Help! I broke off the bottom door of my Prius glovebox!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jrlnc, Mar 6, 2012.
  1. jrlnc
    jrlnc Junior Member
    56
    Piedmont, NC
    I was trying to save money by not going to the dealer for wipers and the interior cabin filter.
    After much effort I got the new wipers on so I tried to tackle the filter. I read the manual and opened the lower door. I took off the side arm and then popped open the compartment. I put in the filter but the door fell completely off and the side arm fell into the compartment.
    Now I think if I take it to the dealer they're going to charge a fortune to fix this mess.
    has anyone else had this problem? Can I fix it or is it now only a dealer issue?
    I feel horrible about this -- my new car looks like somebody trashed it. :-(
  2. fuzzy1
    10,039
    If the door just fell off, it seems unlikely that it actually broke. It comes off easily and the damper (side arm) falls off easily without actually breaking anything. And it can be a bugger to put back together the first time or two. But without re-doing mine again and taking pictures, I don't yet have reassembly advice.
    Hopefully that side arm didn't fall back behind the trim. Retrieving it from there appears difficult.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Side arm? Do you mean the damper like fuzzy mentioned or do you mean the latch(es) that hold the door close?
  4. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    I made a quick video showing how to change the filter. It's not the best video but might help you a little with your issue. If not...just ignore it I'm just hoping to save you some money instead of going to the dealership.
    AnneN, TJ Minski, priusFTW and 5 others like this.
  5. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Thanks a bunch for making and posting that video. Very helpful. :)
  6. fuzzy1
    10,039
    Jrlnc: The 'side arm' in this video was well behaved. Mine was not, giving several bits of trouble before I got it right.
  7. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Even if it fell down behind the kick panel ... it's no big deal. Just pop off the kick panel and get it out. There's nowhere it can go that you can't get it with a little mechanical aptitude. Just get some good lighting and you'll figure it out. It really isn't hard.
    REV
  8. jrlnc
    jrlnc Junior Member
    56
    Piedmont, NC
    Thanks unlimited and others!
    It was very cold and dark in my garage when this happened.
    I will make another attempt to put things right this evening and use some extra lighting.
    I hope it is fixable. I will post back and let you know how it goes.
  9. alfa737
    alfa737 Member
    126
    27
    Unlimited, gr8 job with the filter change ..
    How do you embed a video, does it have to ne on youtube first and how do you add it to the forum?
    thanks
  10. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Upload to youtube and just add the URL via the Insert Link button.
  11. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    Depressing the left side of the glove box to get it go down seems much stiffer than other Toyotas I've owned. Other than that, it was pretty easy to change the filter.
  12. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    Our local mice population find the white "noise-suppressant" insulation shown in the video (glued to the backside wall of lower glove box) - to be absolutely delicious!
  13. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    Notice how the aftermarket cheapo filter does not have the same amount of filter media? This is why they opened up the pleats to get less materal to cover the same area. Also, the media material does not quite look the same as factory when I checked one out in the auto parts store.
    For me, they only need changed every 30,000 miles or so. I'll stick with a Toyota replacement.
  14. revhigh
    986
    141
    True ... but ... does it matter in that application ?? I think not.
    Having said that ... can't go wrong with the OEM filter.
    I've made about a dozen of these filters from cut up furnace filters. Cost about $2 each and do the exact same job. If you look at how it fits, you'll see it just lays in there ... air can easily get around and under it without passing throught the filter ... it's not like an engine air filter that's well sealed.
    As far as I'm concerned ... the whole concept is just a ridiculous money making scam for the dealers.
    REV
  15. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    I have noticed that it is easy for the bottom hinge points of the glove box to slip out of place when opening wide for a filter change, but it is easy enough to slide them in before reclosing the door. I bought a Puralator filter at Advance that seemed pretty close to the Toyota one (about $15)....I didn't bother to count the number of pleats though. Happy to change it every 15K if it helps my wife with her allergies.
  16. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I couldn't get the damper back on so it rides in the bottom glovebox. If you open it watch your knees!:eek:
