Help Finding TSB's... 0205-11 an d 0363-10
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bpollard, Jan 21, 2012.
  1. bpollard
    bpollard New Member
    51
    West New York, NJ
    Took my 2010 Gen III Prius in today hoping to get TSB-0012-10 and/or TSB-0204-11 performed because of poor cold weather start-up problems.
    Instead, they performed TSB-0205-11 and TSB-0363-10
    I did a google search and a search of these forms but did not come up with what these two additional TSB's actually do. Can anyone help?
  2. jdcollins5
    jdcollins5 Senior Member
    4,909
    1,066
    Wilmington, NC
  3. bpollard
    bpollard New Member
    51
    West New York, NJ
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,447
    38
    Santa Fe, NM
    0205-11 is an ECM reflash to address failure to start (P3190, P3191, P0A0F). Look under your hood with all the other labels to see if there is a sticker indicating such.
    0363-10 is a Brake ECU reflash to address brake noise when stopped.
    Chances are, the tech did a health check, found no codes for P030x, went into the ECU menu, noticed that there were two updates available, and did those.
  5. bpollard
    bpollard New Member
    51
    West New York, NJ
    do you have a PDF copy of either 0205-11 or 0363-10?
  6. seilerts
    3,326
    1,447
    38
    Santa Fe, NM
    see attached
