Gen III shifter knob in Gen II
Discussion in 'Gen 2 Prius Accessories & Modifications' started by RyC, Dec 5, 2011.
  1. RyC
    RyC Junior Member
    25
    San Luis Obispo
    Hi guys,
    Does anyone know if the Gen III shifter knob is removable or if it will fit onto the Gen II shifter screw? I just think it looks cooler and was wondering if I could switch them out.
    Thanks!
  2. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    I believe they are, both are 6mm threaded. Just unscrew it to the left, it does have thread compound on it to keep from vibrating loose, but it won't hurt to take it off. I had a Gen 3 and replaced it a while back, but had to put back on to trade it in. I see a few are listed on ebay. Can you tell me what color your gen 2 knob is? I have a new 2012 v wagon and want to change it out and need the pattern to show for my wife but need it to be silver.
  3. RyC
    RyC Junior Member
    25
    San Luis Obispo
    Thanks for your help, ill peruse ebay and see if I can find anything. My Gen 2 knob is the stock gray one, looks like this [​IMG]. I've already taken if off to install a new HU, but it sticks back on just fine.
  4. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    RyC any luck? I'm interested in doing the same mod myself. Any news would be appriciated.
  5. RyC
    RyC Junior Member
    25
    San Luis Obispo
    Dave,
    I haven't had the chance to pick up or try out the gen III shifter yet, but I'll post back when I try it out!
  6. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    To answer your question, yes the shifter does unscrew. It is held in place with some thread locker and may seem like your breaking it to be able to unscrew it. As far as finding some?? I would suggest a crashed Prius at a junk yard or google works too.
  7. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Be careful with this change! One day out for a look around I had the portable GPS cable touching the shift knob and the car went to neutral. I could not figure the problem but then I moved the cable and all was well. It seems this nob is sensitive to weight? Hal
