Grinding noise in cold weather
Discussion in 'Gen 2 Prius Technical Discussion' started by marksniles, May 8, 2006.
  1. marksniles
    marksniles Junior Member
    Hi everyone!
    I was wondering if anyone else has experienced a grinding noise when you first start the car in very cold weather. It just started this past winter and the dealer has never had any of its car have that happen before. I was the first! Lucky me! Several trips later they say that it is fixed but now that the warm weather is here, I'll have to wait for next winter to see if they truly fixed it. They said it had something to do with the brakes.
    Just sharing.
    Thanks,
    Mark
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    that's the coolant being pumped from the thermos to the main coolant line system...seems the pump doesn't like cold weather much.
    A few people have had that motor burn out and had to have it replaced, but for the most part it's normal.
  3. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    sounds like they were talking about the brake accumulator pump. i don't get much "very cold" weather by me so i can't tell what you're talking about. but that will probably run every time you start the car, it does for me. a quick little grind sound.
  4. 200Volts
    200Volts Member
    429
    43
    Northern CA
    My 04 with 80k miles makes the cooling "whine-pump" noise when turned off. At Tahoe (high altitude) pressing on the brake makes the short "flipper, dophin" squeek noise. Applying my brakes around town, sometimes makes a "racheting" noise (brake accumulator?) from the driver side, dash, near the windsheild.
    No wonder I can't hear my AM radio.
  5. adampaul7
    adampaul7 New Member
    Hyderabad,AP,India
