1. Offline
    andreax716 New Member
    Start a Conversation
    Apr 18, 2008
    16
    Bay Area, CA
    Your Vehicle Year:
    Please help! I misplaced the instructions on how to install my Shark Fin Antenna from priuschatshop...anyone have some step by step instructions, or better yet, some picture instructions???
    TIA!!!
  2. Offline
    Rokeby Member
    Jan 21, 2008
    2,980
    674
    Ballamer, Merlin
    Your Vehicle Year:
    andreax716,
    Installation isntructions are at the VisualGarage site:
    VG Shark Fin Antenna - Installation
    there are a number of threads here on PriusChat about installation. Use the
    search function with "sharkfin" or "shark fin" and you'll find them quickly.
    Good Luck.
  3. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    Bolt the wire up, clean the roof, peal the paper off, and stick it on.
    Some other details on my page:
    EV page
  4. Offline
    wchardin Advertise Here
    Mar 16, 2008
    2,050
    Owensboro, KY
    Your Vehicle Year:
    Its also good to follow the instructions and use the masking tape to outline the placement, otherwise you will have an askew shark fin like me. Anyone know how to remove one and what to use as replacement tape, I would guess acetone and 3m tape.
  5. Offline
    mrblaise Go Lakers!!
    Mar 2, 2008
    2,247
    524
    Southern California
    Your Vehicle Year:
    I would also add to make sure you or a friend stands behind the car before final placement to ensure that the sharkfin is aligned perfectly straight forward. You don't want to end up with the antenna pointing slightly to the left or right. You really can't make that observation if you're too close to the car.
  6. Offline
    Jan 17, 2006
    6,041
    353
    Northern CA
    Your Vehicle Year:
    Yank it off with some heat, and/or floss. Then follow up with WD-40 or Kerosene (same thing, really). Wash well. Use an alcohol wipe, and start over with some 3m tape. Might be best to ask the company for a new ring though since you'll never cut your tape to look that good!
  7. Offline
    macmaster05 Senor Member
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Ok how did you install the shark fin since it's near impossible to reach from standing behind the car, and from the side it's still a good reach and you can't get see from a good angle if it's straight or not. Do you typically need a step stool? Even if I use masking tape I was hoping to stand behind it while I press the antenna down. Please advise. Thanks.
  8. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
  9. Offline
    mhmercer New Member
    Oct 11, 2009
    44
    Alameda, CA
    Your Vehicle Year:
    I used a two step, step ladder to get the Shark Fin where I needed it to be.
    I saw one example where someone used a laser pointer to line-up the Fin with the rear window washer nozzle. I had my wife check to the same effect, then I applied electrical tape near the Fin's perimeter as a guide. On a Gen III there's not a heck-of-a-lot of room to move the Fin off-center, as it soon bumps into the antenna below it.
    Be sure that the paint area where you intend to apply the Shark Fin's adhesive layer is very clean. I used 70 rubbing alcohol the first time. That was not sufficient, as parts of the adhesive separated from the paint over night. 3M General Purpose Adhesive Cleaner did the job intended.
    Marshal
    1 people like this.
  10. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    See, I KNEW someone had to use a step ladder to reach it properly! Haha. Thanks!
    I dont own any 3M GPAC and hope I wouldn't have to buy any for this install. I do have 70 isopropyl and the regular soap/detergent. My car is somewhat dirty and dusty, so I am debating between getting a full car wash or just cleaning the local area (it's not quite dirty enough to warrant a car wash). Thanks.
  11. Offline
    mhmercer New Member
    Oct 11, 2009
    44
    Alameda, CA
    Your Vehicle Year:
    Seriously: just get some 3M GPAC. You'll thank me later.
    Marshal
  12. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Just so I understand, so you didnt use 3M GPAC the first time and you found it didn't stick well. By the time you corrected the fin, wasn't the adhesive less sticky? How did you re-install the fin?
    Also, I just did a preliminary cleaning around the antenna base using only detergent and water and it feels very clean/smooth. The only thing I can see is some dust left from my cleaning cloth which I think I'll try to pick up with a swiffer static cloth.
  13. Offline
    Rokeby Member
    Jan 21, 2008
    2,980
    674
    Ballamer, Merlin
    Your Vehicle Year:
    When I mounted my sharkfin, in addition to taping off all the way
    'round the fin, I marked center lines on the tape fore and aft of the fin,
    and also on the front and back of the fin so that alignment was easy.
    Use "low tack," reduced stickiness, masking tape to make removal easy.
    It is either white, blue, or light green.
    DO NOT USE THE TAN MASKING TAPE.
    You can use any wax dissolving solution. I used Goof Off -- it comes in
    very small containers, some places even 7-11 carries it -- but mineral
    spirits, etc, will do fine.
    DO NOT USE ACETONE, BENZENE, etc.
    I would suggest :
    * Work in coolish temps, not in direct sunlight.
    * First, wash the mounting area with mild soap and water to remove
    dirt and grit.
    * Rinsing the area liberally with clear water.
    * Dry with a soft cloth.
    * Dampen a clean soft cloth with the chosen wax remover. (The idea
    here is not to have so much cleaner in the cloth that it drips somewhere
    else.)
    * Gently clean the mounting area.
    * Dry with clean, soft cloth.
    * Repeat the last three steps.
    * Mount the fin.
    * Carefully remove the tape. (There is a best way to do this. Do not
    pull the tape straight up, it can pull off paint. Gently, slowly pull the
    tape back on itself so it peels off. Even better is to pull the tape at a
    diagonal.)
    * With low tack tape it is highly unlikely to have any tape adhesive
    reside. But if there is any, clean it off with a rag dampened in the
    cleaner.
    * Wash and wax the whole car, with an extra coat of wax on and
    around the fin.
    * Celebrate! :cheer2:
    1 people like this.
  14. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Great advice Roke, thanks. Is 70% isopropyl (rubbing alcohol) a "wax remover"? And I assume the process of removing the wax does not strip the paint? Did my car even come waxed, cause I've never truly waxed it?
    Noted on the Acetone, as far as I know that is very abrasive and should be only used on metal.
  15. Offline
    Rokeby Member
    Jan 21, 2008
    2,980
    674
    Ballamer, Merlin
    Your Vehicle Year:
    I don't really know. I followed someone else's recommendations. ;)
    It looks like you have metallic paint. If so, it has a clear overcoat
    formulated to protect the paint from airborne pollutants, and even
    dilute acid rain -- for a little while anyway. The overcoat can easily
    withstand the oh, so gentle abuse of sensitive cleaning with a dewaxer.
    I would suspect that your car was washed by the dealer to remove
    transportation dirt/dust so it was all sparkly when you picked it up.
    Whether they also waxed it is anybody's guess.
    The dewaxing business is a CYA procedure to get maximum stick.
    Acetone is a clear liquid. It isn't abrasive pe ser. It is highly reactive
    and will soften/dissolve most any coating. Think of it as a fast
    evaporating paint remover.
    For long term shine and color retention, you should at least wax your
    car regularly. There are many threads on waxing or using one of the
    other special long lasting, high shine DIY coatings.
  16. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Thanks again. My scientific intuition tells me that rubbing alcohol is technically a wax remover, as it is a solvent, albeit, not as as strong as the commercial stuff like 3M. VG's instructions say to clean with rubbing alcohol first, then the 3M solvents or Dawn.
    You seem to suggest using the soap/water first, then using the wax remover/solvent/alcohol, which I agree with.
  17. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    sorry double post
  18. Offline
    sktn77a Member
    Apr 28, 2007
    270
    NC
    Your Vehicle Year:
    So what's your opinion on reception quality with the sharkfin? I'd love to get rid of the "Rubber Ducky" but don't want to ruin the radio reception.
  19. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    It's on its way in the mail so I don't have it yet, which is why Im asking all these prep/cleaning questions. But I'm crossing my fingers big time that it works well.
  20. Offline
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Does anybody know if its a bad idea to install the fin right before it rains (I'm getting it today but it's supposed to rain in 2 days)? I'm wondering if the adhesive needs time to cure, and rain would break those bonds. Thanks.
Share This Page
