1. Offline
    elendilmir New Member
    May 13, 2008
    Message Count:
    70
    western maryland
    Your Vehicle Year:
    2002 Prius
    There seems to be very little discussion of older battery life. I just passed the 105K mark, so it's starting to weigh on my mind. Is this being discussed somewhere that I'm not seeing?
  2. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    The reason for no serious discussion is the absence of hard data.
  3. Offline
    tochatihu New Member
    Apr 10, 2004
    Message Count:
    3,164
    346
    Kunming Yunnan China
    Your Vehicle Year:
    2001 Prius
    Some of these failed quite early, which probably led to Toyota's special service campaign to reseal the modules to the elctrolyte inside wouldn't leak out and corrode the connections. Did yours have that work done? It's free.
    Some have lasted for more than 300,000 miles in service. Overall failure rate of perhaps 1 to 10%? Known to Toyota; not to us.
    Other than SSC 40G (above) there is not much you can do to help, besides avoiding extremely high battery temperatures. If you're curious, have some money to spend and a good Toyota shop handy, they can measure module voltages during charge and discharge cycles.
    In the case of gradual battery failure, some have reported falling fuel economy first, followed by warning lights and very poor vehicle performance. Then, the diagnostic codes identify the battery or some other cause.
    If you don't want to pay for that test, then I suggest you just not think about it until a problem arises.
Share This Page
