1. Offline
    brwnjr82 New Member
    Sep 24, 2008
    Message Count:
    london
    Your Vehicle Year:
    Hi Everyone,I bought a Prius 2008 model from the salvage,having done all the work,i realised when I am doing above 35 mile on the speedo there is this noise like a manual car that is being driven too long on the low gear.(high rev/minute)Like the gear is not going upto gear four or five.The damage to the car was the following:-off side front panel,mainframe,suspension,driving shaft,inverter coolant pump and fuse box inside the bonnet(hood).Notting physically wrong with the engine.Most of the repair was done on the persenger side.Any advice will be appreciated.Many Thanks in advance
  2. Offline
    jelloslug It buffed right out!
    Jun 11, 2008
    Message Count:
    807
    36
    Greenville, SC
    Your Vehicle Year:
    What was the extent of the damage that you repaired? That will help with the diagnosis.
  3. Offline
    brwnjr82 New Member
    Sep 24, 2008
    Message Count:
    london
    Your Vehicle Year:
    Hi Jelloslug,Thanks so much for your response,The damage to the car was the following:-off side front panel,mainframe,suspension,driving shaft,inverter coolant pump and fuse box inside the bonnet(hood).Notting physically wrong with the engine.Most off the repair was done on the persenger side.Looing forward to your reply.
  4. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    In other words, high engine RPMs? My first suspicion is that the traction battery and/or its charging system and/or one of the electric motors is damaged. You will probably need to take this to a certified Prius tech to get it properly diagnosed with Toyota's proprietary equipment. Sorry.
  5. Offline
    Jun 11, 2008
    Message Count:
    807
    36
    Greenville, SC
    Your Vehicle Year:
    When you replaced the axle did you refill the tranny fluid for any that you may have lost? Can you pinpoint the location of the noise? Is there any vibration with the noise? Have you examined the wheel bearing on the damaged side for runout or endplay issues? I would also check the axle nut for proper torque (216 N/m or 157 ft/lbs). Those areas would be where I would start.
  6. Offline
    brwnjr82 New Member
    Sep 24, 2008
    Message Count:
    london
    Your Vehicle Year:
    Hi Jelloslug,Thanks again for your help,The noise is without vibration of any kind.also from my observation,the noise seems to be coming from the mid section.lastly,i refilled the fluid lost when the axle was replace.Will try the axle torque to see if any noticable difference.Thanks once again for your help.
  7. Offline
    brwnjr82 New Member
    Sep 24, 2008
    Message Count:
    london
    Your Vehicle Year:
    Hello everyone,Thanks so much for all your effort in this forum.I have now solved the problem of the High pitch noise coming from my Prius engine.The problem has to do with faulty Hub and a missing part.The missing part was a plastic air reservoir attached to the air filter under the arc wheel of the driver side.I am now enjoying a very quiet ride in my car.Thanks so much to all members who offer their knowledge.It cost less than a £100 to fixed,whereas Toyota was asking for a fee £500 to diagnose the problem.Long Live Prius Forum!
  8. Offline
    Jun 11, 2008
    Message Count:
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Great to hear you got it fixed! I knew it would not be something terribly complex.
Share This Page
