Gear Shift Problem Stuck in Neutral
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jpk1102, Jul 18, 2010.
  1. jpk1102
    jpk1102 Junior Member
    2018 Prius
    OK, I read a couple posts on Gear Shift switching back to neutral. Here is my situation.
    Got in the car to return some movies and realized I left them on the table. Went back to the house, and right before I turned into the driveway, noticed a metal coffee cup had come out of the holder and the edge was up under the accelerator. I had been applying my brakes to slow for the turn into the driveway, then when I went to accelerate, nothing, then noticed the cup.
    Removed the cup and stepped on the gas to go into the driveway. Nothing. Turned the car off, then back on and tried to put into drive, goes a tiny bit then slips back into neutral. Tried it in reverse, same thing, pops back into neutral.
    I can hold the shift lever in position and the car moves. It's in the driveway now and will get towed to the Toyota dealer tomorrow. Obviously a problem with the shifter as a result of the "coffee cup" under the edge of the accelerator. And yes, I know it's dangerous, hubby used the car last on his visit home this weekend and apparently the coffee cup either got put down on the floorboard or was knocked out. I had no idea, and I bring it in the home when I'm done.....anyway.
    So, hubby is out of work and money is tight. I will have to have the Toyota dealer fix this, but I don't want to get taken to the cleaners. Anyone here have any idea if the most likely cause was the spring talked about in other posts breaking, or a switch sticking or what. Seems like something got knocked or shifted out of adjustment. Does the accelerator have some type of cut off switch if something gets lodged under it?
    Any info is appreciated as to what may be wrong and how much I should be prepared for?
    BTW 2008 Prius, 76,000 miles, had the transaxle fluid changed at 67,000. Everything has been working fine till this.
  2. jpk1102
    2018 Prius
    Oh yeah, forgot to mention it is HOT today. I saw that was a factor in the other reports.
    So, least possible thing wrong? Any info is appreciated as to what may be wrong and how much I should be prepared for?
    Also, will it hurt to hold the lever in "D" and drive it vs. having it towed?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The coffee cup under the accelerator is in no way connected to the failed shifter switch, unless perhaps you banged your head on the shifter trying to get the cup loose.
    All you have is a failed shifter assembly. It is nothing more than a magnet and some Hall Effect switches. One of them must of died in the heat. Yours wouldn't be the first to do this.
    Tom
  4. jpk1102
    2018 Prius
    Update: Went out this morning expecting to have to hold the shift lever in "D" to drive to the dealer. The car is shifting fine. Dealer couldn't take it till Thursday so it is back home with me.
    After reading other posts, I'm thinking this could be heat related - either warping the plastic cover on the gear shifter unit, as you say heat damage to one of the Hall Effect switches, in the shifter assembly etc.
    But I'm going to post the symptoms I now recollect I've been having over the last 6 months, in case anyone else is having the same problems. They may be an indicator of the same problem I am having and the start of gear shifter failure - might be helpful to know they may have a shifter going out.
    Over the last 6 months:
    1. On occasion, the shifter hasn't "taken" in "D". I've had to repeat the shift sequence when starting up to shift to "D" once or twice and it finally kicks in.
    2. On at least two, if not three occasions on the freeway, I've discovered the shift in gear "B" when I clearly know I put it in "D" starting out. And no, I did NOT bump the shift lever. I put it in "D" to drive, then discovered it in "B", say an hour later. I have no idea how long it was in "B" during that hour.......
    3. This situation last night with the shifter reverting back to neutral when attempting to put it in either "D" or "R". The car would drive if I held the shifter down in "D".
    Thanks Tom for your reply. And Patrick on the other thread I posted on Prius Chat is a great resource, thank you to everyone who contributes.
  5. McMasterc
    McMasterc Junior Member
    Central Texas
    Since Sunday have been experiencing similar strange behavior from my ‘07 Prius that has ~93K miles with no other issues.
    Afternoons when temps in West Texas and New Mexico have been around 99+ and the battery status indicator on the center console display registers 1 purple bar, moving car drops out of gear, goes to neutral. Makes no difference where I am and how fast I am going, happened in parking lots and has happened as I’ve climbed and descended San Augustine and Transmountain Passes during this week's afternoons. Little discomforting… Have not been idling or letting it sit without moving for any period with other systems on.
    After the gear drop, have been able to get it back in Drive and resume after load shedding, i.e. AC, lights and radio off, then restarting car with those systems off. No other power draws that I’m aware of that I can impact. What I mean by this that after the restart I reengage drive and either go slow or coast enough to regenerate and store power in batteries. Another indicator something is amiss is that the letter B in the shift pattern to the left of the speed display disappears.
    Common thread has been high use of AC and low battery. AC performance has not appeared to degrade, no means for me to check other than “feelâ€. Moving around parking lot is not much stress and usually ICE comes on when AC is on and car moves more than 8-10 mph. Dealer maintenance at turn in desk says that there may be something generating a high current draw that drains the battery faster than it can be regenerated.
    Don't see this as a mechanical or switch problem, seems more like some kind of failsafe, but that's only my opinion.
  6. Patrick Wong
    18,198
    6,464
    What would happen if you tried to restart the car without bothering to turn off the AC, lights and radio? My guess is that this would make no difference.
    When the car is operating properly, B will not appear when the gear selector is in either P, R, or N. The fact that B disappears is indicative that the car is in one of those three gear shift positions.
    When the car drops into N, what would happen if you hold the gear selector in the D position? Would the car be driveable? If yes, then that is evidence that the gear selector needs to be replaced.
  7. McMasterc
    Central Texas
    Yes, started the car with lights, AC and radio on, shifted into either drive or reverse, repeated the drop out back to N. Only when I eliminated those loads was I able to continue.
    Held stick in D, holds in drive, moves under power. When I released my hold, reverted to N. Still does not explain why it does this only under low battery remaining indications that occur in "normal" driving conditions.
    I guess what I meant to say is that when the B disappears, it is no longer present on the display, complete blank space where it used to be in the display. Normal for me is that the B and the other positions are visible on the display when the car is in gear and the D is brightly illuminated, in my case the B is flat out "gone."
    I'll go out on limb and say that changing out shifter may be treating symptom vice the cause.
    Appreciate the feedback.
  8. qbee42
    18,058
    3,073
    Northern Michigan
    If it's only a shifter problem, then holding the shifter in D should make everything else work okay. If you have low battery problems even with the shifter in D or Park, then most likely you have a HV Battery issue or an Inverter issue, where it is not charging the HV Battery.
    Tom
  9. jpk1102
    2018 Prius
    Here is the update on my gear shifter problem. Brought it to the dealer for my appointment this morning. Of course I noticed that my left front headlight had gone out (car is 2008), so of course that is $75. Guess I should feel lucky my car doesn't have the expensive HID lights.
    Back to the shifter, the service advisor just called and the shifter is bad. I asked him what was wrong and he tells me they found a "sticky" substance in/on it. I asked how that was possible as it was a sealed unit. He said it's not completely sealed and something got spilled on/near it. I said HOW could something be spilled on or near it if it is mounted on the dashboard. I have never had liquid or any kind on or near the dashboard. I don't open sodas, etc. in the car where some stray spray could magically just go inside the shifter opening without going anywhere else, hahaha. So no way anything sticky came from me.
    He said, they've seen it before and that is what it is: sticky substance. So, that leaves two possible options:
    1. It's something that Toyota failed to clean off in manufacture.
    2. The VERY, VERY remote chance that when the car was at a carwash in all of two times in two years, they used spray cleaner to clean the dash and somehow sprayed it into the gearshift opening. Guess this COULD be possible, but I think highly unlikely.
    Cost to repair $699. for the shifter, plus $75. added bonus of the headlight.
    Hope the headlight going out was just normal wear and not an indication of a "battery" issue like poster above his having.
    So, just thought I would post so everyone knows about this sticky substance getting on the shifter and causing failure. Be really, really careful not to get anything near that shifter opening.
    I have asked for the old part to be returned to me so I can inspect it. I want to see the "sticky" substance firsthand. Any of you experienced members want a look at it?
  10. Patrick Wong
    18,198
    6,464
    I don't doubt that your shifter had failed, and you'll recall that I had encouraged you to DIY replace it in another related string. However I really doubt that the failure was due to a sticky substance that was introduced into the mechanism from the shift lever opening.
    If that was true, then you should notice some difficulty in moving the shift lever from the resting position to the various shift positions. I don't believe that you've reported this to be the case.
  11. jpk1102
    2018 Prius
    No, there was no real difficulty shifting it - sometimes it wouldn't "take" the first time and I would have to repeat the process, but not very often. I have a call into the service advisor as I want to ask a few more questions and make sure they know I want the old part.
    They didn't have the shifter in stock so had to order it. I won't have my car back till tomorrow.
    I know the DIY was a better option, if I had someone to do it that would be great. But I don't. i'm going to ask the Service Advisor how much was part and how much was labor.
    AND more about the sticky substance......
  12. absassoc
    absassoc Junior Member
    Umina Beach NSW Australia
    Had a somewhat similar problem in my 2004 Prius which went into neutral on a freeway off ramp and I just had enough momentum to run clear however the Park button wouldn't work either. There were no alarms, the ScanGuauge showed no fault codes, water temp was 85C and 12V bettery voltage 13.7V - don't remember the traction battery voltage - and rebooting did no good until, after about 20m a last reboot let it go into Drive (5m before the tow truck arrived) and it has now behaved faultlessly for the last 100km. Car has done 77 000km and has been a joy to drive for the 2 1/2 years I have owned it; apart from the 12V charging voltage does not seem enough to keep the 12V battery fully charged without an external top up about one a month - current battery is sealed type with gassing vent and ~8 months old.
    AB-S
