Gas mileage decline since hitting curb
Discussion in 'Gen 3 Prius Technical Discussion' started by rtlt, Jul 29, 2011.
  1. rtlt
    rtlt New Member
    surprise, az
    During May our car hit a curb hard enough that both tires on the drivers side had to be replaced ( flat and a bubble). At the time, the technician tested the car for other damage and found none---- other than needing to be realigned - which he did. Since then, the gas mileage has declined and seems to be getting worse.
    Prior to the incident, we had been averaging about 53 mpg with better mileage in good weather and a little less in the heat of the summer. After the incident, the mileage seemed to drop to about 47-48 . Then in June the car was due for 20,000 mile service which was done and no problems found. Oil was changed and airfilters checked ( they had been replaced at 15,000 miles). Since the service, the mileage hasn't improved and seems to be getting a bit worse --last couple tanks down to about 45.5mpg. There has been no change to car weight, driver style, or avg driving profile. I've tried a couple different brands of gasoline, checked air pressure, fluid levels etc.. I've been running the air conditioner in the summer but last year I was getting at least 50-52mpg during the summer. It feels that the car is struggling more in lower gears and not up-shifting as easy. Is there a sensor that maybe got out of line or some other part that could be causing this issue that is not quickly noticable when the car is on the rack ????
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    I'm thinking alignment still off?
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Perhaps he did not aligned it to OEM specs
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Given the amount of dissatisfaction with dealer service expressed in this forum, you should go to a private alignment shop for a suspension/alignment inspection. Are there ANY driving issues, like the car pulls to one side instead of tracking straight or pulls to one side upon hard braking? Does it tend to change direction when you hit a bump or go over a railroad crossing?
  5. rtlt
    rtlt New Member
    surprise, az
    No noticable alignment issues when driving. Wear on tires seem normal and there is no pulling of the car to either side of the road --seems to track straight. Haven't noticed any change when crossing railroad tracks but I wasn't focusing on that -- I will in future.
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    The Pruis does not have a automatic transmission with gears like most other autos have. It has a Continuously Variable Transmission (CVT).
    [ame=http://en.wikipedia.org/wiki/Continuously_variable_transmission]Continuously variable transmission - Wikipedia, the free encyclopedia[/ame]
    If you feel it acting like an automatic transmission shifting gears that could indicate damage to the driveline mainly the transaxle assembly.
    I would also advocate that you have the alignment checked elsewhere and ensure that the rear wheel alignment is checked and within specifications also.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    A 4 wheel alignment check.
    If the dealer only did a front wheel check then the car could be crabbing down the road.
  8. FLteacher
    FLteacher Junior Member
    75
    I wonder if it's the new tires. Were the tires replaced with the same exact type? Often there is a break in period for new tires as well.
  9. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    This may sound silly, and some folks may disagree with me but... go check your oil. If it is at the full line or above, that is your answer.
    good luck
  10. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Generally in the US, this summer has been hotter than last, so perhaps the battery is hotter so the HSD is using less battery and more ICE power which would be consistent with your symptoms. Also, the A/C would be running harder than last year and a combination of the two would result in lower mileage this summer. Hitting the curb could be entirely unrelated.
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Try rotating new tires to the front and old tires to the back.
  12. ryogajyc
    985
    165
    Reseda, CA
    That's not possible; both tires on the driver's side were replaced.
  13. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Yes, so both tires on the left are new, and both on the right are old.
    Rotate the back left tire to the front right. Rotate the front right tire to the back left.
    Use jack stands, blocks and/or the spare tire if necessary to stand in.
  14. ursle
    ursle Gas miser
    1,049
    192
    NH
    Cycle your emergency brake on and off a few times, raise the rear wheels and see if the rear brakes are adjusted to tight, clean your cabin air filter, is it time for a new 12v battery? Check your oil level, 2/3rd's up the dip stick, check the engine air filter, is it dirty?
  15. ryogajyc
    985
    165
    Reseda, CA
    Sorry, I misread your earlier post as swap front and back tires.
    If the tires aren't directional.
  16. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    I've found that my mileage has dropped roughly 4-5 MPG this summer. I was hoping for a gain, but that hasn't happened. It HAS been EXTREMELY HOT and the A/C has been in use constantly, which is what I attribute the MPG loss to. I had averaged around 48.9 MPG for the first 11K miles since January, when it was extremely cold. Ironically, I got better mileage on a brand new engine in the middle of the winter than I'm getting this summer. I'm sure that when the worst of the summer is over and I can stop using the AC so heavily that it'll go back to slightly over 50 again. My summer heavy AC mileage has been around 45, which really ticks me off, but it's been so hot that I don't care ... I HAVE to have the AC on, set at about 74. Even at 74 it runs full bore almost constantly due to the incredible heat we've been experiencing.
    REV
  17. Caug1
    Caug1 Member
    119
    BOSTON
    What type of oil did dealer put in? wrong ,may be.
  18. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    You've seen the video I posted that shows the 10mpg drop when the A/C compressor is running hard. It's no surprise that your mpg has dropped so much. The heatwave that your guys are experiencing leaves your no choice but to run. The A/C hard. Better to stay cool than suffer from heat exhaustion. :)
  19. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Were they replaced with equivalent LRR tires or just any tires that'll drop your mileage like a rock?
  20. Mendel Leisk
    38,243
    +1 on the above.
