How do you change the License LED? Getting Access seems very difficult!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by arek, Jan 5, 2013.
  1. arek
    arek Junior Member
    97
    Just got my 194 wedge bulbs. Took a look tonight and it looks very hard to access? Do you need to remove the silver panel? Don't see a way to remove just the lens covers! Anyone have any idea.?
    Arek
  2. lensovet
    2,614
    495
    Burlington, NJ
    you get access to the LP lights from the inside of the hatch. consult page 516 of the manual PDF linked to in the FAQ (or page 519 of the paper manual).
    Totmacher and arek like this.
  3. grodnyc
    grodnyc Junior Member
    24
    Long Island, NY
    With my luck, when I was taking out the base bulb, it fell and it went inside of a small hole. Now I hear it there behind the black plastic rear door cover. Does anyone know how to take out that plastic cover so that I can I retrieve the base bulb?
    Thanks
  4. arek
    arek Junior Member
    97
    Yup, did it last night. Very easy!
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The plastic hatch cover just pulls off. The only trick is that u have to start from the top where the hinges are & work ur way down where the latch is
  6. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Where did you get the bulbs? How much were they?
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Thanks for posting the info on how to get at the OEM bulbs- I have some leftover 194 LED wedge bulbs- I wanted to use them for the license plate- but thought it was going to be a major ordeal to get access. Looks pretty easy though...
  8. ny_rob
    1,968
    813
    L.I.- NY
    There's tons of them on amazon and ebay...
    Amazon.com: 194 wedge led
  9. Ed Burke
    Ed Burke Junior Member
    32
    Long Island, NY
    There are two interior access panels designed to be pried out from only one end, on the inside of the hatch, take your time do not be impatient and you can remove them without damaging anything. Then the bulb holders can be removed from the inside, see the owners manual for how to replace the license plate bulbs. It took me about a half hour to do it all and I damaged nothing. I also replaced the Back Up lights with LED Bulbs so they all look the same at night.
    lensovet likes this.
  10. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Thanks. What color did you go with? Warm white? Did you use these on the interior as well?
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Do cool white. If u do warm white it will look just like the incandescent bulbs that are in there now
  12. ny_rob
    1,968
    813
    L.I.- NY
    I don't think any of the cheap 194 wedge LEDS on Amazon/Ebay are actually warm white anyway (no matter what they advertise). From what I've seen/purchased- they all have some blue tinge.... even the $20 per set Wedge bulbs.
    I used these for the lic plate illumination: Amazon- 4x 194 168 5-SMD White High Power LED Car Lights Bulb They're no better than any of the Ebay $1 LEDS, but I had enough stuff in my shopping cart to get free shipping- so I ordered them. They have a blue tinge, but they're OK for the lic plate illumination as there's no other white light's back there to compare them with...
    Here's the one I bought for the two front map lights:
    http://www.ebay.com/itm/US-Ship-Car-LED-Interior-Bulbs-Panel
    They also have a slight blue tinge, but for $4 (x2) I can live with it and it's very bright and plug-n-play.
  13. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Make sure you pry from the slot close to the trunk window with flat screwdriver
  14. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Thanks. Would the panel lights also work in the rear dome light or do I need something else?
  15. ny_rob
    1,968
    813
    L.I.- NY
    Yeah, it fits perfectly....
  16. ny_rob
    1,968
    813
    L.I.- NY
    And here's the map light with the same panel...
  17. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Awesome -thanks!
  18. ny_rob
    1,968
    813
    L.I.- NY
    I wasn't really happy with the fit on the LED's I mentioned in post #12, I ordered two of these LED replacements for Malibu Landscape light 6 LED SMD SMT 194 and am extremely happy with them for the lic plate illumination- they're actually a real white- no blue- and brighter than the OEM incandescent bulbs.
  19. lensovet
    2,614
    495
    Burlington, NJ
    ok honest question…LP lights?? those would be the last lights i would think of changing…i mean…do cops pull you over because they have trouble seeing your plates? you never even see these lights yourself…
  20. lopgok
    lopgok Member
    177
    29
    unknown
    I have been pulled over because my license plate light was out.
    I replaced my lights because
    1) the leds use about 1w each rather than 5w each
    2) they cost $2 for both
    3) I will never have to deal with it again or worry about bulbs burning out.
    4) They are brighter
    I used the one that have 4 5050 leds on one side, and can be mounted in either orientation.
    Some of the flat circuit board types are too long to fit, but they can be used on the interior..
