HID Headlight Retrofits
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Unleashd, Dec 13, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Its gonna look awesome when your all done. Crud... Now I have another project! (y)
    Unleashd likes this.
  2. Unleashd
    Unleashd Junior Member
    71
    Oakhill, VA
    If you want a set of pristine halogen headlamp units, let me know. I haven't used the set that I bought here on PC :)
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
  4. Unleashd
    71
    Oakhill, VA
    These came from an '05 model. Just the one orange reflector.
  5. Unleashd
    71
    Oakhill, VA
    Today's work...Baked the painted shrouds - 150 deg for ~15 min
    and then started to put the headlight back together..
    I made a couple of scratches as you can see in the pictures above and below. Need to hit those spots with paint tomorrow.
    Justdidit likes this.
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Looks good! If you can, b4 u put it all bk 2gether 2mrw, can you take a picture of how you wired up the bi-xenon switch for your hi-beams?
  7. Unleashd
    71
    Oakhill, VA
    I tried to reuse the connector by prying out the crimps, but I was not able to. Advance Auto and Radioshack also did not have the same connector. So, I ended up cutting and soldering the wires instead. I considered completely leaving out the high beam, but that would not pass inspection next year.
  8. Unleashd
    71
    Oakhill, VA
    First picture of just the passenger side headlight connected...:)
  9. Unleashd
    71
    Oakhill, VA
    Both headlights mocked up. Driver side is Morimoto 3Five 5000K bulb. Passenger side is OEM bulb.
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Nice job. I'm sure the connector is proprietary to Toyota - your choice looks to be the simplest method. Any chance of the hi-beam in action?
  11. Unleashd
    71
    Oakhill, VA
    Will post pics later. Forgot to click that pic.
  12. Unleashd
    71
    Oakhill, VA
    While waiting for the 2nd coat of painting the reflectors to dry, I was perusing the local auto store. And......
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Nice! any idea what MCD rating those are? I am looking at some that are 20,000mcd to make my Faux led lighting real.
    From This:
    To this:
    with the Projector conversion and the painted shrouds and reflectors.
  14. Unleashd
    71
    Oakhill, VA
    Not sure of the rating. I am not even sure these will last too long. But just wanted to try them. The pair of 14" prewired strips was on sale for $15. The strips have 3M adhesive on them and are weatherproof according to the packaging. Let's see how long they last ;)
    another shot in the dark...
  15. Unleashd
    71
    Oakhill, VA
    Houston, we have a problem. The 2nd coat of paint is messed up :(
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    whoa... what happened? wrong can of paint!? Can you re-mist over it after its dried? did this happen in the oven?!
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Looks good for $15!!
  18. Unleashd
    71
    Oakhill, VA
    Not in the oven. I had scratched the paint after the first coat while test fitting the projector shroud. As soon as I applied the second coat, this happened :( Same paint can as the first coat.
    OTOH, this kind of created a texture inside the entire reflector bowl :p So, I left it like that and went ahead and assembled the car back. It has been a week since I started working on this. My wife walked in from work and started taunting me. Guess, I started loosing patience too :LOL:
    Well...here is the final output of this project...
    Parking lights only
    Low Beams
    Low Beams with Fog Lights
    Low beam and Fog lights closeup
    High Beams
    Cutoff along the wall(s)
    High Beam Pattern: The pattern is sort of all concentrated on the left, as though only the driver's side lamp is switching. But, I can hear and see the passenger side lamp also switching to high beams.
  19. Unleashd
    71
    Oakhill, VA
    The only thing that I can think of is that it might have been due to the cold weather that I did the painting in. The reflector bowl might not have been warm enough. Not sure though...
  20. Unleashd
    71
    Oakhill, VA
