1. Offline
    davide Junior Member
    Start a Conversation
    Jul 30, 2006
    45
    suburban Detroit
    I'm actually planning to buy not a Liftback/Gen III but a Prius c in either Super White or the somewhat flashier white called Moonglow. I have doubts about my local collision shop's (my family has used them for decades) ability to truly match the Moonglow, if I were to get into a fender-bender. So I'd like to hear from liftback/Gen III Blizzard Pearl owners whose cars have been repainted by non-dealer collision shops: Did they match the Blizzard Pearl so that you're satisfied? :cautious:
  2. Offline
    Big Steve ramblin wreck
    Mar 5, 2012
    386
    36
    Richmond VA
    Your Vehicle Year:
    Not direct to your question, but a Toyota body shop repaired my rear bumper and The new paint is perfect.
  3. Offline
    JimN Let the games begin!
    Nov 26, 2006
    5,143
    368
    South Jersey
    Your Vehicle Year:
    Toyota doesn't make paint and anyone can buy it. If the color is difficult to match than every shop is in the same situation. If the guy in the shop is good you won't be able to tell the difference. FWIW, the bumpers of white cars don't always match the body so the factory doesn't get it perfect 100% of the time.
  4. Offline
    Rebound Senior Member
    Mar 11, 2010
    1,780
    503
    SF Bay Area, California
    Your Vehicle Year:
    My local body shop told me that the Blizzard Pearl is more expensive to repair.
  5. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    This paint has been around for years --- don't worry about it
  6. Offline
    ny_rob Active Member
    Feb 28, 2012
    924
    274
    L.I.- NY
    Your Vehicle Year:
    My brother in law owns a bodyshop- he said Blizzard Pearl is a 3-step process paintjob.
    In some cases you may have to simply paint a whole panel rather then spot painting.
    Don't let that stop you from choosing that color- it's awesome... :cool:
  7. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    I picked it because I wanted a white car to combat the heat here. But I rather like the pearl sheen it shows in certain lights. 3 step paint? Is that why this is an "extra cost paint option" from Toyota?
    JeffHastings likes this.
  8. Offline
    Jul 30, 2006
    45
    suburban Detroit
    I think JimN meant: Toyota does make paint and anyone can buy it. I'll be buying a Prius c, and preferring the no-extra-charge Moonglow (based on what I've read on the Prius c main forum) over Super White, so my thought was: if Blizzard Pearl (available on the larger GenIII Liftback) has been hard to match, then probably Moonglow would be, too. (P.S. I have not talked to my independent body-shop owner yet.)
  9. Offline
    priusincc Member
    Apr 15, 2007
    307
    Northern Nevada
    Your Vehicle Year:
    I did a search of Blizzard Pearl threads, and some people had problems with just touch-up, and with some body shops not able to match the paint after an incident. One person also mentioned that on a new car the bumpers didn't match the body with the Blizzard Pearl. It is a three step process. I guess it would be OK if you happened to get an experienced shop.
    For me, I wouldn't consider the premium paint on a new 2012, but it does look good.
  10. Offline
    Lordkifar Junior Member
    Jun 15, 2012
    53
    Your Vehicle Year:
    Why is difficult to match the blizzard pearl? Is it the way the paint has been applied to the car in the factory or the color? I would assume that of it is the latter, using the correct color code should solve the problem....but again I know little about body work.
  11. Offline
    Mar 5, 2012
    386
    36
    Richmond VA
    Your Vehicle Year:
    Yep, that's the reason, and also the reason for the up charge in my repair.
  12. Offline
    ashrat Junior Member
    Oct 26, 2010
    Tuscola, Il
    Your Vehicle Year:
    I had the rear bumper cover replaced on my 2011 Blizzard Pearl Car and it looks like a very good match (repair was done at an independent body shop). Would the bumper cover come pre-painted from Toyota?
  13. Offline
    Jun 15, 2012
    53
    Your Vehicle Year:
    Doubt that the bumper would have come pre-painted from Toyota...would probably have cost a lot to do so.
  14. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    OT: I just saw in another thread that you lost a hub cap. You already have bumper damage on your 2 week old car too?
  15. Offline
    Feb 28, 2012
    924
    274
    L.I.- NY
    Your Vehicle Year:
    Supposedly it's: primer coat + base color coat + pearl coat + clear coat.
    So even parts like a mirror or bumper, rocker panel, etc take more steps (and the shop has to purchase the pearl coat in addition to the primary color) to complete. More steps = more billable labor time.
  16. Offline
    Mar 5, 2012
    386
    36
    Richmond VA
    Your Vehicle Year:
    Sigh, yeah. The hub cap was Toyota's fault. The bumper, I backed into the car cross the street. Only two month's old (not two weeks, the hubcap was in the 2nd week.)
  17. Offline
    milkman44 Member
    Oct 16, 2011
    124
    25
    Ky
    Your Vehicle Year:
    I have the Barcelona Red and after I bought the car used, I found out that the dealer had repainted the front bumper. In certain light, the bumper was a different color than the rest of the car. About six weeks ago, I hit a possum and broke the bottom of the bumper, cost my deductable to get it replaced. The new fresh painted bumper looked really good and matched the rest of the car. All was well for a couple of weeks and then the bumper is a different color when out of the sun. I suppose as the paint cured, it changed color slightly. Two other vehicles and different body shops have had the same results with inability to match paint, maybe I'm just too picky.
  18. Offline
    JeffHastings Member
    Aug 8, 2011
    103
    26
    Whippany, NJ
    Your Vehicle Year:
    Same reason I picked it and I'm in the Northeast, not as hot but warm enough in summer. Wish I'd gotten the Bisque interior instead of dark grey but my salesperson screwed up and I was in a situation where I had to get a car quickly. The grey seats are nice in winter, though. don't need heated seats. Aside from that, do love that pearl sheen exterior!
  19. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    Did not mean to rub it in. It happens. When my 2002 Camry was 1 month old, I backed it into a parked car across the street, when I was dropping my friend off at his house. It was my first car with a spoiler. The front of the other car was below it and I was only watching the mirror on the windshield so I missed it completly.
    My insurance paid for the other car. In my case I elected to ignore it for 1 year, then bought some touch up paint and fixed it myself. It was easy to hide imperfections on a white car.
  20. Offline
    Mar 5, 2012
    386
    36
    Richmond VA
    Your Vehicle Year:
    Not to worry, my grown kids and son-in-law had a field day asking me how my backup camera was working out. Sorta funny if it didn't hurt so much.
Share This Page
