Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    no matter which ones you take, they are for sure WAY better than the stock ones////
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Yes, much better than stock ones. Listen to the comparison video the OP posted at the beginning of the thread.
    SCH-I535
  3. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  4. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    @xliderider;
    Do you have problems getting a safety check with those horns?
    I had air horns, but during the safety check, they told me they were not allowed.
    I put the stock ones back just to pass safety.
    I called the DMV and they told me that air horns are not illegal to have, but they are too loud and that is why I did not pass.
    I hate these stock horns!
    If you passed safety, I might look at those horns you got...
    Thanks,
    Alan
  5. kevinb70
    kevinb70 Junior Member
    Atlanta, GA
    Installed a set of Hella Twin SuperTone horns. Doesn't sound that much louder on the video (amplitude compensation?) but much better in person...
  6. xliderider
    7,848
    3,102
    Honolulu, HI
    I have no problem passing safety inspections with the upgraded horns. They sound identical to the oem horns in my Camry.
    SCH-I535
  7. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Do you have the part/model number of the FIAMM horns from Napa?
    Thanks,
    Alan
  8. xliderider
    7,848
    3,102
    Honolulu, HI
    Here's the original post:
  9. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Harbor Freight has some inexpensive chrome horns too.
  10. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Thanks...
  11. Noodleho
    Noodleho Junior Member
    32
    Sacramento
    if I going to install 72102 FIAMM Freeway Blaster Horn High Tone and
    72112 FIAMM Freeway Blaster Horn Low Tone, do I need a relay? Thx!
  12. xliderider
    7,848
    3,102
    Honolulu, HI
    No, you don't need a relay. I wired high/low horns to the oem terminals and haven't had any problems or blown fuses.
    SCH-I535
    #312 xliderider, Sep 18, 2014
    Noodleho likes this.
  13. Noodleho
    32
    Sacramento
  14. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    How long has your mod been in there? How many times has it be used? Have you tried a sustained use to see if any fuses blow or wiring burns up? Checked the wiring diagram to verify the circuit?
  15. xliderider
    7,848
    3,102
    Honolulu, HI
    About 2.5 yrs, 10+ times, sometimes 1 to 2 seconds, no.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I have a set of Camero horns on my Prii for 2.5 years. I've laid on the horn a few times & have never had any problem.
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Yes you may or may not 'need' one, but it wouldn't hurt to use one. Cheap insurance to protect what maybe down stream from the added current flow. A wiring diagram would better answer if one should chance not using one. Is the 2011 vehicle wiring the same as the 2014?
    Great, but for me without a wiring diagram to know the factory circuit a relay is cheap insurance to protect the wiring and anything else.
  18. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    BTW, harbor freight has a set of chrome horns for $9 with coupon that even comes with a relay.
    j12piprius likes this.
  19. xliderider
    7,848
    3,102
    Honolulu, HI
    So go ahead and wire the relay. Can't hurt, as long as you wire it properly.
    SCH-I535
  20. Blajoie
    Blajoie Junior Member
    San Diego, California
    Thanks OP, installed the horns today on my 2012 Three.
    Removing the toyota emblem made working in the tight space much easier.
    My horn anchor bolt was a 12mm though.
    The new horns sound great!
    evpv and Dylan Doxey like this.
