Headlight problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTeam, Jul 5, 2007.
  1. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I've got a package 6 2006 Prius. One of the headlights keeps going out. I can't really tell when or how it goes out since I can't see it. I'll notice it when I see the reflection in the back of another car. If I turn the bright lights on and off it has no effect, but when I turn them all the way off and back on the light comes back. Sometimes on long trips it will stay on the whole time, sometimes it won't. Sometimes on short trips it will go out, sometimes it won't. It is not an event I can make happen. I've taken it to the dealer and they can't make it happen (of course). ANyone have any ideas as to what is going on?
  2. hyo silver
    hyo silver Awaaaaay
    15,204
    1,440
    off into the sunset
    Sure sounds like a loose conection, maybe a faulty bulb. Are they HID? Do bumps in the road have any effect?
  3. AlphaTeam
    AlphaTeam Member
    643
    Earth
    They are HID's.
    I'm not sure about the loose connection theory. But I'm not an expert on HID operation. But lets say that it was loose and I hit a bump light goes out. Why would be turning the lights off and back on make them go back on? If the circuit was open then switching them off and on would still not make it operate. If the connection opened and reclosed then why didn't it come back on by itself?
  4. galaxee
    galaxee mostly benevolent
    9,811
    400
    MD
    bulb and/or HID computer, probably. i believe this is the 4th time i've read about this, but DH hasn't seen one yet.
  5. 1fixitman
    1fixitman Member
    179
    Augusta, GA
    <div class='quotetop'>QUOTE(galaxee @ Jul 5 2007, 10:57 AM) [snapback]473448[/snapback]</div>
    Galaxee,
    I am not familiar with the location of the HID Printed Circuit Board. It it possible that these boards are being put in places that do not allow enough heat to be removed from them? Are they exposed to any air flow or do they have heat sinks on the board somewhere? Just curious in theory if heat removal may solve the problem with this long, ongoing issue with many of the vehicles out there. If this is an issue then a small micro fan that operates on 12 volts similar to those found in electronic gear may help or solve this problem. This is all theory for now and I do not have a vehicle with this problem to troubleshoot.
    D Rock
  6. ekarasko
    ekarasko New Member
    The problem with intermittent HID headlight operation appears to be common with the Prius, but is also occurring with other models. I own a Sienna with the same problem. The dealer first replaced the HID computer $1,100, then the bulb $400, and now tells me I need a whole new headlight assembly for another $1,100. This is all in three months. The service technician said "If its not working, give it a little hit with your fist." Not easy to do on the highway. The point is that inoperable headlights are a safety issue, police officers can stop you for it, and you cannot pass inspection without operating headlights. Reading the posts on this site, it is clear that there is a manufacturing defect that is contributing to the problem. You must help out by going to the National Highway Safety Administration web site and filing a complaint (www.NHTSA.gov) It will take you about 5 minutes and you will need the VIN number of your vehicle. If enough people who are having this problem complain, Toyota will likely have to issue a recall and pay for the repairs. Up to $2,600 dollars is too much to pay for working headlights. Good luck.
    <div class='quotetop'>QUOTE(AlphaTeam @ Jul 5 2007, 09:06 AM) [snapback]473428[/snapback]</div>
  7. davidtoo
    davidtoo Junior Member
    Sacramento, California
    <div class='quotetop'>QUOTE(AlphaTeam @ Jul 5 2007, 06:06 AM) [snapback]473428[/snapback]</div>
    I have a 2006 Prius with the same symptoms. Today I took it to the dealer who told me my left halogen headlight had gone out at 40,000 miles (it would work if I turned the light on again - for a while. It cost $529 to repair - they have to remove the bumper to replace the headlight assembly.
  8. wile-e
    wile-e New Member
    48
    I know from other cars where they had one HID light that was affected intermittently the problem was at the connector going to that particular light. If you pull the connector loose you usually have a poor connection at that point. You will see some blackening on the connection because it has been arcing. I have known those who replaced the connector completely and some who bent the parts so that they touched. Much cheaper than $1100..... Of course none of these were on a Prius.....
    You should probably have someone with a wiring diagram check every connection on the route.
    As I sit here and think about your problem the connection may be just under the Fuse Assembly on the Prius. I looked at the underneath of mine recently due to some other problems and the connection that 'Y's out for the headlights is one that was not firmly snapped in on mine. (The assembly got melted by the Toyota shop person when I had them checking the 12V battery. The Toyota techs kept putting things back together wrong.... A month of back and forth with them till I found that the Fuse box wasn't snapped in correctly on one corner... When I FINALLY got the car back from the dealer I checked all of the connections...)
    It makes some sense for the intermittent. In the case of a friend's car the little snap that held that section of the wiring harness in place had snapped off so the connector would bounce off the side of the fender. If he stopped while turning left it would blink. I imagine that this could also happen with the HID controller, but I would assume that the dealer's tech would catch that. (Most HID controllers are close to the light.)
    Now you are going to make me go out and check my connections.....again! :)
  9. galaxee
    9,811
    400
    MD
    <div class='quotetop'>QUOTE(D Rock @ Jul 15 2007, 06:40 AM) [snapback]479036[/snapback]</div>
    D- i completely missed this a few months ago! sorry.
    we're in the process of going through pretty much everything we own and trying to minimize. included in all that is DH's store of "interesting car parts i want to take apart someday" that were well enough ignored by the end of 70 hour work weeks. iirc there is an HID computer in there. if/when he runs across it i will ask him to take it apart and look for air flow/heat sinks before it goes.
    funny, he never once saw the HID light issue described here and the only burned out ones he saw in his time as a yota tech were from using HIDs as running lights.
  10. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    I have experienced the same problem. I tried pulling the fuze out and replacing it and the light would work. However, the problem still occurs. I found that if I turn off the head lights completely and then turn them back on that the light will then work. I keep my lights on all the time. With the HID they run at a lower voltage during the day. I have about 30,000 miles on the car and it is still in warranty. So I guess I will take it in. I will try and wait for the light to be off so that when I drive it in they will see it not working. That is half the battle convincing others that there is a real problem.
    Manny
  11. firepa63
    firepa63 Former Prius Owner
    1,762
    201
    It seems like there have been enough problems with HIDs on the 2006 that people should be reporting the problem to http://www-odi.nhtsa.dot.gov/ivoq/. Maybe this will force Toyota to do a recall, or at least fix the problem when out of warranty.
  12. jbh7254
    jbh7254 JimH
    New Jersey
    I followed your recommendation and submitted the issue to NHTSA and received a request for additional information. I provided pictures showing one headlight out and then the other, and as soon as I dig out the service record showing that the dealer elected to replace both headlights per direction from Toyota it will be scanned and sent as well. Nothing may come of this, but if everyone who has the issue raises it to NHTSA maybe Toyota will step up. This really is a safety issue. I would have one headlight or the other or both go out randomly. If I noticed - not hard after dark - I turned the lights off and back on and both would light for a while. The dealer was responsive, but had to take their direction from Toyota.
  13. lsmike
    lsmike New Member
    So California
    I'm in the same boat with a 2007. Same symptoms except that some times its the left, sometimes the right. Also, as others say, turning it off and then back on corrects it. Probably a board or relay problem but don't have a wiring diagram to locate them.
    Oddly, it's done it since new but haven't had it back to the dealer as that's a pain. I'm in So. Cal so I don't think it's heat related. Also, banging on the bad light has no effect, so I don't think it's in the headlight assembly.
    Anyone with an idea where the HID board and/or relay, etc. is would point me in the right direction. Hoping for an easy fix so I don't have to tie the car up at the dealer for days.
    Just called my service writer at the dealer and will report when she returns the call.
    Thanks, mike
    ProctorAndy likes this.
  14. narf
    narf Member
    580
    Colorado
    Four Touring
    I've read that these are typical symptoms of an HID capsule (bulb) nearing the end of it's life. The bulb will go out after it heats up, and if you shut it down and wait it will relight and run for a while. What concerns me is that HIDs are supposed to last the life of the car.
    Seems to me that when Toyota (and others) went to the newer low mercury capsules these problems began to appear.
  15. lsmike
    lsmike New Member
    So California
    Hi Narf,
    I would agree except it's done it since the car was new and on both sides individually, but never both at the same time. Thanks for the quick reply and I'll report what my dealer says. I just noticed I have 39K miles so am out of the basic warranty.
    Mike
  16. trevorlane
    trevorlane New Member
    Amherst, MA
    I thought I was alone on this, I have a 2006 Prius with about 52,000 miles. I am also having the same issue with my HIDs, and this began around the 44,000 mile mark. I brought it into the dealership who told me they can't seem to figure out what the issue is, much less have the computer tell them there is an issue. They told me they wouldn't cover the issue under warranty. From what I read on the PriusOnline forum board, this isn't a small issue. I'm not sure myself what to do next, and I don't have an extended warranty.
  17. OverTork
    OverTork Junior Member
    68
    Northville, MI
    It could just be a bad connection. If I'm not mistaken HID lamps require a high voltage pulse to get lit. They get this pulse when you initially turn them on. That may be why turning them off and on again gets it restarted.
  18. lsmike
    lsmike New Member
    So California
    Hi Trev,
    You and a lot of us aren't alone. After I posted this afternoon, my favorite service writer at the local Toyota dealer called me back. She's had two in the last two weeks. As I have let the warranty expire they have to diagnose it and then call Toyota for a finding of whether it is still covered. It's one of those things that's more of an annoyance than a serious issue, unless of course, the headlights just die.
    mike
  19. calmel
    calmel New Member
    california
    On my '04 Prius with HID, the left headlamp also cuts out sporatically. If I turn the headlamp switch off & then on, it comes back on - for a while. My dealer wants to change the ballast (which includes a computer) and the bulb for $1000! Ouch!! Phone quotes from other area dealers ranged from $800 to $1100.
    My question is: if the ballast/computer is bad, why do I need a new bulb? If the bulb is bad, why do I need a new ballast/computer? Couldn't get a straight answer from the dealer.
    Does anybody know of a way to determine if this problem is simply something lose somewhere?
    Does anyone know if any Toyota dealers have absorbed this cost on any out-of-warranty cars? At 4 yrs/55K miles, I'm beyond the basic coverage of 3 yrs/36K miles. I should think a critical safety item like a headlamp system should last more than 4 yrs.
    Thanks for any insight anybody can provide.
  20. trevorlane
    Amherst, MA
    Well I called the Toyota Customer Experience Center and spoke with a representative. I explained to him the situation with my headlights, and he opened a case regarding the issue so I'm going to take it to a local dealer, since the other dealer told me 1.) there's no issue and 2.) the dealer is located in central mass, which is an hour and a half away from me. I asked him to have the dealer check the bulbs, ballasts, connections, and ECU. I'm hoping that they find something more this time around.
