1. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    I just purchased a 2005 Prius (80k miles) a few weeks ago and was wondering what some tips are on how to drive and get the most out of it. I tried searching the forums for a sticky on this as well as individual posts but couldn't find exactly what I was looking for. I guess I have a few questions:
    How should you accelerate from a stop? Should you slowly accelerate or hit the gas quicker? How should you drive up a decent sized hill and down the other side (about .5 mi up and .5 down). When driving in general, should you try to drive at a constant speed (i.e. 40mph) or ease off the gas and accelerate every so often. Also, what speeds do the gears change at? I'd hate to ride it on high rpm's on 3rd gear when I should just go a bit faster to lower the rpm's on 4th gear. It's really quiet so it can be hard sometimes to hear the transmission shift.
    Thanks everyone!
    I have a ton of other questions, but I might save those for another post here after some of these get answered or just ask them here in seperate threads on the newbie forum.
  2. Offline
    donee New Member
    Aug 15, 2005
    Message Count:
    2,958
    183
    Chicagoland
    Your Vehicle Year:
    Hi Tom,
    This is an indepth topic with lots of posts around.
    The main thing to start off learning is how the accellerator peddle works. After you accellerate, if you pull back only as far as you are used to in other cars, the Prius will configure the transmission for rapid changes. This means keeping the engine running, and at a higher RPM than neccassary to move the car along at a constant speed. Although the car will move along at a constant speed. To get the car into more efficient configuration, one needs to pull somewhat farther back on the peddle. At some point the car will start to slow down. Over time you will learn how much you can lift and maintain speed. If you exceed 40 mph, the engine will jump back on.
    The engine has its best efficiency about 2000 RPM. When you accellerate form a stop, this is just shy of where the battery will be called upon to provide extra accelleration power. So, initially you will see the yellow arrow on the MFD, then pull back a little until you get a green arrow or no arrows to/from the battery icon. You can increase peddle staying on green arrow as you accellerate. Some people say not to get the loop mode going for the extreme best mileage. But I find that is not practical in traffic. I shoot for either no arrows or green arrows, and avoid accellerations that uses battery. If it starts to loop power between the motors and the engine, so be it. The accleleration doing this way slower than many drivers , and way faster than many other drivers. Kinda in the middle. As the Prius does not have "fuel enrichment" it can accellerate pretty briskly without being too inefficient, unlike standard cars.
    The gears in the Prius do not change. The engine and motors are always rigidly connected to the gears even when the car is stopped.
    The HSD drive on the Prius does change modes. It has an accellerate mode, a glide mode which is kinda like coasting, but its envoked just by lifting off on the peddle just the right amount and way. It has an EV mode - where the car is rolling under electric drive only at slower speeds. it has a slow-speed highway mode which gives very good mileage and only uses the engine (people call this SHM - super highway mode), and it has a higher speed highway mode (typically up above 62 mph). It also has a downhill electric highway mode, where the battery pushes the car along, the engine is still turning, but there is no gasoline being injected into it.
    The gliding mode can be invoked in a warmed up Prius at 40 mph or slower. The engine will turn off and the car will glide along. With a small peddle depression you can bring on the EV mode, and here in Chicagoland this is handy for cresting a small hill in the road and then gliding down the backside. Other cars do not even know you are doing this, as you just maintain the same speed.
    Its not good to use the electric mode for accelleating from a stop. The car does not have sufficiently robust electrical system for that to be efficient.
  3. Offline
    hobbit New Member
    Mar 23, 2005
    Message Count:
    4,089
    443
    Bahstahn
    Your Vehicle Year:
    The transmission as such doesn't shift, it's a smooth continuum
    of effective ratio change all done by regulating torques and
    speeds on electric motors. No mechanical shifting happens at all.
    If you're a technical sort, you might be intrigued by some
    training slides I worked up a while ago [with pix and diagrams
    snagged from Toyota and some of our own tear-downs] which might
    help, and at a minimum you should read Graham Davies' pages
    about running operation as well as john1701a's seminal info
    about it.
    "Optimal" acceleration ranges are fairly generous, as long as you've
    got the engine working reasonably hard [high torque == efficient]
    which generally happens over a wide RPM range and it's just a
    question of how much instantaneous power you want to send to the
    wheels. Gentle, but not totally down in grandma territory, yields
    good results.
    _H*
  4. Offline
    Frayadjacent Resident Conservative
    Mar 22, 2009
    Message Count:
    373
    Austin, TX
    Your Vehicle Year:
    As a newb to the Prius I would say - Observe what is happening depending on where your foot is on the pedal. It's very sensitive, and what it does is dependent on what state the car is in. (it goes through different states as the engine warms up). It's very easy to learn how to get the car to glide and to 'golf cart' at low speeds.
  5. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    Yeah I noticed this, I tend to slightly press the accelerator to get battery only. Thank you donee and hobbit for the insightful information. I guess it will just take some time and forum searches to fully understand it.
    Right now I'm averaging about around 52mpg on rural hilly driving at about 35-40mph, which I don't think is too bad.
  6. Offline
    Ytsejamer1 New Member
    Mar 8, 2009
    Message Count:
    62
    Somersworth, NH
    Your Vehicle Year:
    52mpg sounds about right for 35-40mph rural driving. I did about 40 miles of that today and got around 57mpg.
    I'm still learning how best to deal with stop and go, stop and go, etc...it is cool when sitting next to a car at a stop light and the car just "shuts off"... I'm always thinking about the car idling next to mine..."SUCKAH!!!" ha ha ha...
  7. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    Cool, Cool, I guess I have a few more questions since most of the other ones were answered. These are a bit unrelated, but I think they can fall into the title of this thread.
    Is it bad to "top-off" at the gas pump? I usually pump till it clicks then maybe add in about $.30 more to either round it to nearest dollar or $.50. Is this ok? And when it does fill up, how many pips would you say exist off of the guage, (i.e. whenever you fill up past full, the gauge will sit on full for longer than normal because the sensor is submerged.) Also, how large is my tank (2005) and how much gas does one pip represent (roughly). Lastly, are the pips of equal value, meaning that is the 6th pip the same ammount of gas as say the 2nd to last or last one (depending on the precautionary measure used on empty). Sorry bout all the quesitons, just like to know each feature on everything and how it works, just like my BlackBerry :)
    And I take it, everyone uses 87 unleaded?
    I guess I 've seen the answers to most of the questions above on other threads. Question though, what benefit is the bladder providing? Not really sure why its there.
  8. Offline
    Mar 22, 2009
    Message Count:
    373
    Austin, TX
    Your Vehicle Year:
    I would be very happy averaging 52mpg. I've gotten mine to 46 and change, with only 400 miles on the clock, so I'm happy.
  9. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    It is bad to top-off. It increases hydrocarbon pollution (by saturating the vapor recovery canister with liquid) and can actually damage the fuel tank and its computer.
    The pips have variable meaning from car-to-car and from fillup-to-fillup. The *only* rule is: when the last one starts to flash you are about to run out of gas, no matter how much gas you put in last time or how far you've driven. There's no way to be certain how far you can drive from that point, therefore it is prudent to fill-up before that point.
    Do not drive after running out of gas unless absolutely necessary. The battery will not take you more than a mile in any case, and draining the battery below two purple bars on the display reduces its life.
    Fuel economy short-path zen: Brakes, Battery, And "B" Are Bad; therefore
    - Accelerate briskly; the engine is most efficient near full load.
    - Gliding (no arrows on the "Energy" display) is better than coasting
    - Coasting (arrow into the battery on the "Energy" display) is better than braking
    - Braking is better than stopping
    - Stopping is better than running into something
    Applying these principles in actual driving without inducing road rage in others is left as an exercise for the driver. Ideally one would accelerate to some speed and then glide all the way to the next stop, which is clearly infeasible in most real situations. "B" is to be used only on long downgrades, to avoid riding the brakes.
    Check tire pressures also at least monthly. Many of us use 42/40 PSI front/rear to improve fuel economy, at the cost of a harsher ride.
    Keep in mind that the battery system gets its cooling air from the cabin. If the battery system gets hot its efficiency, and thus your fuel economy, will drop. Rule of thumb: if you are uncomfortably warm then so is the battery, and you should turn ON your A/C. (Yes, this is one more way in which Prius is not like conventional cars.)
    If you do not have covered parking during the day consider a custom Sunshade for the front window, and then park facing south or southwest. Many Toyota dealers have these; I'd recommend the folding style and not the roll-up.
  10. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    Message Count:
    1,514
    Akron, OH
    Your Vehicle Year:
    And lastly the Climate control (especially the heater) can kill gas mileage, especially when at higher fan speeds.
  11. Offline
    magruder Average Member
    Mar 4, 2009
    Message Count:
    145
    Colorado
    Your Vehicle Year:
    The purpose of the bladder is to reduce evaporative emissions by decreasing the amount of air space in the fuel tank.
  12. Offline
    wicastawakan New Member
    Dec 22, 2008
    Message Count:
    107
    Oklahoma
    Your Vehicle Year:
    That pretty much covers it. You can accelerate with the traffic flow & still get good mileage. I use moderate to brisk acceleration, then back off & let the mpg max out while maintaining or slightly decreasing in mph depending upon the road situation. I think it is helpful to set your screen where you are seeing the mpg you are getting right now & you'll quickly learn what increases/decreases your mileage.
    On hills if I can cheat a little & pick up a little momentum/speed going down one, I then feather off a bit on the next climb & seems to work pretty well. I think it is better than trying to hold a constant speed, which means I don't always use my cruise in the hills.
  13. Offline
    Kennneth New Member
    Mar 6, 2009
    Message Count:
    Warrenville, IL
    Your Vehicle Year:
    Learn to accelerate evenly and smoothly. Since you have a constant velocity transmission you don't have to worry about what gear you are in. When you are up to speed, pretend you have an egg between your foot and the pedal and focus your sights about 1/4 mile ahead of you when you are driving and coast as much as you can (engine off). Absolutely do not tailgate, this will force you to brake and gas and brake and gas. City driving I get: Summer 60 mpg and winter (Chicago) 45 mpg. Hope this helps.
    go
  14. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    Lots of good points, thank you for all the info. So I guess only use the "B" when going down long hills to not wear out the brake pads or to slow down when the roads are icy. I guess its kind of like a "jake brake" in tractor trailers right? If I know that I'm going to come up to a stop up ahead (driving on a flat road), say 500 feet, but coasting will not slow me down enough, I will eventually have to brake, wouldn't it be good to just put it in "b" and let it slow me down this way? Maybe I'm missing something here.
    Also, I am curious how to get the "stealth" or "no arrow mode". I am pretty sure that if I am going up a hill it is impossible, and when I go down, it will always show arrows back to the battery, is the "stealth" mode only allowable on a flat road? Also, to go into stealth mode, do you slightly press on the gas? I know if you simply let go of it and coast, you will get the green arrows back to the battery.
  15. Offline
    Mar 4, 2009
    Message Count:
    145
    Colorado
    Your Vehicle Year:
    It is better to coast than to use B because you charge your battery while coasting. To glide the engine must be completely warmed up, and you have to be going slower than 42 mph. It is easier to glide on flat and downhill sections of the road.
  16. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    So how exactly do you glide? Do you just slightly press on the accelerator? I know that if you don't press the accelerator at all, you will be coasting right?
  17. Offline
    Mar 4, 2009
    Message Count:
    145
    Colorado
    Your Vehicle Year:
    Sorry, yes you have to slightly press the accelerator to glide. If you let the accelerator all the way up you are coasting.
  18. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Don't use "B" on icy roads. In "B" you are always getting some regenerative and/or "jake" braking, and there are times when you don't want to be braking on an icy road.
    Don't use "B" for slowing down in normal traffic because it it wastes energy unnecessarily. That use of "B" is perfectly safe, but it will reduce fuel economy. Learning to glide is better (below).
    You can indeed glide going uphill, and of course the car will slow down while doing so. Getting into glide is a matter of applying just the right amount of pressure on the gas pedal in a given situation. Glance at the display to see whether it is happening. After some practice it is possible to sense when you're doing it from the sound of the drive system and acceleration.
    Most importantly, don't stress about any of this. If you're not enjoying it it's not worth it.
  19. Offline
    f1hp New Member
    Mar 24, 2009
    Message Count:
    bc
    Your Vehicle Year:
    FYI: When using "B" you DO charge the battery; & that is a fact.
  20. Offline
    tom1l21 New Member
    Mar 24, 2009
    Message Count:
    262
    East Longmeadow, MA
    Your Vehicle Year:
    Yeah I thought maybe "B" was better because you won't be using brake pads.
    So I take it, coasting is only for driving in slow stop and go traffic, parking lots, or when your battery gets below 5 bars (to charge it)?
Share This Page
