1. Offline
    linuxpenguin New Member
    Mar 6, 2007
    352
    178
    Your Vehicle Year:
    Hi guys,
    For all you PHEV drivers out there who have gone more than 2 months on a tank, I'm curious how your car (specifically, your remaining gasoline) fared when you went two to three months between fill-ups? Did you notice that more fuel was being burned as the tank aged?
    I drive a Plugin Conversions Corp (PICC) conversion system and I haven't filled up since the first week in August (about 2 months ago today) so I guess I'm towards the end of the shelf life of the gasoline in my car even though I still have 2+ gallons left.
    Has anyone had to use fuel stabilizer to prevent fuel from degrading?
    I know it's probably a lost cause for this tank since the fuel has probably degraded enough already (from what I understand, the fuel becomes significantly more dense as time goes on--I admit I'm relatively ignorant of the fuel aging process and the effects therein). I should probably just use up the remaining fuel or top off my tank (though I'm a little hesitant to lose my tank average data as I'm at 890 miles on ~ 7.25 gallons) here before the average temperature drops below freezing since I'm still running summer blend fuel.
    I'm also contemplating only filling my car up with half tanks from now on since it looks like I end up wasting a bunch of fuel at the end because it becomes more dense--has anyone else thought to do this or any other tricks?
    Andrew
    1 people like this.
  2. Offline
    TheForce Ron Paul 2012
    May 30, 2005
    3,428
    434
    Wheelersburg, Ohio
    Your Vehicle Year:
    I'm also running a tank since the beginning of August. 2200 miles so far and 17% fuel remaining. I plan on running this to 0% which should put me near December before i fill up. I don't notice anything different so far. I'm not too concerned about.
    1 people like this.
  3. Offline
    Mar 6, 2007
    352
    178
    Your Vehicle Year:
    Fair enough. I see you've been using EV-mode quite a bit. 2200 miles on a tank so far is very impressive--that's what, 40 miles a day? I suppose I could just use EV mode all the time and not have to worry about my fuel going bad =). I generally just drive the car normally with the ICE running for the extra acceleration...
    Hmmm...I wonder how many miles I could get on a tank if I drove in EV all the time since my system has the 70 MPH EV mode...
    Anyway, thanks for the post TheForce and good luck with your tank!
    Andrew
    1 people like this.
  4. Offline
    May 30, 2005
    3,428
    434
    Wheelersburg, Ohio
    Your Vehicle Year:
    I run about 22 miles a day. About 4-6 miles is with the gas engine running.
    I guess the best thing to do is get some gas, put it in a sealed container, then wait. Test the gas or have it tested once a month and see when it goes bad.
    I have not seen a good answer on the net on how long it takes gas to go bad. Ive seen 12 weeks to 1 year. Only way to tell is to test it.
    1 people like this.
  5. Offline
    snead_c New Member
    Nov 18, 2008
    606
    45
    Hendersonville
    Your Vehicle Year:
    I always use Stabil in my lawn tractor and mowers...it really is an ounce of prevention worth many dollars of cure. It may help in your auto fuel. Yes, also I'd consider keeping less gas in the car so you'll be putting in fresh gas more often.
    1 people like this.
  6. Offline
    boxer93 Psyched for PHEV
    May 9, 2008
    155
    22
    Southern NH
    Your Vehicle Year:
    I have had no issues with the fuel or ICE. I run 7-8 weeks between fillups. I think of stabile if the gas will sit for months. I think the fuel is always getting mixed while the car is moving. This IMHO would not allow the fuel to separate or degrade easily.
    Chris
Share This Page
