1. Offline
    wjterry New Member
    Jun 20, 2009
    Message Count:
    47
    Winchester, KY
    Your Vehicle Year:
    Would anyone have a logical explanation as to why there is a 4 to 5 mpg difference between the indicated mpg on the instrument panel and the calculated mpg based on miles driven vs. gallons at fill up on my new 2010 Prius? Don't get me wrong, I love the car. I just wished the indicated mpg were more reliable.
    Wes T.
  2. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    "Search" is your friend and will help you
  3. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    How many times have you filled? How many tanks of gas are you totaling for your calculation?
    The short answer is that there is some discrepancy between displayed and actual mileage. A bigger factor is usually the variation of full when filling your tank. This introduces short term inconsistencies in your mileage calculations. If you total several tanks the variation should cancel out.
    Tom
  4. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
  5. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    I didn't search or read, buy I think it's as simple as this. Displayed mileage is calculated fuel flow. I bet there is no actual fuel flow measuring device
  6. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Another hypothesis. The fuel flow was based on pure gasoline and fuel containing ethanol has a lower specific gravity and is "thinner". In other words with the only variable being fuel, there is actually more fuel that flows through the injector with fuel containing ethanol than pure gasoline.
  7. Offline
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Fuel flow is calculated by timing the injector pulses, which is how the engine ECU controls the fuel/air ratio. As a result, the volume measurement is very precise, but also each volume is very small. Small round-off errors accumulate over time, producing a slight but consistent error.
    Tom
Share This Page
