Grabbing Brakes and Rocking after stop.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LINKSTER, Aug 15, 2009.
  1. LINKSTER
    LINKSTER
    Expand Collapse
    LINKSTER
    los Angeles
    Hi
    I have mentioned this before with a reply but it has become more involved. My brakes have been grabbing after I have been parked. This usually happens when I have been parked on a incline for some time. When I go into reverse, they grab (actually seize) excessively when I go into reverse. Yesterday, the same thing happened when I was parked on a level surface. Has anyone ever experienced this?
    Another parking issue. Whenever I make a complete stop and use "Park", the car will rock back slightly, even on a level surface?? Has anyone ever experienced this?
    Linkster
  2. MikeDS
    MikeDS
    Expand Collapse
    Member
    298
    Los Angeles
    I've experienced both. The rocking after park seems common in a lot of cars. I just try to release the brake slowly.
    The grabbing thing happened to me once and is indeed weird. Taking the car out of reverse and then putting it back in reverse solved it for me the one time it happened. Seems like a system bug, and makes me feel a little uncomfortable about the brake management...
  3. Dakine50
    Dakine50
    Expand Collapse
    Member
    148
    22
    Nor-Cal
    Boy, that's the understatement of the year! LOL! Happened to me the very next day after I brought it home from the dealer. I was backing out of my garage and brakes were grabbing like crazy! WTH? But after that one incident, it never happened again.....
  4. cdw
    cdw
    Expand Collapse
    New Member
    Wilmington, DE
    I used to have the rocking on every level surface, including flat, until I made a point of pushing in the parking/emergency brake *before* letting off the brake and putting the car in "P" (instead of after). Hasn't happened since.
    2 people like this.
  5. moner
    moner
    Expand Collapse
    New Member
    302
    56
    Vancouver, BC
    My car rocks a bit after being put into park, and I often have the grabbing brakes when trying to reverse out of a parking spot. Quite annoying, makes it impossible to back out smoothly. I'd been driving standard transmissions for a long time so I though maybe it was an just automatic thing, but I guess not?
  6. dc202
    dc202
    Expand Collapse
    Member
    230
    Pacific Northwest
    Definitely not a normal part of an automatic.
    I have a feeling we will be seeing a TSB on the grabbing brake issue, if not a safety recall, at some point.
  7. moresee11
    moresee11
    Expand Collapse
    New Member
    San Francisco Bay Area
    thanks, I will give it a try, I was wondering why it would matter since my problem always occurs when I start the car. Does this car have some kind of "memory"
  8. LINKSTER
    LINKSTER
    Expand Collapse
    LINKSTER
    los Angeles
    If we have a problem in this area, how does it get to Toyota other than at the 5,000 mile check. Are there any other avenues to get this problem, we are experiencing, directly to Toyota's Technical Department sooner?
    Linkster
  9. spiderman
    spiderman
    Expand Collapse
    wretched
    7,472
    1,446
    Alaska
    Wow, the grabbing brakes thing happened to me for the first time tonight. I have about 1,200 miles now and when I pulled out of the store parking lot (in reverse), the brakes really grabbed. So much so it was hard to gracefully come to a stop. I finessed it more than usual and was able to overcome it. After getting home, I tried backing up again and there was no problem.
    With that said, the only difference in driving style was that I was sitting in the parking lot with the car "on" and with the AC on for about 12 min.
    Peter
  10. Bobsprius
    Bobsprius
    Expand Collapse
    BobPrius
    679
    79
    Buffalo
    I asked my dealer about it today when I test drove my car which arrived today. He told me that it has to do with how HARD one hit's the brake, so maybe try a little different touch and experiment a little. When you press HARD on the brake is when it happens more he told me from his experience. I drove mine normal and tried that and it seemed ok (today) but I pick it up Friday so will see what happens then with more time.
    Do you apply the Parking brake as well when parked at all???
  11. dc202
    dc202
    Expand Collapse
    Member
    230
    Pacific Northwest
    Until you can get Toyota to fix this problem with grabbing brakes, try placing the car in park and then start over. So far, that has worked for me. The rocking issue does not concern me.
  12. spiderman
    spiderman
    Expand Collapse
    wretched
    7,472
    1,446
    Alaska
    I don't believe what your dealer said at all. Now I will say braking has gotten much smoother since they have broken it. However this is the first time the grabbing has happened to me (1,200 miles now) and it was really noticeable. But like anything that happens on occasions, it is gonna be hard to convince Toyota something is wrong. Again, I was able to make my maneuver without incident but it was disconcerting.
    I try to use my parking brake as often as I can remember to because I don't like to think about what the rocking is doing to the drive train.
    Peter
  13. MikeDS
    MikeDS
    Expand Collapse
    Member
    298
    Los Angeles
    Yeah, its definitely not an issue of brake pedal pressure...it feels like you just slammed the brake down when you barely touch it. Happened to me once and was very weird...hasnt happened since. At the time I just put the car in park and then back in drive and it went away...
  14. Future_Prius?
    Future_Prius?
    Expand Collapse
    New Member
    17
    Northern Nevada
    I've experienced the grabbing brake problem but it was resolved on another thread somewhere. If you ALWAYS keep your foot on the brake when shifting into Reverse you won't have the grabbing brake problem.
  15. spiderman
    spiderman
    Expand Collapse
    wretched
    7,472
    1,446
    Alaska
    Don't you always have to have your foot on the brake to shift period (other than Park)?
  16. wfolta
    wfolta
    Expand Collapse
    New Member
    293
    57
    Washington DC
    When you say "parked on an incline for some time" how long do you mean? Hours, days, weeks?
    I think everyone has experienced brake grab in the first week or two of owning a Prius. It's common enough that it's made it into Prius FAQ's.
    My opinion -- agreeing with the FAQ's -- is that it's related to rust/particles accumulated on the brakes during shipment. I've certainly experienced similar grab on every car I've ever owned, if I let it sit for a week or two. And the fact that the brake grab seems to occur once or twice early in the life of the car and then never again -- in my experience and in my reading on the forums -- reinforces that.
    Remember, with regenerative braking you're only using physical braking below 8 MPH, or if you brake hard, or if you pop it into Neutral before braking. And, I'd assume, in Reverse. Is it a coincidence that brake grab is reported in the two of these situations where you'd be able to feel it: creeping in forward or reverse?
    Again, most every car I've owned over the years will do this if you do not apply the parking brake before letting off of the brake. The Park gear is not applying a brake, it's dropping a pin into a transmission gear's teeth to prevent it from turning, but there's a lot of slack/tension in the entire drivetrain that you'll experience if you don't have a brake (either the regular brake or the parking brake) on to actually lock the wheels.
  17. LINKSTER
    LINKSTER
    Expand Collapse
    LINKSTER
    los Angeles
    Hi To Everyone
    I am back again and the situation has gotten worse. My brakes grab at least twice a week- level, incline makes no difference. Trust me, I know how to set the brakes. I am not interested in learning how to "get around" the problem, I just want them to work properly. I talked to my salesman, a savvy guy, and he said document the problem by bringing it in and it's Toyota's responsibility to fix it. If they can can't fix it in three attempts, then we are dealing with arbitration or a new car. I didn't pay $30,000+ for a car to hope that it works normally, we should expect to receive a car that meets the standards that all of us expect. In this case they have fallen short. My wife is handicapped and snapping her back and forth is not unacceptable. I encourage all you to submit legitimate problems to Toyota for them to resolve, rather than "game them" and avoid helping future buyers of this car. I am not a happy camper and I intend to have a car that works. Stay tuned.
    Linkster
  18. damack1
    damack1
    Expand Collapse
    Member
    123
    25
    Huntsville, Alabama
  19. donee
    donee
    Expand Collapse
    New Member
    2,958
    191
    Chicagoland
    Hi All,
    This is usually caused by rust on the brake rotors. The Prius as you know does most of its braking electrically. The brakes can go for a long time without getting hot and driving water vapor out of the outer layers of the metal. The water vapor will then start the rust action.
    The common way to deal with this is on a slight downhill, to put the transmission in N mode (not to be confused with the legal definition of disengaging the mechanical gears as the Prius never does this) and pressing the brake so that the car runs down the hill at the initial speed. Its probably wise to do this below 40 mph, and to pick a long shallow hill. Then shift it back into D mode on the fly. When in N mode, the inverter electronics are static, and the Prius cannot brake electrically as a consequence. Pressing the brakes down the hill forces the friction brakes to be used, and the rust to be ground off of the brake rotors.
    If your Prius has not been used for a few days, or its rained since the last time you used it, then its a good idea to perform this proceedure as soon as practical once driving.
    One thing that helps reduce the frequency of this issue, if you park the car outside, and do not live in mountanous terrain, is full wheel covers. It still happens, but with the wheel covers, rain does not splash through the openings and wet down the rotors.
  20. jburns
    jburns
    Expand Collapse
    Senior Senior Member
    829
    109
    Archdale, NC
    The grabbing that occasionally happens when backing is not caused by rust on the brakes. It is clearly the brakes over applying from slight foot pressure. It is sudden and only the low speed prevents it from being a dramatic event. Even so it can give your neck a bit of exercise.
