1. Offline
    Sergio-PL Member
    Start a Conversation
    Jun 24, 2011
    150
    36
    Poland
    Your Vehicle Year:
    I measure first bar on 5 min consumption bar. If it's at 10 l/100km => cold night, poor result. If 7.5 l/100km => night about 8 degrees, there is a chance for good normal mode result with low heater penalty.
    If about 5.5 l/100km => car is hot (at least +15 deg outside or short break after previous trip) => big chance for 4.7 l/100km for the rest of the trip.
    Now I understand why both Auris and Yaris in user's manual had section "Starting vehicle" split between Germany and other countries. After reading it 3 times I found the difference.
    In DE - start engine and begin travel immediately. In other countries - start engine, wait for 10 seconds, begin travel.
    No startup split found in Prius manual.
  2. Offline
    errantneuron New Member
    Aug 6, 2011
    Los Angeles
    Your Vehicle Year:
    I am very puzzled by the behavior at start-up of my prius. Rokibler's diagrams are very helpful, and somewhat resemble what I encounter, but still are not quite right. I don't have a scangauge, so I have to go by engine sounds and consumption display.
    If the car starts up below 60, it goes into S1a, and follows normal warm-up
    If the car starts above 60, even up to high temperatures (i.e. stopped for 3 minutes immediately after 1 hour on the freeway on a hot day), it goes into a strange other stage that doesn't resemble any of the stages described in this thread.
    Here are some features of this "stage"
    -ICE will only shut off when stopped (resembles S1b)
    -when gliding at any speed, the engine will continue to spin at very low rpm's. the instantaneous mpg will show 99 until speed drops <15 mph or so. the energy flow display shows no grey arrow coming out of the ICE. (not S1b)
    -cannot press EV mode button (even <10 mph) (resembles S1b)
    -doesn't last for a set period of time. If I drive a bit, then am stopped in traffic for a while, it will continue this behavior when the ICE fires again. (resembles S1b)
    -happens at a wide range of temperatures, even very hot. (not S1b)
    -when this "stage" ends, it goes immediately into stage 4. (not S1b)
    So it is similar to stage "4-" that rokibler describes, but it only happens on start-up, and doesn't seem to be temperature- or time-dependent. Additionally, the car never exhibits this behavior at any other time: even if it has been sitting idle for a long time after reaching stage 4, it immediately returns to stage 4.
    What is going on?
    tincmulc likes this.
  3. Offline
    markabele Senior Member
    Mar 27, 2012
    1,315
    177
    Nebraska
    Your Vehicle Year:
    I had this exact thing happen to me about an hour ago. Pretty much just as you described it. The engine was warmed up pretty decent but maybe not fully and I had only shut it off for about a minute.
  4. Offline
    rebenson Member
    Apr 12, 2008
    351
    35
    Suburb of Chicago
    Your Vehicle Year:
    Yesterday I was driving and got "locked" out of ev mode. Guess it was because of heat because none of the other options were valid...
  5. Offline
    telmo744 HSD fanatic
    Apr 8, 2010
    773
    65
    Portugal
    Your Vehicle Year:
    @Errantneuron/Markabele - I believe that is called "idle check". Some 10 seconds approx.
    1 people like this.
  6. Offline
    FrankTiger Member
    May 26, 2010
    47
    70
    Madrid, Spain
    Your Vehicle Year:
    Hi everyone
    With the new design of this forum, the link-backs that were at the bottom of the old design are missing. That is the reason that I make this post, just to tell everyone that wants to know more about the behaviour of the HSD during S1a & S1b stages that there is this thread HSD behaviour during S1a &amp; S1b warming stages | PriusChat
    In that thread, for stationary warm-ups you may find several graphs like those below:
    [IMG]
    [IMG]
    [IMG]
    I hope you like them
    Big hugs from Frank
    bwilson4web likes this.
  7. Offline
    Dan4500 Junior Member
    Oct 31, 2012
    45
    Your Vehicle Year:
    Relative newby: But does the GenIII still have the thermal container to keep the coolant warm? I haven't seen it referenced and some of the postings here suggest cooling overnight, which means they stopped using it. I've looked under the hood and cannot locate anything that would be it.
    By the way I posted a backup camera add-on using a 12 volt camera for the 2012 Two on one of the Gen III Accessories blogs. Less than $30 in parts vs over $300 by add-on dealer.
  8. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,172
    Alaska
    Your Vehicle Year:
    Nope.
  9. Offline
    macman408 Devil's Advocate General
    Mar 21, 2010
    762
    169
    Your Vehicle Year:
    I've noticed a few things that aren't captured in the stages I've seen described - for example, when below 68°C, attempting to glide is a crapshoot as to whether the engine will actually turn off or not - sometimes it will, sometimes it won't, and I don't know if there's an easy way to tell whether it will on a given attempt or not. And then, obviously, above 70°C, it gets to S4, and it's easy to get into a glide. However, something happens in between - once the coolant reaches 68°C, I can glide with nearly 100% success. It's obviously not in full S4 though, because EV is only available to 10 mph. But I've had times where I hit 68°C, then stop for a long stoplight or something, and spend quite a lot of time driving before I hit 70°C, and the behavior is very different from when the temperature is below 68°C.
    And, just a tip for anybody that's taking advantage of all this knowledge for hypermiling... The car REALLY likes to turn off the engine at the end of S1b (usually 40°C) and at 68°/70°C. I pay attention as I'm approaching that point so that a pulse brings me up to that temperature, and then I can start a glide right then, since it guarantees the engine will turn off. (If I start accelerating at 38°C and don't start gliding until 42°C, that works too - the engine will always shut off when I stop accelerating after being ready to go into S2. I just try to avoid hitting 40°C right before I need to accelerate, since then the engine will fire back up and keep running for a while.) Then I try to take advantage of the fact that the engine has shut off to go stealth and use only the battery to maintain speed for as long as possible, as long as the SoC is above 60%. I do that because no matter what I do, the car will try to bleed SoC down to 60%, so I might as well use it up with the engine off. If I need to accelerate from a stop, or up a big hill, or some other large power demand, I'll of course use the engine again - but it's almost impossible to get the engine to turn on just briefly for a pulse (like from 30 to 40 mph) when the coolant is between 40° and 68°C - sometimes it works, more often it keeps running. Taking advantage of these known points where the engine will turn off has been fairly handy for me when hypermiling.
  10. Offline
    srivenkat Member
    Feb 28, 2011
    114
    IL
    Your Vehicle Year:
    Can someone please explain what "idle check ceremony" is and why the Prius needs to perform it every time? Aren't "ceremonies" performed only once in a while? :confused:
  11. Offline
    srivenkat Member
    Feb 28, 2011
    114
    IL
    Your Vehicle Year:
    Also, are the speeds mentioned in this thread the speeds displayed by ScanGauge or on the dash? The reason I was asking is that the dash is like 3MPH higher than that shown by SG from what I heard. Thanks.
  12. Offline
    Mar 21, 2010
    762
    169
    Your Vehicle Year:
    I've always felt that 'ceremony' was probably a dictionary translation from the original Japanese of whoever coined the term. My guess is 'procedure' might be a better term. Basically, I think it's the various actions that the car performs and conditions that must be met while the engine is more-or-less idle. I think in the Gen 2, this had to happen while the car was stopped, while the Gen 3 can do it while the car is gliding.
    The dash, I believe. Certainly for the EV Mode speed limits, so I'd assume the others are as well.
  13. Offline
    srivenkat Member
    Feb 28, 2011
    114
    IL
    Your Vehicle Year:
    This is the behavior I see as well. But this seems to belie the end point at 103F for end of s1b at which point I should be able to glide if it starts between 25 and 45 MPH. Anything I could be doing wrong to be denied the 25-45 MPH glide?
  14. Offline
    tumbleweed Senior Member
    Oct 3, 2005
    3,968
    616
    Eastern Oregon
    Your Vehicle Year:
    I think we all see this behavior from time to time. A couple of things you may already be aware of, the ICE will not shut down if the catalytic converter is not hot enough, another thing that will keep it running is the heater trying to warm up the interior.
  15. Offline
    srivenkat Member
    Feb 28, 2011
    114
    IL
    Your Vehicle Year:
    I was aware of the latter but not the former. Which makes me wonder if certain gas brands could cause ICE/Cat to heat up sooner. I seemed to notice better MPG with Shell "Nitrogen-enriched" fuel. But I am not sure if that's the reason or my fluctuating driving style.
Share This Page
