How accurate is the estimated miles left in tank?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by yazyazoo, Jul 24, 2014.
  1. yazyazoo
    yazyazoo Junior Member
    47
    TriState
    2014 Prius Plug-in
    I was wondering how accurate the estimated miles in the tank is? For the next two days I will have a 204 mile commute. The Prius estimates I have 210 miles left. Should I be able to make it?
    Also does the estimated miles also include EV miles from charges?
    Thanks.
  2. JC91006
    16,470
    8,383
    That estimate can be off by 80 miles, almosr 2 gallons should still be in your tank. But just to be safe, I would fill up before leaving.
  3. yazyazoo
    47
    TriState
    2014 Prius Plug-in
    So you are saying that they underestimate by 80 miles?
  4. JC91006
    16,470
    8,383
    Yes
  5. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I can also attest to this.
  6. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Of course, if the commute for the next two days is at an unusually high mpg, you won't... You might want to reevaluate after the first day, and remember that the estimated range includes the EV miles. Having managed a couple of 1,000 mile tanks, I now fill up around the second pip.
  7. ETC(SS)
    6,493
    YMMV.
    "My" Prius (2010 G3) has an 11.8 gallon tank if the manual is correct.
    I drive until I hear the BEEEEEP and the MDF tells me that I'm low on gas.
    This happens when the DTE=20.
    Then I drive another 50-70 miles and I'm able to put as much as 10.2 gallons into the tank.
    If my car gets 50 MPG this means that the DTE value is off by even more than 80-gallons.
    The Pips have a smaller fuel tank, but I'd be willing to bet that they have a working reserve similar to my garden-variety G3.
    The important thing is to determine what your car has for range when the last little bar starts flashing - or?
    You can put the give-a-crap switch in the "don't" position and just get fuel when the beeeeeeeep happens.....or a little bit before that....or a lot before that.
    I'm not sure how the Pip treats EV miles, but my guess is that it's similar to the how the EV miles are treated in the plebeian G3.....they just have to add a zero since the Pip is good for 10 miles in EV instead of just one.
    Good Luck!
  8. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    I just keep an eye on the Fuel Level display in Torque and decide from there when to fill up if I'm trying to push the tank as far as I can. Definitely have close to 2 gallons (in my PiP) when it beeps and goes to flashing pip. Most often, though, I wind up having to top off the tank before a road trip anyway, so I never even get that far.
  9. bisco
    48,969
    it's only as accurate as your current mpg's equal the average mpg's it's based on. for me, my mpg's don't change much. and with the 2 gallon reserve, there's nothing to worry about. when the last pip starts flashing, look for a gas station, because it won't warn you again. and it does include ev charge.
  10. yazyazoo
    47
    TriState
    2014 Prius Plug-in
    Last PiP flashing? I haven't seen this. I have only filled up twice and usually fill when there are two bars left. Is there a picture of a PiP flashing when the fuel is low!
    Thanks everyone for the replies.
  11. JC91006
    16,470
    8,383
    The meter goes down to 1 pip first, then next level down would be the flashing......then you run out of gas.
    #11 JC91006, Jul 24, 2014
  12. markabele
    5,084
    1,782
    Nebraska
    I usually fill up when I've used about 9 gallons. Easy to know when that is with our PiP's.
  13. GenSao
    GenSao Junior Member
    Pleasant Hill, CA
    2014 Prius Plug-in
    When I am either on the last pip or when it begins to flash, I get gas shortly. The average is a little more than 8 gallons per fill up.
  14. KV1955
    KV1955 Member
    49
    36
    Manassas, VA
    2014 Prius Plug-in
    I just filled yesterday. The last pip wash flashing and the computer said that I had 5 miles remaining. Took 8.5 gallons, so still almost 2 gallons remaining in tank. (BTW.......927 miles on that 8.5 gallons!)
  15. retired4999
    2,652
    625
    Eau Claire, Wi.
    I tried to get a picture of flashing bar, but all I could get was a picture of one bar or a picture of no bar.
    My picture would just not flash! Sorry. ;)
    markabele and iluvmacs like this.
  16. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    I've seen mine flashing 1 bar... It works! LOL
  17. Biking Maniac
    Biking Maniac Five Prius – have not sold one yet!
    58
    Menomonie Wisconsin
    2001 Prius
    I am curious about the statement that DTE includes EV. I recall having my DTE down to 5, but had kept 10 in EV so that I could get to a gas station if I needed to. Of course, like others it only took 8.5 gallons to fill. Darn, it will be 2 months before we need gas again, so I cannot verify this anytime soon.
  18. bisco
    48,969
    check your dte with an empty battery, the check it again after charging.
    #18 bisco, Jul 24, 2014
  19. ryankokesh
    ryankokesh Junior Member
    33
    iPhone
  20. 3PriusMike
    2,938
    2,288
    Silicon Valley
    The DTE does not just add 10 miles for EV. It takes into account your EV estimate and your battery SOC. If you drive down a long downhill you can watch your DTE increase.
    Mike
