Gen 4 Staff Manual (In Japanese) =/ Specs/Design/Other Info
Discussion in 'Gen 4 Prius Main Forum' started by E46Prius, Sep 23, 2015.
  1. E46Prius
    E46Prius Active Member
    314
    218
    Costa Mesa
    I wish I could read Japanese. Whats the fuel economy? I'm American and don't know what liters are... too lazy to break out a calculator. Looks like it's using the same engine as Gen 3? Maybe tweaked or same exact engine?? Maybe most, if not all, of the extra MPG comes from aero. Maybe software.
    2016 Toyota Prius details leak in manual, returns 40 km/L
    inferno, giora, iplug and 2 others like this.
  2. priusfan500
    priusfan500 Member
    94
    110
    It also included the first decent view of one in white. Screen Shot 2015-09-23 at 1.34.37 PM.png
  3. E46Prius
    314
    218
    Costa Mesa
    It looks nice. I'm starting to like the rear end more than the front now... at first it was the opposite. The front looks a bit unfinished/rushed.
  4. priusfan500
    priusfan500 Member
    94
    110
    December 2015 Debut. I'm guessing that will be the on sale date in Japan, as it's sure to be shown at the Tokyo Auto Show next month.
  5. E46Prius
    314
    218
    Costa Mesa
    Someone translate this please! I want to know what the above picture says. Anything on torsional rigidity? Or amount of high strength steel used (percentage) vs outgoing model?
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Not sure if the illustration is exaggerated or not but Gen4 center of gravity is much lower.
  7. inferno
    inferno Senior Member
    1,072
    405
    Can't be the same engine/system. Patents for the GIII expired so we should see very close MPG in the next 5 years.
    And I thought Toyota said it's a brand new Synergy Drive System!
  8. E46Prius
    314
    218
    Costa Mesa
    The article is quoted as stating the same engine code designation as the gen 3
    KrPtNk likes this.
  9. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    I think patents from Gen1 expired which includes how PSD combine and split power.
  10. Tideland Prius
    16,066
    60% increase in body rigidity over the previous gen Prius (red & pink dots). You can see the other cars listed. The Japanese names are as follows: 2005 at same body rigidity as previous gen Prius - Auris, 2005 at slightly higher rigidity than CT200h - Corolla and the one between GS and Golf Mark VII is the Camry.
    The description below and the picture describes the technique of "Laser Screw Welding" or LSW that's employed in Lexus vehicles.
    Here's an English description:
    Engineering innovations: laser screw welding - Lexus
  11. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Wow, more rigid than the latest Golf. Gen4 is a huge upgrade not only in fuel economy.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    lots of interesting info there.. for instance white seats look great and much better design than anything in Prius (or most Toyotas) before.
    Also 2.9cm more headroom at the back, and a lot more trunk space too. All LED lighting, automatic parking, best safety sense system, trunk 11cm lower to the ground before. Weight is 10kg more than before. A lot of points of the car are significantly lower to the ground, including seating position.
    Still missing a lot of things too... like HUD details, AWD details, system output, etc, etc.
    usbseawolf2000 likes this.
  13. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The consumtion vary between 83-90 mpg according to car's spec and tyres.
  14. spwolf
    3,156
    440
    Eastern Europe
    thats on unrealistic japanese cycle... it is going to be 10% better in the USA and 18% in unrealistic EU cycle.
    pakitt likes this.
  15. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    That would be 10% worse?
  16. Trollbait
    11,316
    Over EPA of old model, I believe.
    JC08 of the gen3 is roughly 40% better than the EPA.
  17. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    It's amphibious!!!
    roflwaffle and Cozynest like this.
  18. Trollbait
    11,316
  19. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    To facilitate forward-facing sonar, Toyota has embedded a live dolphin in each Prius. The horn is a little squeakish, though.
    cyclopathic likes this.
  20. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    All the cubbies that you thought were missing in the 4th-gen actually has been consolidated into a first-in-industry dedicated cetacean storage space for the ultimate in ecological awareness. No longer will you have to suffer the indignity of struggling with a loose porpoise in the cabin. Fully enclosed, your marine mammal will be kept moist and also be protected from both prying eyes and tempting thieves.
    Moist. So moist.
    #20 DtEW, Sep 25, 2015
