Going into Reverse by itself...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan05979, May 27, 2015.
  1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    This has happened 4 times already....I go from N to D and the Transmission goes into Reverse by itself????!!! Anyone experience this?
  2. JC91006
    16,470
    8,383
    Why do you go into Neutral?
  3. Dan05979
    Dan05979 Member
    181
    101
    Sometimes at a light, or in traffic I shift it into N on a level grade so i don't have to keep my foot on the brake.
  4. JC91006
    16,470
    8,383
    oh I do the same, but I press the park button.
    I'm not sure why your car would go into reverse, has your car ever been in an accident?
  5. bisco
    48,969
    check your 12 volt health.
  6. Dan05979
    Dan05979 Member
    181
    101
    How do I do that?
    No accidents. I'll keep my eye on it, maybe it's me shifting from N to D too fast?
  7. Mendel Leisk
    38,239
    Do you do this shift frequently? Just guessing you've worn something out. Sitting at a stop in Neutral, no foot on the brake, doesn't seem the best idea, no offense.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Doesn't the ICE stay on neutral? I thought it does. I shift to P at long lights or drive thrus.
  9. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I know of no reason to use Neutral instead of Park at lights, long or short, if the goal is simply to be able to take your foot off the brake. In fact, Park is actually safer because if someone should hit you from behind, Park will minimize the distance your car will move forward. If you use Neutral and someone hits you, it's a free-for-all and you'll be pushed into the car in front of you or, worse yet, into the intersection.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, if you are in Park and someone hits you hard enough to move the car very far the Park locking mechanism could be destroyed.
    I don't recommend using Neutral except for special circumstances (pushing the vehicle in a shop for example, or at some car washes). When in Neutral the battery can't charge.
    I use the foot brake with the car in "D". Once the brake pedal is pressed hard enough to trip the switch (brake lights) the car will shut off "simulated automatic creep". This will result in the most efficient mode to sit at a light.
    If this is too tiring for you I guess I can't help. ;)
  11. bisco
    48,969
    put a digital volt meter on the jump point under the hood.
  12. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Don't use neutral except as noted for special circumstances. If it "really is shifting into reverse" as you say, I would start by looking at the electronic shifter first.
  13. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Neutral is great at an automatic car wash ,,,, but at a red light ?? Makes no sence to put in .N.
    Or Park , keep it in D use the foot brake ,,
    Okinawa and Mendel Leisk like this.
  14. Dan05979
    Dan05979 Member
    181
    101
    I used to be a trucker with an 18 speed stick, N was my "park" at a light with the trailer brake applied so I can rest my foot. I also got spoiled with my 5 series as it has "auto brake hold" which I think is one of the best features on that car.
  15. Maarten28
    Maarten28 Active Member
    414
    223
    Netherlands
    A reason to use N at traffic lights and not park is that you don't have to press the brake pedal to shift into D so it's quicker. A reason not to sit in D at traffic lights is so not to bother the guy behind you with your super bright brake lights. Ok, I know in America it is the norm to have an automatic gearbox so everyone does it, but IMHO it is annoying.
  16. Dan05979
    Dan05979 Member
    181
    101
    Exactly, just a driving habit I have.
  17. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Different strokes, but habits can be changed. :)
  18. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    With your foot-off-brake and neutral method, you must have to watch carefully to be certain the car isn't rolling, as well as shifting into N, then back to D. I don't understand how that routine is any easier than resting your foot on the brake for the duration of a red light. You don't have to press hard.
  19. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    While I agree with what's said so far about just using your brakes as they were intended...
    ...back to your actual issue - when you pull the shifter down to the D position, are you letting it spring back naturally, or do you hold on to the shifter while it returns to the center position? Especially if you let it snap back as one might when shifting in a hurry as the light turns green, it's possible that the momentum from moving upwards from D carries it through the N region and into R, then back into N and over to the central position. The end result would be the car thinking you had shifted to D very briefly, then to R. If you are more deliberate with your handling of the shift knob, it might help.
    Dan05979 likes this.
  20. Dan05979
    Dan05979 Member
    181
    101
    i think I was letting it spring back and it probably it would accidentally go into reverse.
