Got my PIP Monday! Initial observations...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by chuckp, Mar 10, 2012.
  1. chuckp
    chuckp Junior Member
    26
    Seattle, WA
    I'm rapidly migrating toward just running the car the way it was designed. Just let the engine run if I want heat or defrost. It's easier and the vehicle still turns in remarkable mileage, which is a major advantage with the current fuel prices. And it holds 4 "size D" adults comfortably!
    It's hard to imagine, but my "old" 2010 had to turn on the ICE nearly every time I powered it up!
  2. gramps
    gramps Member
    179
    36
    San Diego
    Thanks
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I use a disc lock (pic below) at the gym locker (my car keys there!) ....
    These things are more secure because very difficult to get cutters on the pin / shank / throw.
    I don't know if there is a disc lock with tight dimension for the 'plug', but if there is, it would be pretty clean and secure, methinks. The little cable lock above is so easily cut, but will deter casual thief.
  4. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    After I get my PIP tomorrow, I'm going to Home Depot with the cable and get a lock. I saw that Disk Lock and will see if it fits.
  5. COIllini1
    COIllini1 Junior Member
    34
    Colorado
    Great. Let us know if it works and make & model # etc.
    Thanks.
  6. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    That disk lock is much too thick. The hole is the size of a luggage lock.
  7. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    John,
    What lock solution did you come up with?
  8. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
  9. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
  10. john1701a
    12,749
    5,243
    57
    $20 for the cablelock. $8 for the padlock.
    There's a charging-station available at work, so I haven't actually had a need for it yet.
  11. fjpod
    fjpod Member
    419
    72
    New York
    how about simply pushing a loop of the charging cable through a spoke on the wheel and then putting a heavy lock on the loop?
  12. moviebizman
    moviebizman Junior Member
    55
    Cypress, CA
    That is a SMART idea. I was wondering myself if people would steal other peoples charging units. I'm going to get one of these locks! People are pretty honest at my work. We have a few Chevy Volts and about 4 PiPs and I wondered if someone else's charging unit was faulty - how easy it would be for them to just switch with you. For that I put labels around my cord and at the wall receptacle end on the rectangle box just to deter co-employees from a quick switch. But I wonder if having the lock on it would cause some real crook to actually try and still bust it loose and cause more damage to the car and female end that's attached to the car.
