How do you remove the cover on hatch?
Discussion in 'Gen 2 Prius Main Forum' started by Brian, Apr 6, 2004.
  1. Brian
    Brian Member
    480
    Bakersfield
    I am trying to get behind the cover on the hatch to look about putting the camera on. Please help me get the cover off, it is quite hard. Anyone know???
    Thanks
    Brian
  2. Brian
    Brian Member
    480
    Bakersfield
    Here is a picture I took to better justify my question. I hope this helps!
    Brian
  3. ajpalm
    ajpalm New Member
    22
    Hi Brian,
    The answer is really 'just pull'
    That bottom black plastic panel is held in by plastic lugs. Start on the side that the handle isn't on and pull.
    Using a soft but strong rod to help lever is how the manual (service) says to do it. There example was a screwdriver wrapped in tape.
    Once you get the first couple off, you will work out how the rest come. There is 11 lugs.
    To put it back on, just line it up and PUSH!!
    Andrew
  4. csommers
    csommers New Member
    Camera? I've no doubt missed an earlier post.
    Are you installing a rear view back-up camera?
    chuck
  5. Brian
    Brian Member
    480
    Bakersfield
    I am not now, there are no wires back there that are ready for a camera, and as some people have said, that there is no immediate plug-in for a camera either.
    Brian
  6. ajpalm
    ajpalm New Member
    22
