1. Offline
    Walker1 New Member
    Start a Conversation
    Jan 13, 2006
    905
    FL
    Your Vehicle Year:
    Hi, I raised the tire pressure to 44 lbs. on all 4 tires and gained about 2 MPG on my 2008 Prius. Before that I was struggling to get 48 MPG. I notice no difference in handling or the ride so I will keep this tire pressure. :)
  2. Offline
    Matt Herring New Member
    Apr 28, 2009
    421
    50
    North Andover, MA
    Your Vehicle Year:
    Pulse and glide is magnified by the increased tire pressure as it allows you to coast further with higher psi tires. If you haven't been doing P&G give it a try and watch the mpg continue to climb!
    1 people like this.
  3. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,328
    1,767
    Queens, NY
    Your Vehicle Year:
    Yup, with nice and sunny weather in FL.
  4. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,464
    378
    Your Vehicle Year:
    What was the original tire pressure before you changed it to 44?
  5. Offline
    fiftyplus New Member
    Apr 16, 2009
    Your Vehicle Year:
    44 sounds kind of high, that's 10 more psi than what I use. But if your tires aren't blowing up, I supposed I could go up a little more. :p
  6. Offline
    Mar 25, 2009
    2,464
    378
    Your Vehicle Year:
    If you search the forum you will find some people use much higher pressure than 44 psi. :eek: I won't risk that myself though.
  7. Offline
    spitinuri Member
    May 23, 2008
    309
    Your Vehicle Year:
    Very true! I'm currently running 52/50 psi front/rear.
  8. Offline
    Blauer Glimmer New Member
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    Upped the tire pressure on my 2009 Touring to 42/40 to see if I could improve mpg, but can't tell yet (only 100 miles into the tank). Since the suspension on the Touring is already stiff, I am now noticing every pothole left by a nasty upstate NY winter :(
    I'll try it for a few tanks, but I may have to lower it a bit to preserve some costly dental work.;)
    1 people like this.
  9. Offline
    nooaah New Member
    May 8, 2008
    381
    Philadelphia
    Your Vehicle Year:
    Tire pressure definitely raises MPG if you're even a novice driver (i.e. don't accelerate at a good rate, don't gain extra momentum before hills, don't P&G at all). I get in the low 50's doing all the right things with stock pressure and I gain about 3-4mpg by hopping up to 42/40. This also depends on terrain, so your gains may be lower or higher than that.
  10. Offline
    ETP Ancient sloth foot
    Apr 12, 2009
    566
    Crestview/North Florida
    Your Vehicle Year:
    Keep me posted. I too feel these ultra low profile tires are not designed for very high pressure. With 44 PSI on all 4 and getting around 56-57 MPG with good gas. Gas makes a big difference as I got a tank of gas that had too much ethanol in it and it went down to 54MPG. Whoever thought up making gas out of our corn should be %^^&&*^%^%$$. We need electric cars not cars that use fuel that hoses the mileage. Pile of idiots eh!
    These views do not reflect the views of the management:D
  11. Offline
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    You are getting terrific mileage, though. I have not been so fortunate. Last tank was 43 mpg (on the MFD and by calculation). I forgot to reset the MFD when I filled up this time (first time on higher tire pressure). I am now at 44 mpg, so I figure I've probably upped my mpg by about 2. I'll find out when I refill later this week.
  12. Offline
    nooaah New Member
    May 8, 2008
    381
    Philadelphia
    Your Vehicle Year:
    How so?
  13. Offline
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    When I compute miles traveled/gallons purchased.
  14. Offline
    nooaah New Member
    May 8, 2008
    381
    Philadelphia
    Your Vehicle Year:
    That rarely is accurate with this car because of the fuel bladder, though it could give you a decent ballpark figure.
  15. Online
    boppo Active Member
    Mar 11, 2009
    673
    93
    Owego, NY
    Your Vehicle Year:
    I don't think my 2006 has a bladder problem cuz I get down to the last pip before it blinks and I have added 11.611 and 11.625 on the last 2 tanks. I figure that I can do the math gals into miles a get a spot on MPG reading.
  16. Offline
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    On the last tank it was just about spot-on, but I know that isn't always the case.
  17. Offline
    mingoglia Member
    Oct 25, 2007
    845
    Gilbert, AZ
    Your Vehicle Year:
    I feel for you people in other areas when it comes to fuel economy. In the phoenix metro area not only do we not have cold temperatures but all the stop lights are timed pretty good, the majority of our area is in a grid, and the stop lights are about a mile apart. I really have to purposely drive bad to get under 50mpg year round here... unless I have a super prius for some reason. ;) My pressures at 42f/40r and it's a non-touring. In the summer I'll usually go between 500-550 miles on a tank before filling up. My normal commute consists of 63% on a freeway with a 65mph speed limit. I normally drive about 72-75.
  18. Offline
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    The Touring takes a hit on mileage, but I knew that going in. It has been relatively mild, though the early mornings are chilly, since I bought my Prius, which is garaged and not subject to extremes anyway. There is no such thing as flat ground and few straightaways around here, though, so I don't expect to get some of the amazing mph's I've seen around the board.
  19. Online
    boppo Active Member
    Mar 11, 2009
    673
    93
    Owego, NY
    Your Vehicle Year:
    I am moving back to Owego to take care on my mom, will be putting my prius in the garage in the winter - just can't deal with the salt. I see your from the tier.
  20. Offline
    May 2, 2009
    294
    NY (Southern Tier)
    Your Vehicle Year:
    Yup. I'm in Horseheads and travel to Corning for work every day. My Prius will be going through the salty winter - we've never gotten into the "winter pig" habit. Hoping the finish can take it. Our 7 year old CRV looks pretty good, and we didn't have a garage for the first few years of its life.
Share This Page
