How to boost FM reception?
Discussion in 'Gen 3 Prius Audio and Electronics' started by MeetGeorgeJetson, May 28, 2015.
  1. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    Installed my new Pioneer HU and damn if its not worse in the FM reception dept then the stock radio. Any ideas on how to get better reception?
  2. mrbigh
    3,686
    699
    Long Island, NY
    The car built in antenna it is amplified........
  3. FrankB
    FrankB Member
    117
    53
    Assuming the question is for a 2010 or 2011, the beige wire going to pin 8 on the 10 pin connector needs 12V to power the amplified antenna.
  4. MeetGeorgeJetson
    48
    33
    Woodstock NY, USA
    Hmmmm. dont know if it is amplified, but I followed the Crutchfield instructions to the T, everything else seems to be working fine. The antenna jack went straight into the Pioneer, no adapter.
  5. douglasjre
    douglasjre Senior Member
    1,773
    617
    Orlando, FL
    Where is the beige wire and the ten pin connector
  6. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
  7. essay o
    essay o New Member
    Tecumseh, MI
    My new to me 2012 PriusV gets TERRIBLE FM radio reception. Is the tiny shark fin the antenna? Toyota needs to be informed this antenna really is worthless. How to install a Good reception antenna
  8. Attila Fekete
    Attila Fekete Member
    164
    58
    Budapest, Hungary
    The shark fin is not the iriginal Toyota antenna, which includes the amplifier too.
    Maybe the amplifier is missed in the replacement.
