How soon should you get an oil change after the Maint Reqd light stays on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hiro Protagonist, Mar 28, 2011.
  1. Hiro Protagonist
    Hiro Protagonist New Member
    It seems like a silly question, I know. This is my first Prius so I'm still in the dark about a lot of things. I've put about 5000 miles on it since I picked it up from the dealership (used, so there's about 21,000 miles on it).
    My Maint Reqd light has been blinking for about a week, and meant to take it in this weekend to get an oil change but had no time. This morning on the highway (I commute ~45 miles each way every day) the light comes on and stays on (which makes sense if the dealership reset the maintenance data when I bought it).
    Normally I'd take it in for an oil change this afternoon, but that may not be possible. I know the light illuminates based on a mileage meter and not an engine condition (ie low oil).
    It may be the case that I can't take it in until this weekend. I'm just wondering if it's wise to keep driving it this week knowing I need an oil change and that I'm likely to put ~450 miles on it. I checked my oil this morning and it doesn't seem terribly low.
    Should I top up the oil to keep it humming until the weekend? Should I just drive, since driving it for a week won't be an issue?
    Help! :D
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Which particular Prius model do you have (gen1, 2 or 3/2010)? or what year is it?
  3. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Like you said it's a mileage thing, not low oil - the light comes on in Gen II at 4500 miles, so it's more a heads-up than a problem light. I'm sure if you go 5500 miles instead of 5000 you should be fine, just go a week and have it changed.
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Personally, I just reset it.
    I have gone to a 6-month, 6,000 miles routine using full synthetic oil. So when my light comes on at 4,500 miles, it means nothing to me.
  5. Hiro Protagonist
    Sorry, should have clarified. It's a 2008 model.
  6. Patrick Wong
    18,199
    6,464
    It's OK if you change the oil at 5,500 miles. Since the powertrain warranty coverage for the engine requires you to change the oil at 5K miles or 6 month intervals (whichever comes first) I suggest that you not delay that service beyond the coming weekend.
  7. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Just follow Patrick's instructions. You won't ever be wrong. :)
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    It's not a low oil indicator, just a straight mileage thing. But it's always a good idea to check your oil level from time to time. You only need to add oil if it's low on the dipstick.
  9. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    i have a different take on this.
    after 5,000 miles on my '06, the oil level has not moved from when it was previously filled. additionally, the oil is very, very clean.
    the reason for this is that the Prius engine runs very little vs a conventional car.
    i sometimes go to 7,500 miles. remember..the Gen3 manual now says 10,000 miles between oil changes.
    personally, i believe that Gen2 is fine running standard oil 7,500 miles.
