gasoline vaporizer kit?
Discussion in 'Prius c Accessories and Modifications' started by formula, Sep 14, 2014.
  1. formula
    formula Member
    320
    32
    CA
    gasoline vaporizer kit? I found some videos on youtube. does it really work?
    I see some people doing this on lawn mower and it works.
    1 gallon of gas = 160 gallon or vapor.
  2. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    I wouldn't try this on a Prius, but you wont have as much at risk if you use it on your mower. You might find it is merely a "money vaporizer".
    GregP507 likes this.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Snake oil scam marketing.
    Gasoline ALWAYS vaporizes before burning.
    wjtracy likes this.
  4. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Vapor would be measured by volume (e.g. cubic feet). Other than that, sounds like snake oil...
  5. ChapmanF
    15,104
    A gallon is a perfectly legitimate volume measure. Other than that, sounds like snake oil...
  6. Torvic
    Torvic New Member
    2014 Prius c
    The guys over at Jalopnik have a good write about about this video. I'm unable to link it, because I'm a noob here! Basically....BS.
  7. GregP507
    GregP507 Senior Member
    3,002
    480
    Vaporizers are nothing new. I remember reading an article about them in Popular Mechanics or a similar magazine over 40 years ago. Boiling the gasoline and blending the resulting vapor with air causes rapid detonation problems, which causes excessive strain on wrist-pins and crankshafts. An entirely different engine design would be required.
    The Honda CVCC engine was a partial step in that direction; it burned a lean mixture in the combustion chamber, but it was buffered with a richer mixture in a secondary chamber, which absorbed the shock of rapid detonation. As computer-controlled fuel injection became common, the advantages of the CVCC became less relevant.
    Before the diesel engine was widely adopted in the US, internal combustion engines were equipped with vaporizers to allow them to burn fuel oils such as kerosene. The early Fordson tractors were so equipped. Diesel engines subsequently proved to be a more practical way to burn such fuels.
    #7 GregP507, Sep 14, 2014
    Torvic and Ecobill like this.
  8. mahout
    mahout Active Member
    655
    116
    NC
    Its not worth the effort. Even in a carburator the fuel is metered into the air stream as a tiny stream of liquid that is fragmented quickly into a near gaseous state. If it didn't, combustion would be tough to get. The process is not as good as fuel injection where the liquid at high pressure is very well injected as a gas into the air stream.
    You might get an increase in mpg for changing to gas injection in a lawn mower carb but the change in jet size and control of injection pressure is a bit complicated. In essence its changing a lawn mower from metered pulling liquid into the airstream to pressurized injection, which, by the way your Prius already has.
    It has no benefit, and lots of drawbacks, for the Prius.
  9. bisco
    48,985
    a lot of negativity here...
  10. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Scam product -> negative response
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Oldest scam in the automotive market!
  12. formula
    formula Member
    320
    32
    CA
    I got my answer. thanks.
    same as the HHO thing.
  13. GregP507
    3,002
    480
    "You can feel it working!"
    ztanos likes this.
  14. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    He should add flames... don't they add 50 extra horsepower.
    Super Mario likes this.
