How To: Change Headlamp / Headlight bulb
Discussion in 'Knowledge Base Articles Discussion' started by usbseawolf2000, Oct 20, 2007.
  1. Tideland Prius
    16,073
    Hey!
    it should be the same. I'm unaware of any changes made to the back of the headlights for 2006+ models.
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Hi Windstrings,
    Don't you have the HIDs on both your Prii? (In which event, the halogen installation procedure is not applicable.)
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    No difference as mine is 06 model year.
    BTW, how are everyone's Extreme Power bulb doing?
  4. Boo
    5,051
    483
    97
    Flushing, NY
    Mine are fine ... but I only have 2000 miles on them so you can't judge by me.
    I too wonder about how Tideland Prius (and others) are doing with theirs.
  5. Tideland Prius
    16,073
    They're working fine. They're dimmer not because of the bulbs (I don't think) but I strongly believe the 12V battery is dying.
    I've left the Prius at home so I hope my dad gets around to replacing that battery before the car strands him in the middle of street or something because the 12V ran out of juice to run the electronics.
    My right parking light did blow out in March. Replaced it with one of my "old" bulbs lying around when I switched the licence plate lights (LED)/map lights (The free ones from Powerbulbs).
  6. windstrings
    windstrings Certified Prius Breeder
    6,278
    373
    Central Texas
    Hey Tideland, unless your car is only in accessory mode, shouldn't the inverter maintain proper voltage to the 12V whether the battery itself is weak or not?
  7. Tideland Prius
    16,073
    I suppose. It is a little worrying though. Turning on the lights for barely a min (i'd say 30 secs) in ACC or IG-ON mode and you can see the lights get dimmer and dimmer and the "taillight on" light disappear and then eventually teh radio will stutter around the 1 min mark.
    Turn the car on (READY) and everything's back to normal.
  8. windstrings
    6,278
    373
    Central Texas
    Yep, thats what it sounds like....a weak 12V battery... the inverter supports the 12V voltage while in ready mode.
    Sounds like you knew that.
    How long can you run "once the car is fully charged and in ready mode" before the ICE kicks in?...
    I think it may be a bit trickier figuring then the "main" battery is getting weak... but thats another subject.
    My Right headlight is starting to flicker off intermittently... when I turn the lights off and back on, I can usually re-fire the HID bulb, but its hold a blue hue till it warms up like the other one.
    I somehow think it may only be the bulb. If it were anything else, I don't see why refireing would help.
    But knowledge is power, I sure feel better about tackling the job after reading your instruction sheet.... thanks for going to the trouble.
  9. Tideland Prius
    16,073
    No idea, I didn't time it. It doesn't seem anything out of the ordinary.
    Could it be the wire has some corrosion on it? I do not know.. just firing out ideas.
  10. jerry62
    jerry62 Junior Member
    Southeast Wisconsin
    Been a long time...
    First, I went over 98K miles on my 2005 Prius I obtained in late 2004 before my driver side low beam stock headlight went out. And I ALWAYS drive with the headlights on. Always. The original passenger side is still fine (although I replaced it as well, today).
    I was confused about which headlight to get, so I checked out Prius Chat and other online info, 9003 HB2. I bought a pair of these cheap GE 9003 puppies for about $12 at Wal-Mart (that's the total price for 2, not individual bulbs), but I thought why not, I'll give them a shot.
    I took close up pix of the original lights and the GE's if anyone is interested. The original lights say "DOT HB2" at the far right, and the GE's (which appear to be made in Hungary) say "HB2 DOT" near the top, with the etching having a brown burnt look to it, as opposed to a clean etch on the original lights.
    What a pain to install these things! If I could only have another half-inch on the driver side (move that fusebox back, use smaller fuses, whatever), it would be so much easier to work with! And what's with the screw-plugs? Sorry, but I'd be happier with a traditional screw. If they wanted a plug, I'm certain there's something easier to work with.
    Anyway, hopefully I'll get another near-100K out of these lights as well.
  11. resoh02
    resoh02 Member
    140
    Northern OHIO
    I went to Toyota Dealer and they said you can only use Toyota bulbs and for them to put one in would be 300.00. I don't have HID they are std. headlights. Love the Toyota Dealers
  12. windstrings
    6,278
    373
    Central Texas
    If they thought they could get away with it they would tell you, that you had to go to them because only their tires would work when yours wore out.
    Knowledge is power.... the one that has more than the other wins.... hence the beauty of this forum.... it prevents the wolves from taking advantage.
    I bought my HID bulbs from ebay "Stan".. they cost me 69.00 for two...thats right... I said HID... not halogen.....
    so I bought 4 since I have two cars.....
    They all work perfect.
    They went up to 99.00... now they are back at the sale price for "buy it now".... 69.00 a pair
  13. Boo
    5,051
    483
    97
    Flushing, NY
    LOL.
    If they charge $45 for the OEM halogen bulb, that means they want $255 to install one bulb. My mechanic/body shop guy charged me $15 to install TWO bulbs.
  14. pinball
    pinball New Member
    121
    Surrey UK
    The guy in my local auto shop says they'll be getting the Philips X-Treme Power bulbs in soon.
    He did say that because they burn hotter, cars with plastic headlamp covers need to be careful as the heat could warp or even discolour the cover.
    Anyone experienced this ?
    Pinball
  15. resoh02
    resoh02 Member
    140
    Northern OHIO
    Installing Boot, if you start the connector in the boot before installing connector, line up the top of boot to top of connector. Push connector just enough so the boot holds the connector, now install connector on pins and turn boot clock wise to install..Thats it. :(
  16. Tideland Prius
    16,073
    Not sure but they do get quite hot, yes.
  17. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I had the original Silverstars on my 2005 Tundra. I put 26,000 miles on them before i sold the truck in March 2008. They were nice and bright and stood up well. They were only used at night and during the day and also when offroading in conjunction with my front and rear amber lights (high and low mount) also Sylvania bulbs in those.
    I just picked up a set of the Silverstar Ultras today because Kragen had a $20 off coupon in the paper. Will probably put them in tomorrow afternoon if i can figure out how to get to the area.
  18. Tideland Prius
    16,073
    Let us know how they compare.
    My X-Treme Powers are still running.
  19. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Sounds good. Mine must've been a fluke.
    My Philips Vision Plus bulbs are still running.
  20. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    So my passenger side headlight finally went out yesterday, and I replaced it with the OEM I bought last year. For whatever reasons, the passenger side lasted 9 months longer than the driver side :confused:
    Ordered a pair of Philips Vision Plus from http://www.motorbulbs.com for $30. Free shipping and cheaper than PowerBulbs ($36).
