs two more indicators:
    * A red circle to the left of the CHG area to let you know you'd gone into friction braking.
    * A "bullseye" where the ECO indicator is (useless, redundant indicator) where the center indicates that the engine is spinning, and the outer circle indicates cylinders firing.
  15. Offline
    FlipStylee270 New Member
    Jun 5, 2009
    Message Count:
    39
    New York City
    Your Vehicle Year:
    Is it better to see 10%-20% CHG bar at for a lenght of time, or 70-80% CHG for shorter... Meaning, is it better to brake early, where theres really not much braking but just regen braking, or shorter brake distance with 80-90% CHG?
    Does each wH cars equal to 1 bar in the recharge?
    If I'm on EV and use up 1 battery bar, how many cars does it take to bring that 1 bar back, like "recapturing" energy?
    Thanks in advance!
    (This is out of topic, but if we somehow placed prius on a Dyno that would simulate a regen glide, would it be the same as plug-in vehicle?, wouldn't it be nice if the traction battery would be charged before you roll out of the garage using this silly method?)
  16. Offline
    clooch New Member
    May 31, 2008
    Message Count:
    26
    Auburn, Maine USA
    Your Vehicle Year:
    imho the gen lll is touchier upon regen, it seems harder to glide as well.
    this is my $ .02 worth :D
  17. Offline
    Vincent Don't Wait Until Tomorrow
    Sep 5, 2005
    Message Count:
    641
    27
    South Florida
    Your Vehicle Year:
    Subjective answer to the original question:
    1. Battery SOC is always higher in my Gen III vs my Gen II.
    2. Brakes feel more responsive on the Gen III.
    There's a much more noticable George Jetson type regen whine when applying the Gen III brakes that bothered me at first, but is now part of all the other "normal" Prius noises that I don't hear any more.
Share This Page
