How to change trip summary to reflect fuel cost versus fuel savings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusLuv6777, Jul 31, 2015.
  1. PriusLuv6777
    PriusLuv6777 New Member
    Gr8 Lake St8
    Is there a way to change the trip summary to reflect the cost of each trip when the car shuts off vs. the savings? Thanks in advance!
  2. JC91006
    16,464
    8,377
    Mine shows fuel cost, not savings
  3. PriusLuv6777
    Gr8 Lake St8
    I wish mine would show the trip cost instead of comparing it to whatever the salesman put in as a comparison consumption last month when I bought the car!
  4. JC91006
    16,464
    8,377
    I'm sure it's in the owners manual. But you can get to the menu by pressing "display" on the steering wheel until you get to the main screen. Then hold the display button for a few seconds until the menu pops up. There should be a selection there
  5. PriusLuv6777
    Gr8 Lake St8
    I've tried everything, I'll call Toyota on Monday!
  6. Blizzard_Persona
    1,784
    944
    Pa.
    2023 Prius Prime
    XSE
    It's under settings. Use the thumb controls next to the trip button. Once in settings you can change it from there. It's a little tricky as you have to hold it down for a few seconds and then adjust as needed.
    Also when you are at your monthly view that shows savings/ fuel costs, use the trip button to change between the two. Little trick I learned...
