1. Offline
    meannotgreen New Member
    Jul 10, 2009
    Message Count:
    33
    UK
    Your Vehicle Year:
    Am I right in thinking that to leave B mode you move the shift lever to D even while you're still moving?
    Can't find the answer in the manual - it only tells you how to move to B and otherwise generally warns against changing modes when the car is moving.
  2. Offline
    Therand New Member
    Jun 22, 2009
    Message Count:
    31
    Atlanta, GA
    Your Vehicle Year:
    I've only done a few hill tests with "B" mode but selecting "D" while moving works fine. I would have a hard time believing switching between "B" and "D" while driving would be a problem since there are plenty of Interstates that have 5-6% grades.
    1 people like this.
  3. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    Yes, just switching back to "D" while driving is correct.
    2 people like this.
  4. Offline
    Jul 10, 2009
    Message Count:
    33
    UK
    Your Vehicle Year:
    That's what I thought and likewise I've tried it a few times and it works ok. I think I'd just like to see it written down somewhere for peace of mind!
  5. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Only modes you shouldn't select while moving forward are reverse and park.
    Switch between B and D with gay abandon and complete impunity!
    1 people like this.
  6. Offline
    Mike Dimmick New Member
    Aug 8, 2008
    Message Count:
    959
    226
    Reading, UK
    Your Vehicle Year:
    If you try it and you're travelling sufficiently fast, the car will switch to neutral rather than try to do what you asked.
    Warning: the Gen 2 seems to consider less than 5 mph slow enough to go into Park! You get a nasty slam stop if you're still moving. I hope I didn't damage any part of the transmission when I hit the button a bit early that one time...
  7. Offline
    Therand New Member
    Jun 22, 2009
    Message Count:
    31
    Atlanta, GA
    Your Vehicle Year:
    I haven't had any issues switching between "D" and "N" either. Note - it takes a second for the shifter to acknowledge shifting to neutral but it works just fine.
  8. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Keep in mind that you can overspeed MG1 by coasting in N. If you switch to N when the ICE is off, the ICE will not spin even if it needs to control the speed of MG1. In other words, coasting down a steep hill in N can be hazardous to your HSD.
    Tom
    5 people like this.
  9. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    And is illegal in some (if not most/all) states.
  10. Offline
    lamontcranston Umbra Tenet
    Jul 28, 2009
    Message Count:
    207
    Southern California
    Your Vehicle Year:
    OK, I did some google searching and figured out what those abbreviations mean.
    Do you guys find that you use "B" a lot? I know someone with a Prius and he didn't even know what "B" did.
  11. Offline
    FBear Senior Member
    Nov 1, 2004
    Message Count:
    345
    Maplewood, NJ
    Your Vehicle Year:
    It stands for Motor/Generator 1.
  12. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    Enough about sheep, Pat.
  13. Offline
    creativeguy New Member
    May 21, 2009
    Message Count:
    296
    17
    CA
    Your Vehicle Year:
    This is true. I rented a Prius and accidentally put it in reverse while driving on the freeway at high speeds. The car beeped at me, I think, and otherwise nothing else happened.
  14. Offline
    Kds45 New Member
    Mar 26, 2008
    Message Count:
    South Bend, IN
    Your Vehicle Year:
    I use it some. I jump back out of it as soon as I can, because you can't use Cruise Control when in B. The only big test I gave B was going East over Monteagle, TN. B held me at perfect speed until the grade leveled, and then I just slipped back to D and went back on Cruise.
  15. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    Message Count:
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    Specifically, if you exceed 62-63mph MG1 will spin over 10k rpm.
  16. Offline
    swich2mac Go Hard or Go Home!
    Apr 24, 2009
    Message Count:
    175
    Nashville, TN
    Your Vehicle Year:
    I am a first time Prius owner and I have no Idea what the "B" mode does! ;)
  17. Offline
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
    It gives you engine braking in addition to applying some regenerative braking (when you are not pushing the throttle of course). If I remember correctly the regen braking from B Mode was about 50% of what you could get from applying maximum regenerative braking in D. It acts sort of like low range in a conventional automatic transmission.
    The only use I ever found for it was coming down a long steep hills with the battery at a fairly high SOC. Then it will save some wear on the friction brakes.
    On the Gen2 again, and almost certainly on the Gen3 as well, if you forgot and left it in B it would shift itself back to D after some number of minutes, maybe 5 or so. Also as previously stated the cruise control won't work in B which can act as a reminder.
  18. Offline
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Evan is one of the brave (stupid? ;)) test pilots that have experimented with this limit.
    Tom
  19. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    98% of the time I leave B mode alone. :D
  20. Offline
    MaggieMay New Member
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    On steep hills and grades - B is awesome. It's a little like downshifting in a normal car, except that it really holds the car back. My guess is that if you live in a fairly flat to rolling hills geography you won't use it.
Share This Page
