1. Offline
    KK6PD _ . _ . / _ _ . _
    Start a Conversation
    Mar 24, 2008
    3,578
    617
    Los Angeles
    Your Vehicle Year:
    Yes, the relay is there to switch off DRLs when the headlights are on. Actually when both DRL and headlight it all looks like one big light!
    By itself the DRLs are bright, not blinding!!
    1 people like this.
  2. Offline
    Luke H. Junior Member
    Apr 21, 2011
    United States
    Your Vehicle Year:
    If I were more experienced at this sort of thing, I would not hesitate to install this mod. It looks awesome...
    1 people like this.
  3. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    Yeah, this is one of those mods that seem really easy until you actually start doing it. Glad KK6PD did all the research for us.
  4. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    Just dawned on me......The white flash and all the other problems may only happen on the Amber-Off version. Perhaps whatever circuit they use to keep the DRL off during turns signal flashing causes all the problems. For instance. My switchbacks don't flash reliable during lock/ unlock. the rear signals which are still incandescent flash normally, so it's not the flasher. Clearly the Amber Off circuit needs work. From what I've heard about their customer service there's no point in even trying to get this resolved It's not really that bad. All the problems seem to happen when the turns are lit without energizing the DRLS, so worst case I can tie the DRLS to the turn signals through a diode.
  5. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    Finished the install. It's pretty cool. I discovered that the fusebox actually has an opening in it in a very convenient location and there is no need to drill a hole. I didn't add the headlight relay so for now the DRLs will stay on day and night. Thanks again for all the help.
    Here's a pic of the opening in the fusebox:
    [IMG]
    1 people like this.
  6. Offline
    cproaudio Speedlock Overrider
    Jul 7, 2010
    1,590
    344
    CA
    Your Vehicle Year:
    It's not the flasher. The switchback circuit design still needs work. I have to use Amber-Off because the switchback is installed in the tail light. Tying the white LED with Amber LED with a diode will not work. I've tried it already. It still flashes with white before the amber. In order for the amber to flash without the white, the white LED must be powered up before the amber starts to flash. The only way to get the amber flash by itself is to power up the white LED in the duration of the flash. I have built a circuit using relays, caps and diodes to do this. Autoilluminations will not take responsibility for their cheap design and will blame on the user on every complaint. Since they can't design the amber flash without the white, I had to do what I can with what I have.
  7. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,464
    378
    Your Vehicle Year:
    It's not very clear from the picture where exactly the opening is. Did you mean the port where the bundle of cables enters the glove box?
  8. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    Assume you meant Fuse box, not glove box.
    Kind of.
    Here's a closeup:
    [IMG]
    [IMG]
    It's on the neck opening that the big bundle enters, but it's a separate opening on the top of the neck, right below the left snap that holds the cover on. You can easily fish a wire through that opening and into the middle of the fuse box.
    1 people like this.
  9. Offline
    Yaumeister New Member
    Jun 15, 2009
    23
    United Kingdom
    Your Vehicle Year:
    Would someone kindly provide more details on how I remove the dash to get to the flasher module location?
  10. Offline
    Mar 24, 2008
    3,578
    617
    Los Angeles
    Your Vehicle Year:
    Hello, welcome. The flasher is located under the dash that is in a panel of other components...[IMG]
    you have to pop the under dash under the steering wheel,well on a left hand drive anyway. you will see the cover as shown in the above pic,
    [IMG]
    On a right hand drive, the module may still on the bottom left side. They may have mirrored all the parts and pieces for your car.
    Here is a link for Gen II Stereo install, but it covers dash disassembly!
    http://priuschat.com/forums/attachm...al-dice-install-help-prius_stereo_removal.pdf
    Hope this helps. PM me if you still have questions!
    Good Luck mate! :D
  11. Offline
    Aug 14, 2006
    18,152
    3,450
    Sacramento, CA.
    Your Vehicle Year:
    I forgot about this thread. Such a cool idea and an excellent write up!
    1 people like this.
  12. Offline
    TheForce Ron Paul 2012
    May 30, 2005
    3,429
    438
    Wheelersburg, Ohio
    Your Vehicle Year:
    Have you had any issues with the LED flasher unit not working? Mine has quit working twice since I got it and a simple unplug and plug back in fixed the issue.
    I reinstalled the stock flasher so I would not have to put up with the LED flasher not working. I don't want to get pulled over for not using a turn signal. Plus I think the faster flashing might grab peoples attention better.
  13. Offline
    Jul 7, 2010
    1,590
    344
    CA
    Your Vehicle Year:
    Never had that problem since I installed the flasher.
  14. Offline
    Mar 24, 2008
    3,578
    617
    Los Angeles
    Your Vehicle Year:
    Neither have I! The system is working fine!
  15. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    The flasher hasn't quit, but it does have problems with the lock/unlock flashing. Sometimes it works, most times it either doesn't flash at all or has a super short flash.
  16. Offline
    Mar 24, 2008
    3,578
    617
    Los Angeles
    Your Vehicle Year:
    If it were me, I would just replace the module in question.
    Buy a new one, it's 8 bucks or so.
    Don't beat yerself up over it! :D
  17. Offline
    Jul 7, 2010
    1,590
    344
    CA
    Your Vehicle Year:
    The lock, unlock flash works fine too. Never had a problem with mine. I do have to note that my flasher is flashing incandescent bulbs for the front, LEDs for the mirror and relays for the rear.
  18. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    Yeah, but I'm not the only one with this problem. I suspect if I bought another one I'd have 2 flashers with the same problem.
  19. Offline
    May 30, 2005
    3,429
    438
    Wheelersburg, Ohio
    Your Vehicle Year:
    My LED relay when it works would only flash every once in a while when locking the car. When it did flash it was very short. Almost not enough time for the LEDs to get full power.
  20. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    That's exactly what mine does.
Share This Page
