1. Offline
    beauimoto New Member
    Jul 27, 2009
    Message Count:
    Vancouver
    Your Vehicle Year:
    Why does the gas milage to gas station reduce still when the engine us not running in the 2010 model? I use it in non gas mode and it still reduces the gas bars even when the engine isn't on?
    Anyone have any ideas?
  2. Offline
    TangoPapa Sun-Th Prius... Fri-Sat Supra
    Jul 22, 2009
    Message Count:
    Huntington Beach
    Your Vehicle Year:
    The engine still needs to be used under various conditions. The engine isn't constantly on but if you're inside turning on the lights, or nav, or AC then the car will run the engine to power up so as not to drain the battery. EV mode will just allow the car to rely the least on the gas engine.
    1 people like this.
  3. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    How do you know the engine isn't on? Are you using ScanGauge?
    Tom
    1 people like this.
  4. Offline
    jim256 New Member
    Jun 18, 2009
    Message Count:
    307
    67
    Eastern NC
    Your Vehicle Year:
    If you mean distance to empty, it's based on your average consumption according to the manual, which is not changing that much as you drive.
    1 people like this.
  5. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    The 'Range' feature uses the average consumption, and calculates based on fuel left. Let's say that you still have 100 mile range on the car, and then drive 10 miles, downhill, never needing the engine to turn on. At the bottom of that hill, your range should now indicate 90 miles to empty. This does not mean that you will only have 90 miles left, and any more than you would have had 100 miles when at the top of the hill.
    It simply generates a number based on total fuel economy, and sense that you will have xx range left. This accounts for the 50% of the time that the ICE is on, and cycling off. If you were to run downhill another 100 miles (not possible to my knowledge), then while the range will show 0 (or less then when you started), you will still have enough fuel in the car to drive quite a ways.
    1 people like this.
Share This Page
