1. Offline
    madoue New Member
    Jan 12, 2009
    Message Count:
    53
    Your Vehicle Year:
    Hi there. I just bought a Prius II and am trying to get the key fob to open all 4 doors when I push the unlock button once. I have another 2010 Prius and it worked just fine, but when I go through the steps in the manual, this one will not change.
    Has anyone seen this or does anyone know of special steps to take to make this happen? Thanks.
  2. Offline
    drmalone New Member
    Aug 29, 2009
    Message Count:
    24
    Big Rapids, Mi
    Your Vehicle Year:
    If I recall correctly, on my 2006 Prius the unlock button on the passenger side and on the hatchback would open all the doors. The button on the drivers door would only open that door (you then need to unlock from the inside). I'm not sure you can change that as you can with the 2010. Perhaps someone else has more information.
  3. Offline
    madoue New Member
    Jan 12, 2009
    Message Count:
    53
    Your Vehicle Year:
    Thanks. I do have a 2010 prius that I am trying to change. I actually have two. One works fine and the other will not change for some reason. I do not have a button on the hatch or the passenger door since I have a Prius II.
  4. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    We need a few details:
    1) By Prius II do you mean a Gen II, or a #2 package of a Gen III?
    2) If it's a Gen II, does it have SKS? If so, I know you can program the doors to all open with the SKS. As for a single fob push, I'm not sure. Two pushes of the fob button will open all doors.
    If it is an SKS model, why are you messing around with the fob?
    Tom
  5. Offline
    drmalone New Member
    Aug 29, 2009
    Message Count:
    24
    Big Rapids, Mi
    Your Vehicle Year:
    Sorry, misunderstood. I have a 2010, III with no sensors on the hatchback or the passenger door. I was able to program it to open all the doors from the drivers side. Guess the II is different.
  6. Offline
    kawita New Member
    Jul 19, 2009
    Message Count:
    87
    Batavia, IL
    Your Vehicle Year:
    Sorry to be the bearer of bad news, but to unlock all four doors with the key fob it has to be programed by the dealer. The SKS door handle can be programed to unlock all doors by holding both buttons on the key fob while inside the vehicle for 5 seconds or so.
  7. Offline
    madoue New Member
    Jan 12, 2009
    Message Count:
    53
    Your Vehicle Year:
    It is a 2010 Gen III Prius II. We have two of them and one of them changed exactly as it was supposed to, but this second one does not.
    1 people like this.
  8. Offline
    madoue New Member
    Jan 12, 2009
    Message Count:
    53
    Your Vehicle Year:
    THANK YOU THANK YOU THANK YOU!!
    I just had to do it from inside the car, not outside :rolleyes:
Share This Page
