How do you put the Prius in neutral to push or tow it?
Discussion in 'Gen 2 Prius Main Forum' started by pumpiniron, Sep 14, 2008.
  1. pumpiniron
    pumpiniron New Member
    42
    Scottsdale, Arizona
    Ok so I have a wrecked Prius. The car doesn't start or even turn on. I'm wondering how you go about pushing the car in neutral? As far as I know you can not get it in neutral without the car being on since the transmission is shift by wire. Is there a way to manually put the car in neutral so I can push/tow it?
  2. rigormortis
    rigormortis Active Member
    1,328
    san jose, ca
    if the car will not turn on, at least to the point of being able to be "ignition on" and not ready (push power button on twice without foot on brake), theres no other way to put it in neutral. your going to have to jack it on rollers to tow it.
    i think a tow truck can still lift it from the front and tow on its rear wheels, but watch out for the angle, too high of an angle can dent the rear
    only the pre 2004 prius had a mechanical release for the parking brake
    this is pretty much what the emergency response guide says.
  3. pumpiniron
    42
    Scottsdale, Arizona
    I guess I can thank Toyota for not thinking of this one.
  4. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    Hopefully Hobbit or one of the other Prius gurus will chime in but, I thought I heard once that there is a mechanical way to disengage park from under the car.
  5. rigormortis
    1,328
    san jose, ca
    according to the official toyota response guide, there is no way to disengage park
  6. pumpiniron
    42
    Scottsdale, Arizona
    Technically speaking there should be some sort of way. The idea of the transmission being shift by wire would mean that at some point in the system there would have to be a solenoid of some sort that the computer would control to shift the gears.
  7. Rangerdavid
    Rangerdavid Active Member
    1,324
    Boone, North Carolina
    I'm not aware of any way to do what you are asking. It can be towed though, although you may not want to watch.............
    RD
  8. rigormortis
    1,328
    san jose, ca
    the only way to move a prius that will not turn on (2004- present) is to put it on a towing dolly/wheels, or tow it from the front (i think) period, end of story. do not pass go, do not collect $200, regis that is my final answer
    concentrate your efforts on getting that car turned on instead, once its turned on, the flood gates are open and you can push it all you want. its just not a good idea to tow it in neutral with all 4 wheels on the ground for extended periods, because the transmission is always in gear
    dbcassidy likes this.
  9. Patrick Wong
    16,040
    4,094
    In theory, the manual way would be to raise up the vehicle front, and remove the shift control actuator assembly from the transaxle case. Then it would be necessary to rotate the parking pawl to disengage.
    However this will be messy, so it would be best to either figure out how to power the Prius up (perhaps it needs a new 12V auxiliary battery?), or else raise up the front and tow it.
  10. qbee42
    qbee42 My other car is a boat
    18,040
    2,984
    Northern Michigan
    Patrick is correct. You can mechanically remove the parking pawl assembly, but this is more bother than simply using a dolly.
    Tom
  11. zaxinc
    zaxinc New Member
    67
    Los Angeles
    This is a classic case where technology overlooked the simple things.
  12. hobbit
    hobbit Senior Member
    4,086
    423
    Bahstahn
    The little 3-phase drive motor is on the back of the tranny under
    some fiber shielding and *very* close to the firewall and frame
    members, and would be pretty difficult to remove with it still
    in the car. There's a shot of one opened up in my training slides.
    It pretty much works like a stepper motor.
    What surprises me, at least as far as I know, is that Toyota
    doesn't have a tool to plug into where the transmission ECU is
    under the passenger-side dash and simply drive the pawl motor
    from an external source. It wouldn't be that hard to build.
    You could theoretically do it by powering the correct wires
    in sequence but with that 60:1 reduction it would take a while
    to spin the thing far enough to completely pull the pawl.
    _H*
  13. EZW1
    EZW1 Active Member
    677
    48
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Toyota says DO NOT tow a Prius by the front wheels. Doing so would spin HSD with MG2, generate electricity, and possibly burn wires. They say the only way to tow a Prius is with the back wheels on the ground.
  14. rigormortis
    1,328
    san jose, ca
    yeah maybe i stand corrected, i thought i heard it was okay to tow it for short distances with all 4 wheels on the ground in neutral for short periods. a short period would be defined like a mile or two or just enough so you can move it to tow it properly... i thought this scenario was mentioned in the emergency guide as well, and that was what i meant in the original post.
  15. David Beale
    David Beale Senior Member
    5,062
    984
    Edmonton Alberta
    Like -ANY- FWD car, "DO NOT TOW WITH THE FRONT WHEELS ON THE GROUND".
    Why is this difficult? Why is this a downside to technological developement? It's the same for all FWD cars. If you tow an "ordinary" FWD car for any distance with the front wheels on the ground you can destroy the transmission - even with it in neutral.
    The -ONLY- difference with the Prius, is you can't even drag it a short distance with the front wheels on the ground.
    ALL towtrucks have dollies as standard equipment (to pull illegally parked cars around the block, for example, without taking them out of "P". ALL towtruck operators would tow the Prius with the front wheels off the ground (for short distances, say up to 10 miles). For longer distances they use a tip-up flat bed truck.
    I don't see any problem here. ;)
  16. rigormortis
    1,328
    san jose, ca
    toyota prius 2007 instruction manual page 373:
    NOTICE I AM NOT ENDORSING THIS DO THIS AT YOUR OWN RISK
    if towing service is not available in an emergency your vehicle may be temporarily towed by a cable to chain secured to the emergency toyowing eyelet inside the front bumper. use extreme caution ... a driver must be in the vehicle to steer and operate the brakes... towing in this manner may be done only hard surfaced roads for a short distance at low speeds. wheels axels drive train steering and brakes must be in good conditiion. never tow a vehicle from the rear with all 4 wheels on the ground this may cause serious damage to the transaxle..
    so it is assumed that toyota has no problem whatsoever with towing a prius in an emergency and no towing service is available, with all 4 wheels on the ground as long as its a short distance and under 40 miles per hour.... and not having the car backwards...
    reminder : i said emergency towing. your keyfob not working, you ran out of gas, or you have a flat tire is not really an emergency, this is spefically for a last resort.... and if the car won't power on enough to put it in neutral, you are stuck and have to have it towed professionally
    second reminder:
    the extended warranty comes with free roadside assisance., and if the original poster bought it from prius chat, this whole topic is moot
    if the front wheels are off the ground? then why is there a need for someone to stay in the back to steer?
  17. rigormortis
    1,328
    san jose, ca
    exceeding 42 mph will cause serious damage and ruin and total out mg1
    exceeding 100 mph will casue serious damage and ruin and total out mg2
  18. hobbit
    4,086
    423
    Bahstahn
    Low speeds is the key phrase. See my generated EMF analysis
    and consider how high you'd want to let the voltage get inside
    the inverter without any of its electronic monitoring/control.
    You could certainly push the car across the shop or yard, but
    high speed in a powered-off state seems inadvisable.
    I think Bob Wilson's got a detailed and fairly hairy towing
    story from a little while ago... in an NHW11, which is a little
    different.
    _H*
  19. David Beale
    5,062
    984
    Edmonton Alberta
    In order to tow as posted with all four wheels on the ground you -will- need the FOB, because you -will- need to have the car in "N". That part was missed in the above post.
    I -think- you could have the car left in "N" if you shut it off while moving (it shifts to "N" if you do this). I haven't tried this so I'm not sure if it goes into "P" when it stops.
  20. statultra
    statultra uber-Senior Member
    789
    cape coral, FL
    if u have a 12 volt battery, shift it into neutral by turning IG on.
    if u cant do that, pull the shift cable until u know its in neutral
