Hood Release Cable replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jeremnyc, Jun 6, 2014.
  1. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    My 08's hood release failed. I found some info here about getting the hood open. I ended up using the 10mm with a 1/4" drive through the front. It was a bit tricky, but I got it out. It looks like the "ball" at the hood end of the cable simply fell off.
    When I had it out, I wrapped an insulated 12# wire around the release mechanism and installed the mechanism again. Now, I pull a wire to open the hood partially and it operates as normal after that.
    I ordered a new hood cable. Has anyone snaked one through? Any advice? The new one came with a "handle." Thanks in advance.
  2. ShadeTreeMechanic
    ShadeTreeMechanic New Member
    Home
    Hi JeremyMC.
    Yes, to replace a broken hood release cable on a 2nd generation Prius, requires to remove the black plastic shroud on the radiator top support, pinch 2 black plastic retaining clips, jack up the driver's front left of the car, place a jack stand under the car frame, remove the driver's front left wheel, remove driver's front left black plastic outer fender liner, remove round split rubber bung from the outside firewall, slide back the black rubber weather accordian from the driver's left inside footwell, and gently pull on the broken cable to snake it out.
    Reverse the steps to reinstall.
    Takes about 2 hours.
    ShadeTreeMechanic.
    M@ Childress likes this.
  3. M@ Childress
    M@ Childress Junior Member
    Illinois, USA
    THANK YOU!!!
    Used these directions to run wires forward through the firewall in an ‘08 Prius for after market fog lamps.
