1. Offline
    Start a Conversation
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    For the hell of it I decided to install an HID kit in the GenIII. From all of the pictures I have seen, the cutoff looked pretty decent. It didnt appear to bow much and the cutoff was adequate given the Prius projectors don't have a clear lens.
    I got the kit installed in a few minutes then waited for night to fall before taking it around the block to check out the pattern. I am not happy. :(
    The projectors throw light all over the place and not in a good way. The cutoff is nice and clean right in front of the car but off to either side the beams bend upwards which could potentially blind oncoming traffic. The beams pattern is less focused and much dimmer off to the sides so it may not be such a bad thing but I cannot be sure. The light output is ok for a plug and play kit in a weak projector and I am happy enough with it. It's the bending beam that bugs me.
    I poured through output pictures posted by other members and I noticed all of them are taken at a short distance from a wall/door. None of them were taken at more than 25' away. I noticed two of the pictures show the beam starting the bend up but then the picture ends so I cannot tell of all Prii do this or if I just have two bad bulbs. For the record I am using cheap Chinese bulbs right now as part of a test but I didn't expect this.
    Would anyone else mind taking a few wall shots from a good distance so I can compare beam/ cutoff patterns?
    Thanks,
    My first pic is of my GenIII with a plug and play kit. Pic was taken with cell phone because my camera hates night shots and the rest came out blurry.
    The second pic is of my FX-R retrofit in my GenII for reference on a decent cutoff.
  2. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    And a pic of the cutoff on my first retro with Morimoto Mini D2S.
    [IMG]
  3. Offline
    sfv41901 Blizzard Brigade #164
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    The bowing might be due to how the OEM cutoff has a 2nd step towards the outside. Not much can be done without a proper retro. Something I'm already looking into.
  4. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    I have a feeling you are right. This is sortof disappointing if that is the case. Let me know what you figure out for a retro. My Mini H1s were much better than this and you know how they feel about Minis. LOL
  5. Offline
    flareak Fleet Captain
    Mar 9, 2004
    1,016
    St Louis, MO
    Your Vehicle Year:
    good 'ol toyota :p pretty disappointing that the projectors would perform that way.
  6. Online
    wotcher Member
    Mar 24, 2012
    352
    73
    LA
    Your Vehicle Year:
    were these the results of the h11 morimoto kit? im still deciding to buy the morimoto or the xtreme.
  7. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    Nah. I'm testing bottom of the barrel DDM stuff right now then I was going to swap to Morimoto or Xenon Depot bulbs when I can afford it. I want to document the differences to help future buyers. :)
    4 people like this.
  8. Offline
    wick1ert Senior Member
    Dec 3, 2009
    1,293
    173
    Delawhere
    Your Vehicle Year:
    I feel like the output is better with the Morimoto bulbs vs DDM, but it might just be what I was hoping to happen when I swapped bulbs and therefore it did happen. I'll see what I can do as far as a further away shot somewhere.
  9. Offline
    schorert Member
    Apr 18, 2012
    125
    48
    mass
    Your Vehicle Year:
    The person who invented aftermarket HID kits should be beaten to death after having his eyes burned out with HID bulbs.
    All winter long I drive to and from ice rinks, after dark. And all winter long I am followed up and down the highway by a-holes who have installed aftermarket HID kits. I'd say 1/3rd of the HID lamps on the highway are aftermarket kits, installed in housings that were NOT designed for HID bulbs. I can pick out an aftermarket HID kit from half a mile.
    Some are white, some are blue, some are purple, but all throw excessive light equal to or worse than factory high beams. Since they'll never stop selling them, I wish MA state police would start ticketing for them...
  10. Offline
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    So this morning as I was leaving I paid extra attention to the cutoff (i still have the halogen bulb) & could see how the cutoff bows so this isn't a bulb issue. It's a design issue.
    1 people like this.
  11. Offline
    32kcolors Senior Member
    Jul 14, 2009
    4,910
    684
    Redondo Beach, CA
    Your Vehicle Year:
    Did they revise the headlights at all for 2012? I know they did for LED headlights but did they also do the lower trims? Can someone with both 2010/11 and 2012 inspect very closely to make sure the innards are the same?
  12. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    Great, thanks for your opinion now go back to your corner.
  13. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    Thanks. I was hoping that wasn't the case. :( I'm interested to see what you come up with a retrofit. It would be very nice if something like the FX-R or the RX330/350 dropped right in.
    I'm not really sure what to look for really. I'm deathly afraid of taking anything apart on my new car. LOL
  14. Offline
    Dec 3, 2009
    1,293
    173
    Delawhere
    Your Vehicle Year:
    I looked on ebay for some "junkyard" headlights to see how they were made and if it'd be an easy breakdown, etc. They wanted at least $100 each! It'd be nice to have one sitting there so that you could work with it on your own time and not worry about getting lost or side tracked and the next thing you know, you're trying to re-assemble the car at 2am. I'm just not willing to pay that much for something that has been injured.
  15. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    I hear you, bro. That's just too much cash to play around with.
    I would think that the OE projector could probably be played with to reduce the bowing by bending the shield or cutting a new one. I'm just not interested in baking a brand new headlight, neither is my girlfriend! :eek:
  16. Offline
    ImeanGreen Prius v Five BP Brigade #236
    Feb 20, 2012
    374
    Somewhere out there
    Your Vehicle Year:
    Hopefully goodtimes can chime in on this and get a picture from 25 ft. with his
    Was debating about this too. Already got a quote for it with the mini D2S. Retrofiter told me that he will know if the FX-R series will fit once he opens it up. I'll have to have a week with my pri in the garage from removal to reinstalling back the headlights. :(
  17. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    If you have a choice I would suggest the MH1 over the Mini D2S. I had both and the MH1 was MUCH MUCH better. I ran the MH1 with the Morimoto XB35 bulb and was very happy with it. It was almost as good as the FX-R except not nearly as wide. :)
    Please keep us posted on what you decide to do and post prices if you are allowed to. :)
  18. Offline
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    I was thinking along the lines of a AP1 S2K projector since there is a separate high beam or the FX-R.......I just won't know until I can get a busted 1 to play with & see what can fit. It should be easier than the gen2 since the gen3 already has a projector.
    As far as tweaking the OEM projector......it's not even worth the trouble since uve already opened the headlight, u might as well do a full retro.
  19. Offline
    Aug 14, 2006
    18,135
    3,444
    Sacramento, CA.
    Your Vehicle Year:
    I agree it is not worth the trouble unless it was easy to remove and a retro is a PITA. LOL
    The S2K is nice but many they are expensive!
  20. Offline
    Dec 3, 2009
    1,293
    173
    Delawhere
    Your Vehicle Year:
    I found a Left side one, new on ebay for $121. I ordered it, and with my bowling league finishing up this weekend, I should be able to mess with it in a couple weeks. I've just been too busy with other projects lately to keep up with everything else I've wanted to get done.
Share This Page
