High pitched whine when braking
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Snowball, Jan 8, 2014.
  1. Snowball
    Snowball Junior Member
    48
    Southern CA
    I've noticed more and more that when I am braking that I heard a high pitched whining noise. Sort of this ultrasonic type sound. It will only go away if I depress the brake pedal very firmly after being completely stopped. However every so often the firm press will not stop the noise. I hear it more in the evening on the way home than in the morning to work, though I may not be paying attention as much in the A.M. due to morning brain fog.
    Does this happen to anyone else? I don't hear it any other time. I'm worried something is wrong with my inverter.
    Thanks.
    48,946
    you're regenerating electricity man!(y) theya ll whine to some extent. when you press hard, you're engaging the friction brakes, don't do it!:p
  3. Snowball
    48
    Southern CA
    Ok. I only press hard once I'm completely stopped to get the whining to stop. Because it's still whining when I'm completely stopped! I don't think I'm still generating electricity when I'm not even moving.
    48,946
    ah, sorry, misunderstood. it's making the whining noise while your stopped?
  5. Snowball
    48
    Southern CA
    Yes, the sound starts when I press the brake to slow, and it continues to whine after I have already stopped. While I am stopped, I have the brake held in a static position to keep the car from rolling. From that pedal position, I have to press even further (mash the brake pedal down) to make the sound stop.
  6. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    In the first couple of weeks of ownership, we kept looking out for the ambulance that never showed
  7. bisco
    48,946
    since mr gee has confirmed your experience in his c, it sounds like it might be normal. but i have never heard it in my 3 pri or 2 hycams.
  8. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Mine does it too. I think its the regen brake initiating. That's all. I think it's a normal part of the way the prius c brakes work. First it initiates the regen brake before the friction brake. That makes sense to me. Because I don't think the car can differentiate and apply only the friction brake while the vehicle is stopped. Someone correct me if I am wrong.
  9. bisco
    48,946
    re gen is only active down to 6 mph, then it's pure fiction.
