Gen IV Prius Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by usbseawolf2000, Mar 18, 2016.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    To kick off the work for Gen IV Prius, I am starting this thread. To start off, someone need to test to see if Gen III PIDs work with Gen IV (2016) Prius.
    DicedPixel, goldfinger and fr-pt like this.
  2. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    We'll need to identify those that works and I can put them in a CSV file for everyone to use.
  3. telmo744
    telmo744 HSD fanatic
    2,168
    764
    Portugal
    The pic was taken using 3Gen PIDs, so those not zero are, apparently, working. ;)
  4. fr-pt
    fr-pt Junior Member
    Portugal
    Hi there,
    I am a recent owner of a 4th Gen Prius (Portugal/Europe). I was used to using the OBD metrics in the previous 3rd Gen Prius.
    Now, using the OBDLink with the new 4th Gen Prius togheter with the 'Torque Pro' and the PIDs for 3rd Gen Prius got the following, presented for the metrics used more regularly.
    SUCCESSFULY:
    +B Voltage Value(V)
    COâ‚‚ in g/km (Instantaneous)(g/km)
    Engine Load(%)
    Engine RPM(rpm)
    Fuel Remaining (Calculated from vehicle profile)(%)
    Fuel used (trip)(l)
    Horsepower (At the wheels)(hp)
    Litres Per 100 Kilometer(Instant)(l/100km)
    Speed (GPS)(km/h)
    Speed (OBD)(km/h)
    Throttle Position(Manifold)(%)
    Trip average Litres/100 KM(l/100km)
    Trip distance (stored in vehicle profile)(km)
    Trip Time(Since journey start)(s)
    Trip time(whilst moving)(s)
    Trip time(whilst stationary)(s)​
    NO DATA RECEIVED:
    Auxiliary Battery Voltage(V)
    Batt Pack Current Val(Amperes)
    Coolant temperature(°C)
    Difference between maximum & minimum voltage(V)
    MG1 revolution(RPM)
    MG2 revolution(RPM)
    State of Charge(%)​
    Best wishes and I hope you find the correct PID's, at least for those marked with "NO DATA RECEIVED"
    PtPri and Jorin like this.
  5. telmo744
    2,168
    764
    Portugal
    Filipe.
    I brought here your recent pic with the 4 gen to feed this thread (y)
    Is there a way to run a "sniffer" to find valid adresses? The equations could be similar to previous models... (?)
  6. fr-pt
    fr-pt Junior Member
    Portugal
    I hope so.
    I wonder if 'usbseawolf2000' knows how to do it.
    Meanwhile I will try something this easter.
  7. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    I (my mother, I want a used Volt) just got a '16 Prius. Willing to help but don't have training in this area. Working on CS major so it sounds like fun. I have a KW902/ELM327 OBD2 2 bluetooth device and Apple smart device.
  8. Maxwell61
    Maxwell61 Active Member
    384
    237
    Italy
    I don't know if can be useful, but a French Prius owner sniffed the following:
    - ECU works in 7D2 for enquires and 7DA for answers
    - So, no multiframes answers (7E0 - 7E7)
    - Enquires in 3 or 4 octets (no 2 octets)
    - Answers till 260 octets in a new (from previous) format
    - Tons of data potentially recoverable, the guy stopped at 10,000 characters...
    Here the post on Prius Touring Forum (French):
    http://prius-touring-club.com/vbf/showpost.php?p=299252&postcount=10
    fr-pt and telmo744 like this.
  9. fr-pt
    fr-pt Junior Member
    Portugal
    I've made a Scan using Torque Pro on my 4 Gen Prius (european model) for Header 7D2 and ALL the answers for mode 21 get the same response:
    "7DA037F211100000000"
    The only Headers I got several active responses are:
    7C0
    7C4
    7D0
    abramsbrian, Maxwell61 and telmo744 like this.
  10. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
  11. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Anyone crack the PID's? Really wanting to hook up my Bluetooth KIWI today and do some tests.
    telmo744 likes this.
  12. abramsbrian
    abramsbrian New Member
    San Francisco
    bump... I'm also really in need of these codes to read the steering angle.
    I keep getting the "7DA037F211100000000" response as well.
  13. telmo744
    2,168
    764
    Portugal
    Wouldn't it help someone write an email to Scangauge to see if their latest version includes ZWV50 Prius?
    alexgrigori likes this.
  14. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    This post has been relocated here.
    #15 Cave Arnold, Jan 28, 2017
  15. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi fr-pt and abramsbrian,
    From the 7F negative response code, 11 means "Mode not supported". It means mode 21 is not supported by this ECU.
    From Scangauge website, it seems Toyota is using mode 22; i.e. 2 bytes PID instead of the 1 byte offset in mode 21. e.g. 227A76, 227A53, 221093, 221089, 2210AB, etc. 7D2 is the HV CPU as mentioned in post #9 and 747 is the Bty ECU from Scangauge website.
    Below are my direct translation from Scangauge website:
    Name ShortName ModeAndPID Equation Min Value Max Value Units Header
    1 Hybrid Battery SOC SOC 227A76 A*20/51 0 100 % 747
    2 Hybrid Battery Voltage HBV 227A53 C*4 ? ? V 747
    3 Inverter Coolant Water Temperature ICT 221093 A*9/5-40 59 302 F 7D2
    4 Generator Inverter Temperature GIT 221089 A*9/5-40 59 302 F 7D2
    5 Boosting Converter Temperature (Upper) BUT 2210AB A*9/5-40 59 302 F 7D2
    6 Boosting Converter Temperature (Lower) BLT 2210AB B*9/5-40 59 302 F 7D2
    The min & max HV Voltage depend on your HV Battery chemistry, you can fill in yourself accordingly.
    Vincent
    That_Prius_Car likes this.
  16. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Will these work for Gen.IV?
  17. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    You probably should start a new thread for the Prime. Some values could be the same a Gen 4, but the Prime is a little more advanced Some call it Gen 4.5.
    RCO likes this.
  18. richt
    richt New Member
    Seattle
    SO net net is there a csv for gen iv pids yet?
    This forum is awesome and so helpful!!!
  19. Prodigyplace
    11,696
    11,317
    Central Virginia
