Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. reidhester
    reidhester New Member
    Albuquerque NM
    Thanks for the write up. So you didn't need to wire in a relay?
    I put a Stebel horn on my 2010 BMW R1200GS motorcycle last year. At 135db it gets your attention! So I've been considering doing this for the Prius also but would prefer the big Caddy sound to the Stebel's more euro sound.
  2. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    No relay is needed for these horns, just a simple plug-in installation.
  3. Fla Fla Flo Fly
    Fla Fla Flo Fly Junior Member
    38
    Illinois
    I replaced mine last weekend after someone was changing into my line while I laid down on the horn. They didn't hear a thing, and neither did my wife who was in the passenger seat!
    So far, I'm happy with the cheap and easy upgrade! :rockon:
  4. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    Interesting read. Just wondering if anyone that did this mod had the radar cruise/Pre-crash system module up front behind the badge?
  5. reidhester
    Albuquerque NM
    Thanks for the reply.
  6. johnmaci
    johnmaci Junior Member
    30
    MD
    What I did not see is where the grounding wires were attached?
  7. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Check out my install. You can see the sensor.
    No problems at all with the dynamic cruise control.
    Alan
  8. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Check out my install. I am sure I showed where I landed the ground wire.
    Alan
  9. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    The FIAMM horns come with ground wires. One end plugs to either plug on the horn, the other has an eyelet. Just place the eyelet between the bracket and mounting nut, the metal mounting bracket will ground it to the chassis.
  10. chikai
    chikai Member
    53
    16
    Redmond, WA
    Awesome...thanks for the write up. Just ordered and installed this T-Day break. $18.88 via Amazon delivered for both.
    WOW I can't wait to use it the next time someone cuts me off. Wahhhh-wahhhhh!!!
  11. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Have you ever tried spraying some silicon on the male and female end before putting it together, this along with a good wrap of 3M electrical tape should keep it dry.
  12. reidhester
    Albuquerque NM
    Another alternative is to use shrink wrap tubing and a heat gun.
  13. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    That works good too. The only problem I had with that is there is sometimes some exposed sections on the connections.
    I used to start at the relay and keep wrapping the tape until I got to the bundle of wires. about 2 inches below the bottom of the relay.
    It all depends on where the relay is mounted or placed.
    It seems like every time a relay and connectors needed to be replaced, the wires would end up being too short after cutting the bad stuff off.
    LOL..........never a problem if the relay is inside the car.
  14. torr310
    torr310 Junior Member
    37
    Great job! The small horns bother me when I switched from a medium sized sedan. It's hard to be heard by these big trucks.
    D_n_D likes this.
  15. Motorman
    Motorman Junior Member
    WA
    Thanks EVPV, the instructions were great. After almost being backed into by a lady backing out in a parking lot as I was waiting for a pedestrian. I decided I needed a real horn. What a difference!
  16. Motorman
    WA
    Thanks evpv your instructions were very complete. The sound is so much better.
  17. Volstylexx
    Volstylexx New Member
    Knoxville
    So i just completed this DIY and i must say that I am a very avid DIYer and have worked on many many vehicles in the past. This is by far the MOST difficult project I have ever done. I just completed and i literally had to pull the upper part of the bumper back to get in to the existing horn bolts. Unless you have incredibly small hands, this will tear your arms up. Mine look like i just got into a fight with a thorn bush.
  18. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I also did this mod & thought the instructions were excellent & straight forward.
  19. Volstylexx
    Knoxville
    yes ,couldn't have even attempted the project without this forum and post ,was just much more difficult than anticipated with my large hands lol
  20. SoCalBPrius
    563
    118
    SoCal
    Haha, totally understand what your sayin as this is one of the few times I can say my smaller hands were an advantage over your bigger hands;).
