How can I set it to unlock all doors when I open the driver's door?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ImaO, Sep 17, 2014.
  1. ImaO
    ImaO New Member
    US
    2014 Prius Plug-in
    I have a new 2014 Plug-In. The manual claims that there is a setting (settable through the nav system setup screen?) so that when I open the driver's door, it will unlock all the doors. I can't find this setting. At the moment, it does a very weird thing. Specifically, when I open the driver's door everything else stays as is (usually locked), whereas when I open the passenger-side front door, all the doors unlock. I don't know why this is the default behavior, but I'd really like it to do "unlock all" when I open either the driver side or passenger side front door. Any advice?
  2. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Hold the Lock and Unlock buttons on your remote at the same time for about 5 seconds. You will hear a beep. Try to lock and unlock. If it doesn't work, repeat process. This is discussed somewhere in the Owners Manual. I believe there are three different modes if I remember correctly.
    iplug likes this.
  3. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Just 2 modes. Unlock all, or unlock driver's door only.
    48,962
    that's how i changed mine to unlock all when touching the drivers handle. took a few tries, it's in the manual, but a poor translation imo.
  5. iplug
    iplug Senior Member
    2,447
    1,695
    Rocklin, CA
    Thanks for posting. Same issue here, but never got around to looking up the solution. It works.
