High Pitched Whining Noise After I turn Prius Off and Turn it On
Discussion in 'Gen 2 Prius Technical Discussion' started by Austin Middleton, Apr 5, 2013.
  1. Austin Middleton
    Austin Middleton New Member
    I know this noise is the Thermos Pump and it operates when I turn the car on and off. Question - do you guys experience this too? Or is it failing - also a really annoying noise, but I'll put up with it as long as nothing's breaking.
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It only runs for a short time, I just ignore it. The thermos is more trouble than it is worth as the pump and the control valve have had maintenance issues. Toyota no longer puts one in the Gen3 or later models.
    JeffD
  3. Austin Middleton
    Is it a mileage or emissions thing? Would it be a big deal if I just unplugged it? Would that cause the check engine light to come on?
  4. jdenenberg
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yep, there are sensors that will report a problem to an ECU if you try to disable the pump.
    JeffD
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    I think I would be more worried if I did not hear the pump running after I shut the ca down!
