Gen 2 lift gate garnish replacement (cheaper options?)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scotty Danger, Sep 9, 2014.
  1. Scotty Danger
    Scotty Danger Junior Member
    86
    Scottsdale
    I opened the trunk the other day, and the thing ripped out in my hand. I felt cool for a second (pretended I had super powers), but the high ended abruptly when I saw the replacement costs (averaging 220 - 250 plus shipping).
    Does anybody have any sources that offer this part at a cheaper price? I have a black 2007 and need the lift gate w/ Smart Key integration, part # 7680147060C0
    Thanks in advance for any leads!
  2. dpeverhart
    dpeverhart Member
    126
    23
    I
    Mine broke off and I used epoxy putty from JB Weld to hold it in place temporarily until I could procure a replacement. That was 4 months ago and it's still holding up. It just might be a permanent solution.
  3. Scotty Danger
    86
    Scottsdale
    Hmm good advice! My only worry is - if I epoxy, will I be able to access the license plate lights / trunk switch if necessary in the future?
    The epoxy solution is tempting - two of the plastic pieces are broken, but the other 3 or 4 are in tact. Thanks!
  4. dpeverhart
    dpeverhart Member
    126
    23
    I
    The way I did it you would still have access to the license plate lights. If I remember correctly I placed the broken studs back in their original positions and formed the epoxy putty around the plastic where it broke. Once it dried I put it in place and secured it with the nuts. I didn't realize when I did it that it would be so solid.
  5. Scotty Danger
    86
    Scottsdale
    Ok smart move ... I'll try the same!
  6. JC91006
    16,470
    8,383
    Remember this epoxy is not heat resistant, it weakens when hot. Best to do a 2 hand operation from this point, press to open with one hand, use other hand to lift from the metal part of trunk.
    I've glued mine and it's fallen off once but with 2 hands it's been holding quite well.
