How to customize the Splash Screen
Discussion in 'Prius v Main Forum' started by Cactus Hybrid, Jan 3, 2012.
  1. Cactus Hybrid
    Cactus Hybrid Member
    129
    43
    Paradise Valley, Arizona
    Ok, I just figured out how to customize the Startup Image..the instructions are on page 48 of Nav System Owner's Manual. I have the Advanced Tech Package.
    The Image has to be a JPG or JPEG image up to 10MB. On your home PC, you create TWO files on a USB thumb drive, one called "StartupImage" and "DisplayOffImage" (Both Case sensitive). You put the files (images) that you want, inside the "StartupImage" folder. You then go to your Prius and plug into the USB port. You then go into Setup -> General -> Customize Startup Image. Then just follow the onscreen instructions and your done!
    When the car starts, you still see the Toyota logo for a second, then your custom image for another second, then the system is booted.
    I now can enjoy my Kids picture before every trip!
    ZPriusV5, DGH, tanasit and 2 others like this.
  2. hibou
    hibou New Member
    35
    Washington, DC
    what a GREAT idea!! I am going to do that to suprise my partner when he gets back from a business trip!!!
  3. thomcat
    thomcat Junior Member
    Ballard, WA
    Must be the advanced package. On the first Setup -> General screen I see two blank bars near the bottom - one of those must be it.
  4. Cactus Hybrid
    129
    43
    In the "General" screen scroll to the second screen under "Keyboard Layout" is the "Customize Startup Image" option.. and Yes, I do have the Tech Package.
  5. mi2k
    mi2k Junior Member
    33
    MD
    Just looked in my v 5 -- not there! :(
  6. jackiemac
    jackiemac New Member
    San Francisco Bay Area
    Bummer, I can't get this to work. I've followed the instructions exactly as in the original post and tried many other variations with different formats (jpg, png, pdf, gif).
    I have a Plug-in Prius (Advanced). Maybe there's a bug in the PIP Nav software?
    Any other PIP owners get this to work?
  7. Quentin
    Quentin Member
    320
    71
    West Virginia
    Might want to check out the PiP forum. :p I don't even have my v yet. :D
  8. NavySeal
    NavySeal New Member
    27
    New York City
    Is this just for the V5 Advanced Tech package or is this available on the V 3 also? Anyone?
  9. Quentin
    Quentin Member
    320
    71
    West Virginia
    Sounds like it is exclusive to the HDD navigation which is only available on the v Five ATP.
  10. El_Spectre
    El_Spectre Junior Member
    71
    BTW, this doesn't seem to be documented, but for the 7" fancy schmancy ATP display, the resolution is 800x480.
  11. AZGeek
    AZGeek Semi-informed Member
    638
    143
    63
    Arizona
    Dang. I was hoping for 1080p. ;)
    iPad ?
  12. ambrothe
    ambrothe Junior Member
    99
    Columbus, OH
    Any one else do this? I'm trying to transfer some pics, have followed all instructions here and in the manual, yet keep getting an "No images found...consult manual for accepted file types" error. What gives?
  13. Selborne
    Selborne Junior Member
    NYC
    I think the flash drive has to be formatted Fat32, not NTFS. That's how I got mine to work.
  14. maurices
    maurices Junior Member
    85
    Sartell, Minnesota
    Thanks for this tip, Selborne, it is not in the manual. I had my USB drive formatted as NTFS, and kept getting a "No images found...consult manual for accepted file types" error. Reformatted to Fat32, works like a charm...
  15. Hesham
    Hesham New Member
    2013 Prius v wagon
    After formatting the drive to FAT32, I still could not upload the images. I then reduced the two Jpegs to 800 x480 which finally ended up working. Even though the original files were under the limit specified in the manual, I can only assume the system has trouble handling large files or images with higher resolution than 800 wide.
    KrisB likes this.
  16. DGH
    DGH Thread Terminator
    332
    53
    Wales, WI
    ++Thanks!
  17. The Electric Me
    The Electric Me Go Speed Go!
    6,905
    2,767
    Undisclosed Location
    You need to get a close up picture of Linda Blair in The Exorcist, sneek that in. Casually mention that you've heard strange noises in the garage. When your partner notices it? Pretend you don't see it.
    Good Times!
  18. Nicaaz
    Nicaaz New Member
    16
    Toronto Canada
    2013 Prius Alpha
    Thanks, it works!
  19. KrisB
    KrisB New Member
    What is format FAT32? How do I do that? ALso what happens to other files that are in the plder format?
  20. KrisB
    KrisB New Member
    I tried all the above woth no success where do I go from here? Help
